Question about Microwave Ovens
My Delonghi microwave oven grill was until yesterday working perfectly well. I have checked all plugs etc. and the lights are working correctly on the machine. It has now stopped microwaving and defrosting. Help please. I regularly clean inside and it is in tip-top condition considering it is two years old.
  • 1 more comment
  • jan153 Mar 08, 2009
    Tried unplugging and replugging but no different. Still looks perfectly normal but nothing is happening. No heating food and not defrosting.
    The Model No is AC930AMQ 900 watt.
    Tried the door which seems fine and the turntable is working.
    Has worked perfectly well for two years. Unfortunately seems to have died. If indeed this is a major contol board failure I expect we will have to get a new microwave
  • 728 Answers
You may need a new heating element inside the microwave since you say it is not heating or defrosting anything, but all the other functions of the microwave works like the lights.
Posted on Mar 08, 2009
    President:
  • 987 Answers
You have to change the fuse on the control board...
  • 916 Answers
Check the fuses inside the machine. It sounds like you have a bad fuse that needs to be replaced.
  • 42 Answers
There would have been some short circuit inside the mother chip board . This might have happened if any water has flown inside and made rusty environment. Service ur oven
    Genius:
  • 1,550 Answers
You have a major control board failure.
There tends to be a relay failure on the control board or a shorted relay circuit.
  • SAM ANDERSON Mar 08, 2009
    Yes it is better to go with new one instead of investing money in old unit .
    When you buy new microwave get a extended warranty for three years .
    Brigadier General:
  • 8,619 Answers
Hi!
Please tell me the model number of your Delonghi microwave. Is the turn tray moving. Also check the door switch of your microwave.
  • 154 Answers
Unplug the oven for a long time and try again.
  • crysiszone Mar 08, 2009
    it seems a control board fault.
Mircowave works but doesn't work for heat/grill defrost etc
1.check fuse
2.check relay (microwave oven magnetron)
3, check switches of the doors
May 11, 2014 | DeLonghi P90D23EL-B1A Easi-Tronic Solo...
My micro/oven/grill (ed8525s-sbd on rear) will not turn on. after using the oven feature around 20 seconds after it had done it tripped the kitchen sockets and set the house alarm off. the fuse in the plug...
It's likely that some part of the microwave has gone short circuit and blown the main fuse. The fuse is a 7000 volt glass encapsulated inline fuse housed inside a tubular plastic case about 2 inches long.
Renew the fuse and switch on. Look out for anything that is not functioning and replace that part, eg, fan, light, turntable motor etc.
Jan 29, 2014 | DeLonghi MW 605 Convection/Microwave Oven
My delonghi ac925chs combination oven and grill work... microwave has stopped heating have noticed there is no light on in the microwave.and when i went to use it yesterday it would not heat in the...
Check this video it goes through checking and replacing magnetron, capacitor, diode and fuse. It will be one of those. Check the safety instructions in the description.
Sep 04, 2011 | DeLonghi Microwave Ovens
My de longhi ac925chs has suddenly stopped heating or defrosting but making all the right noises. The oven and grill still work ok. Is this just the fuse and if so, can i change it myself?
It's most likely a burned magnetron, and it's usually as expencive to replace than a new oven but since yours is equiped with a grill and conventional oven check the prices it could be worth changing...
Aug 03, 2011 | DeLonghi MW 535 Microwave Oven
DMX31 microwave does not work,grill, light, timer ok
its likley to be the magnatron burnt out, (the bit that makes it cook!)
its a very pricy part to buy and you cannot fit it yourself without putting yourself in danger doing it,, (like killing yourself!) so if you wont to get it fixed drop it into the shop or if its a fuw years old or more its a better bet to just buy a new one
0
Mar 05, 2010 | DeLonghi Microwave Ovens
Microwave not working
Magnetron may have died or internal fuse may have blown.Its could be all sorts of things.
May be time to buy a new one!
DO NOT TAKE OFF THE COVER YOUR SELVES, AS THEY MAY BE ELETRIC CHARGE STILL PRESANT EVEN WITH THE PLUG DISSCONNECTED
Sep 18, 2009 | DeLonghi MW 535 Microwave Oven
Microwave works perfectly but does not heat
Sadly your microwave has done it's last cooking. The mechanism you need to make it cook again would cost you more than a replacement microwave.
Jul 15, 2009 | GE Countertop Microwave Oven
Where is the 10 amp fuse on my delonghi micro/combo/grill please
Hi, I take it that this is a combi microwave? Some of these have settings on the front to microwave/grill/etc... so make sure its on the right one first!!
If you have selected the correct one then the m/wave does not work it could be several things!
Microwaves run to earth and need diodes to do this if these break down it will not m/wave! It could also be a internal fuse? ( but very unlikley if everything else works) Then you have the Mag or transformer which could be down to! M/waves run on a high power side and a low power side. The low power will not hurt you to much but the high power side will. My advice to uou is not to touch as it could be fatal as these things carry a high charge even when they are unplugged!
Dec 28, 2008 | DeLonghi MW 605 Convection/Microwave Oven
DeLonghi combined microwave/grill/oven.
Found this posted in GE instead of DeLonghi but the basics are the same.
You say it stopped working - you mean it runs but doesn't heat?
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
