Question about Ferret Instruments Digital Tach Advance Timing Light
Problem with a brand new ferret instruments timing light FER86
The light does'nt flash and the diplay shows 0000 when power leads and inductive pickup are connected. The timing light worked perfectly the first time, and stoped during the ignition timing.
    Problem Solver:
  • 18 Answers
The Ferret FI-86 was a speciality light was originally to be made for a European auto company. Needless to say Ferret was quite surprised when the European auto company said they only want 20 lights.
They were shown to an American Tool Company that added them to thier "Ferret Line" of test equipment. After that the unit gained popularity with Marine and Motorcycle Techs.
Here is what is the first thing I would check - The pigtail coming out the handle probably broken and the number 2 pin which is the signal from the pickup is not getting through which will give you the ZEROS across the board.
The cable is a 5 pin DIN connector, should be able to find these most electronis stores....also refered to as a MIDI cable.
The next thing you might want to check is the carbon parts of the pick up the "U" shape cabon and the "I" shaped carcon make sure these are not missing or broken.
Also make sure you have the switches in the proper positions.
Posted on Nov 25, 2011
  • C J B Nov 25, 2011
    Forgot to mention Ferret 800-627-5655 ask for Repair they have the carbons the other stuff - if you wish to do the repair yourself.
    1310 Higgins Drive, Cheboygan, MI 49721
Ferret finder needs recalibrating
Depending on the color red or black casing you will need to send it to the factory for a re-cal.
They have a fast turn around time.
1310 Higgins Drive, Cheboygan, MI 49721 800-627-5655 repair department Evy or Chris
Dec 20, 2013 | Ferret Instruments Digital Tach Advance...
Freeses same ceroingz gas detector lee phane 1 minuto remainig
The phone number is 800-627-5655 Chris and Evy run the repair dept.
The zeroing problem is a in a lock up state. really need to call in this situation
Apr 25, 2013 | Ferret Instruments GasLink II 5-Gas...
My ferret 84 timing light is about 7 years old. it has been working flawlessly until recently. when connected it always sees rpm but the strobe is very intermittent. i purchased a new pickup with no...
Check the Big Yellow Capacitor on the Ckt Bd. the lead closest to the strobe lamp should measure approx 300 to 350 VDC these have a failure rate after about 7 years. Also make sure the solder is making a good connection. The Seriel Num is on the top of the light should be something like 84-9934-0001 which broken down it is 84 the model. next group 9934 is the year, (last two digits of) and week the last four digits production number.
Also could be Lamp or the small red in color trigger transformer, diodes in the lamp area.
The pig tail will have issues at the "Heyco" connector. also what is the Ckt Bd is the construction Conventional "through hole" or SMT "Surface Mount"? I'm thinking it is the Cap.
Ferret Instruments or GXT, Inc. 800-627-5655 ask for Chris or Evy.
1310 Higgins Drive, Cheboyagn, MI 49721
Sep 21, 2011 | Ferret Instruments Digital Tach Advance...
Do i leave feedback ferret on all the time or take it out when feedback is measured
Normally you find where feedback occurs, notch it out with the EQ and recheck for feedback. When system is stable you can take out the ferret.
Feb 04, 2011 | Peavey 32fx USB 32 Channel Mixer
Ferret 40 ...... is there a breakdown for the carbon pile ?
Ferret Instruments was "bought out" by a company GXT, Inc. I worked there for approx 20 years. They have a interesting carbon pile. Consists of alternate Square and round carbon plates. Try calling 800-627-5655 ext 108 repair or they might have changed it ask for Chris or Evy they run the repair dept.
good luck..
or go online to GXT.com not a great website to deal with but the address is 1310 Higgins Drive, Cheboygan, MI 49721
Oct 21, 2010 | Ferret Instruments Battery Load Tester...
97 eclipse 2.0 got timmin set new wires new cole pack new cam sinser and it still wont iddle and
Check the auto-idle speed motor and EGR valve.
Take to an AutoZone or someplace they can read out any error codes for you.
Jul 07, 2010 | Ferret Instruments Digital Tach Advance...
I need A printer for a FERRET 63 engine analyzer.
Call 800-627-5655 ask for repair Chris or Evy. I think the thermal printer is a Seiko brand. AND I believe that Seiko discontinued this model.
1310 Higgins drive , Cheboyagn, MI 49721
The 63 is a good piece of test equipment
Mar 31, 2010 | Ferret Instruments Measuring Tools &...
Can't seem to record onto usb device. It saysitneeds more cpu?
I have the 24fx version of this and have noted the same problem. The solution seems to be turning off the feedback ferret as this uses around 30% of the CPU because it is running all the time! When the desk is booted up check the CPU usage before you turn on any of the digital fx. should show around 35% usage. Turn off the old ferret and hey presto, down to around 12% This should give you enough CPU to record direct to memory stick. Not the best design I know, but a really good sound engineer shouldnt need the feedback ferret anyway ;-)
Aug 07, 2009 | Peavey 32fx USB 32 Channel Mixer
Ferret Instruments  Digital Tach Advance Timing Light Logo
188 people viewed this question
Top Ferret Instruments Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Ferret Instruments Measuring Tool and Sensor Expert? Answer questions, earn points and help others
