Question about Microsoft Xbox 360 Console
I have a xbox 360 witha benq drive it won't read the games
This is the orinigal drive will play dvd but not game says unplayable disc
    Problem Solver:
  • 19 Answers
This is a pretty common problem in the 360 and sometimes it will act a little crazy with errors like "please put into a 360 console", or it thinks games are dvds and just says "play dvd" after putting a game in. This is usually caused from the laser which is either dying out not getting enough power. You can either fix it yourself which will void the warranty, or send it in to get fixed which will cost around $100 for a new drive.
first open up the dvd drive and clean it good, including the laser. Then try the dvd drive POT Tweak
if you decide to get a new laser, then click here for instructions on how to install it properlly.
If you don't want to get a new laser or do the pot tweak, you can get a replacement drive on ebay or somewhere. It must match the key stored on the motherboard, so you would need to taked the pcb board out of the old drive and put it into the new one for the keys to match.
Posted on Mar 09, 2009
    Scholar:
  • 72 Answers
I have fixed heaps of these most common problem is the spindal motor starting to cease a little which puts more load on the ic which drives this only getting hotter when you butcher the pot adjustment it gets even hotter again which puts the wrong voltage to the lazor coils and eventually goes bang then you need a new drive, the solution is replace the motor but since you cant find one anywhere the second option is more apparent repace the rom complete and recode it to your old one another common problem is easy clean the lazer manually cotton bud and tiny bit of windex and dry with the other end (hint if it can read only once then the lazer is fine) check if your disks has no scratches or last nights dinner over them as well good luck
Posted on May 18, 2009
XBOX 360 Elite won't play disc; says "reading" then "open tray".
If the console has never been opened to change the dvd drive then eather your laser lens or one of the 2 motors in the drive needs to be changed. 90% of the time its the laser lens. You cant just use any laser for the xbox 360. There are 3 different drives. Toshiba, BenQ, Samsung, so you have to see what drive model you have before you try to order one yourself. I repair these often with 99% success.
Jan 24, 2010 | Microsoft Xbox 360 Elite Console - Black
It only plays Normal Xbox games
The open tray and unplayable disc is because the lens isn't strong on the drive and needs to have a Pot calibration done to it to make the lens signal stronger. That should fix the open tray/unplayable disc issue. I have done this to quite a few drives and all have been working fine since.
Jul 12, 2009 | Microsoft Xbox 360 Console
Unplayable disc
There is a good chance you DVD drive might have either a faulty motor or laser. In this case if you have any type of warranty you should use it but if you don't you'll have to purchase either a new XBox 360 or a new DVD drive.
The new DVD drive will not be able play games if you simply swap the drives. In order to have it play games you'll have to flash the old Key from the broken drive onto the replacement drive.
Either that or if your system is still under the 3 year warranty from RROD by Microsoft you can try to induce RROD on your XBox 360 and take up a claim with them. Most of the time they send u a refurbrished XBox 360 or a new one.
Jun 16, 2009 | Microsoft Xbox 360 Console
Wont play Games
It sounds like your drive has died. You will need to purchase a replacement from Microsoft or a licensed dealer. You can't replace with a generic drive as the Xbox uses proprietary firmware on them.
Nov 22, 2008 | Microsoft Xbox 360 Elite Console
Keeps saying unplayable disc
its your dvd drive change it.
Nov 08, 2008 | Microsoft Xbox 360 Console
Will not play any games
Some of the Xbox 360s have been known to have issues with their DVD-ROM Drives, On Older Xbox 360s The actual Drive has been known to cause slight scratching and scuffing to your Games.
If your Xbox 360 is having problems reading games, their is potentially a problem with the DVD Drives Laser, i had this issue last year with mine, Out of the blue the DVD Drive stopped working and wouldnt read discs. The i would suggest Calling Up the Xbox Customer support Center for your Country (numbers Available on www.xbox.com/support) and explain your problem to the person on the end of the line.
The only solution is usually to return your Xbox to microsoft Free of charge, which will be either repaired/replaced and sent back to you.
Also, once the solution is solved, it is important to NOT leave Games/DVD's In the Xbox's drive when not in use, Especially when moving the Xbox around as this can knock the laser and cause a fault ! their is only ever a DVD in my xbox drive when it is in use, i take mine out all the time to help prevent these sorts of problems.
Hope This helps !?
Oct 27, 2008 | Microsoft Xbox 360 Console
Unplayable disc
have you tried cleaning your Disc.
Jul 16, 2008 | Microsoft Xbox 360 Console
Unplayable disc
I've had similar problems and I got myself a CD lens cleaner.
Its a cd/dvd sized disc that has a few small bristle on it so when u put it into your drive, it spins and cleans the lens.
They are pretty cheap and you can get them in any electrical store and I've seen them in a few supermarkets.
Also check that your disc's are clean too.
Mar 23, 2008 | Microsoft Xbox 360 Console
Unplayable disc
Go to www.xbox.com go to support and lookif not ityour dvd drive
Feb 21, 2008 | Microsoft Xbox 360 Console
Wont read disc
Have you tried multiple games? Perhaps the particular game in question is scratched, or is no longer being read by the XBOX 360.
Jul 28, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
3,328 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
