Question about Sony Televison & Video
FAN NOISE yesterday we star to hear something like a fan noise... can some body help us? thanks
  • 294 Answers
CHECK THE FAN TO MAKE SURE ITS NOT DIRTY ALSO CHECK ALL THE VENTS AND CLEAN THEM AS WE'LL
Posted on Mar 08, 2009
Why does my refrigerator make loud fan noise when ice maker is on?
Hey friend, thank you for your post!
I understand that you are hearing a loud fan noise when your icemaker is on inside of your Frigidaire refrigerator. You could be hearing the evaporator fan or the condenser fan pushing air into your appliance, this is a normal operating noise. I hope this is helpful. -Matt
Aug 20, 2014 | Frigidaire FRS3R5EMB Side by Side...
Every 20 minutes, my freezer would make a crackling like noise. What does this mean and how can I fix this?
Refrigerators are not the most complicated appliance in the house, but it still takes a lot of parts working together perfectly to keep your food cold. If one of those parts breaks down, or begins to, you may start to hear new noises from your refrigerator. Fridges make some noise during regular operation, but if it suddenly gets louder or makes a different noise, it is a good sign that something is wrong.
Freezer Fan
Freezers can be located on either side of the refrigerator, or may be at the top or the bottom of the unit. If you hear a noise coming from the area in which the freezer is located, you should open the freezer and see if the noise gets louder. Any squealing sounds coming from this area indicate a broken freezer fan. These units are not designed to be repaired, and eventually one making a loud noise will break and need replacement.
Condenser Fan
All motors typically require a fan in order to maintain a safe operating temperature. Like the fan in the freezer, the fan that runs on the condenser can also break down and create a similar squealing noise. The location of the fan noise is what differentiates the freezer and condenser fan problems. If you hear a fan noise coming from the lower part of the fridge at the rear, it is likely the condenser fan causing the problem.
Action to do
Open the freezer to see if the noise gets louder. If the noise becomes louder with the freezer open, the noise is likely caused by the evaporator fan. If the evaporator fan is the culprit, replace it to get rid of the noise.
Pull the refrigerator away from the wall, and check the condenser fan at the back of the fridge. A metal panel may cover the fan, which can be unscrewed. Listen to see if the fan is the source of the noise. If it is, the fan may need to be cleaned or replaced.
Thanks for using FixYa.
Good day ! : )
Sep 07, 2011 | Refrigerators
The heater in my 2000 chevy malibu is making funny noises ... speeds one and two dont work.. havent since we bought the car... for 2 years now.. but what is that sudden noise that came on yesterday... like...
I have ran into the same problem, there may be something has got into fan cage. remove fan motor and investagate to see if it is blocked, or if fan is going bad. it is behind glove box, to remove. remove lower right dash insulator panel from under glove box. slide bcm aside for room to get at fan motor. remove 3 screws from fan motor, and remove fan after disconnecting wiring. the blower motor resistor is beside fan motor. the resistor will make ya lose 1 and 2 speeds. for it is a 5 step resistor.
Oct 29, 2009 | 2000 Chevrolet Malibu
Noise vibration
if you take the back panel of the freezer out you can get to the condenser fan they do have a habit of going bad and actually having the fan and shaft move forward on them usually when you start hearing the noise it is not long before it goes out completely.
May 15, 2009 | Frigidaire FRS26H5AS Side by Side...
Turbo Chef hi speed oven prblem with 2004 model very loud fan
is this a c3 or a tornado oven.there are afew causes for that type of noise but are diffrent for each type,regards les
May 08, 2009 | TurboChef C3 Single Oven
Seems to be a noisy fan on mb4210 combo
Could very well be the fan. The motors can cause interference. There may be a solution to get rid of the noise. Some copper shielding tape may help. You could rule out it being a microphonic preamp tube by turning the amp on as normal and tapping the tubes with something non-conductive. If you hear the tapping noise coming thru the speakers while doing this to a particular tube, replace it. With power tubes, the tops of them turn white on the top when they become microphonic, along with plenty background noise.
Apr 18, 2009 | Marshall Music
I have a ge above range spacemaker xl1800 it seems to work fine except their is a rattling noise when its running it sounds like a bad fan or something comeing loose it seems like its comeing from under...
The noise you are hearing is due to the fan. The fan is used to cool the magnetron during cooking, and because this fan is not working the magnetron is overheating and the thermal protector is opening, killing power to the unit. All you need to fix this is a new fan blade. The fan blade(look for part #80) is slipping on the motor shaft ( the noise you are hearing).
GE XL 1800
If the blade is broken then you can buy a new one from---
GE FAN BLADE
Please ask for further clarifications.
A Fixya rating would be appreciated if you find it useful.
Thanks
Rylee
Feb 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
