Question about Quasar VHQ400 VHS VCR
Vcr showing "no signal check aerial"
Changed my aerial two days ago for a digital aerial now my vcr is not recording.HELP
    Problem Solver:
  • 5 Answers
Retune your video channels
Posted on Sep 16, 2009
The picture doesn't hold. The picture shows just snow on the tv.
VCRs are analogue. So their tuners won't pick up digital TV signals, and their output from the aerial socket is analogue too. You'll have to make sure your TV is on the analogue TV tuner and then tuned to the VCR output channel if you want to use the aerial connection for viewing. It's probably a lot simpler though to use the VCR's AV output to the TV.
If you connect a TV receiver (Aerial/cable/satellite) to the AV input on the VCR, then switch the VCR to that AV input, you will see and be able to record programmes.
Aug 25, 2014 | Televison & Video
I have a hdtv with digital channels. I also have a vcr that can record shows. The thing is i have everything set up correctly. How do i record the shows on tv to my vcr?
A VCR will not record HDTV signals. You can only record normal digital signals. If you wish to record HDTV channels you should look at Blue Ray Recorders.
Sep 28, 2013 | Televison & Video
Problems with Philips vhs recorder/dvd player
You only need coaxial cable to pick up TV stations broadcast via an aerial. If your TV has sockets to connect via HDMI or SCART, then any players can be connected via them. So if the adapter box picks up TV signals, you connect the main aerial cable to that and it should have a coaxial out socket, that should be connected to the aerial in of your TV. If you are recording to an analogue video from the adapter box, then that will need to be connected via a scart socket or other connection.
Nov 24, 2017 | Philips Dvd Player Vhs Video Tape Player...
I have an Alba 32880hdf freeview tv. I cannot record freeview programmes to my panasonic NV-FJ 780 vcr which has 2 scart sockets. I have no problem recording the teresteral channels. Can you help pls
Hi Victor,
You can't record the Freeview channels from the TV. It doesn't work that way. The reason you can still record terrestrial channels is because the VCR is still connected to your roof aerial with a co-axial cable and the VCR has its own built-in analogue tuner for recording terrestrial TV programmes.
To record the digital Freeview channels, you will either need to connect a separate Freeview set-top box to the VCR, or buy a VCR which has a built-in digital (DVB-T) tuner.
The VCR does not record programmes from the TV. It needs to be connected directly to the signal source, i.e. your aerial.
If you need any further assistance, please let me know.
Regards,
BElectric
Jan 15, 2011 | Televison & Video
I have a Grundig VCR which will not record tv programmes although it will play tapes quite normally. the skart lead is connected and i have tried changing it around and even a different one. cannot see...
You need to input a signal into the video from either your aerial or cable box etc. these are connected by either a scart from the cable/satelite box or the aerial input in the rear of the VCR, you will then need to tune the VCR in if using the aerial.You will not be able to record anything if there is no signal.
Apr 14, 2010 | Televison & Video
How do i set up atv without inbuilt digital a seperate digital box and a video recorder?the tv digital tuner and video all have scart leads.Should the aerial cable go to the video or digital box?
Aerial to digi box first then video then tv (not strictly necessary)
Depending on what you want to do with the vcr and the digi minimum scart connection is
digi to video - video to tv
Nov 08, 2009 | Computers & Internet
Cannot get any digital channels since local digital switch over
The official line on this is that you should try and retune again, but there are some Panasonic models with similar model numbers to yours which have been specifically identified as having incompatibility problems with the Freeview retune.
However, your model is definitely not one which appears on the problem list, so it's worth checking that your aerial wasn't misaligned or damaged during the gales last weekend. In addition the Winter Hill transmitter is currently undergoing work until December which will significantly boost the digital signal and give it HDTV capability, so your box may have have been knocked out of kilter if the current digital service was temporarily operating at restricted capacity. Digital signals are by their nature much weaker than analogue tv and if you have a marginal aerial system which has been up for many years and which feeds a number of televisions in the house then it's definitely a good idea to see about upgrading your aerial system.
The difference in actual parts costs between a top spec aerial system and a poor one are surprisingly low, it's also easily possible with careful design and installation to get a better performance with poor parts than you can get with a poorly designed and installed system using top quality parts. One thing does hold true though: a well designed and installed system using poor parts will only last a few years before needing serious attention but a proper job can last up to thirty years.
If you're sure about your aerial system and retuning does not help, then you'll need to contact Panasonic directly. The first web address below will give you their contact number along with a list of Freeview boxes with known retune issues. A second web address which I've given takes you to an excellent Sheffield based tv aerial company which has an incredibly informative website.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
http://www.aerialsandtv.com/index.html#ATVinfo
I hope that you've found my answer to be helpful and ask only that you return the favour by rating my answer.
Oct 05, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Sony VHS model no: SLV-SE710G isn't recording now that we have a freeview box. It just keeps changing back to L1 whenever i try to record anything!! I only want to record channels 1,2,3,4 !! HELP!!
Its hard to work out without looking at your cables. I assume the problem started when the freeview box got set up. I would guess that the aerial cable is now in the set top box instead of the vcr as the vcr sounds like it is unable to record when there's no signal (a common feature) so there shouldn't be a fault with the vcr,
just unplug the aerial from the set top box & plug it back into the vcr. Ch 1 2 3 4 should be back on vcr but set top box wont have any Ch.
most set top boxes have an aerial output, so you'll need another aerial cable, plug this into the aerial input on the vcr & ch 1 2 3 4 will be there but these will be analog (if your area has stopped analog transmission thats the prob rite there)
If you plug the matching cables from the set top box into L1 on vcr you'll be able to record digital tv as L1 use a signal from another tuner eg set top box, dvd player whereas the vcr channels 1 2 3 4 use the vcr's built in analog tuner. so it shouldn't be a biggie another cable should fix it,
Hope this is helpful, ask if you need more info
Aug 20, 2009 | Sony Televison & Video
My son dropped my vcr and now when I record all I get is a bluescreen during playback, was something damaged, can it be fixed or should I just toss it out?
Have you checked that your signal input eg. aerial connection, cable connection etc has not fallen out from the rear of the VCR. If this is ok does it still play pre-recorded tapes ok? Make sure the channel indicator is still showing a tuned channel such as 1 or 2 etc. If still a problem please get back to me.
Jun 06, 2009 | Philips VR330 VHS VCR
My Sansui recorder records blank when I use the timer!
first of all make sure the time and date is set correctly on your recorder (options or set-up usually) second make sure an aerial input is going to your recorder (not just to your tv (the recorder is in the loop with aerial lead to it then from it to tv)) third make sure the on-board tuners are tuned to the correct tv channels (recorder is just a tv without a screen and has its own channels that need to be tuned in)
Jul 13, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Quasar VHQ400 VHS VCR Logo
95 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
