Question about Bosch 1274DVS 3" x 21" Belt Sander
Drive pulley removal
I have a Bosch 1274dvs belt sander that needs a new drive pulley. I have stripped it down to the chassis and drive pulley but cant figure out how to best remove the drive pulley nut or gear that is holding the assembly together. I am open for suggestions.
  • 52 Answers
here is a parts breakdown. in center of picture is name of website where you can get a download. I cannot figure out if you are removing # 831 or 835 pulley. Either way its righty loosey on nut and you will have to hold opposite end to loosen.
Posted on Mar 10, 2009
Replace drive belt Bosch pbs7a
Nov 14, 2012 | Bosch Belt Sander Drive Belt For Pbs 7a,...
To replace drive belt on Bosch 7 PBS belt sander remove cover, 3 screws, place new drive belt over splined drive pulley. Feed belt clockwise over paper pully and Utilize welded hexigonal with suitable wrench to turn and 'pop' the belt on.
on Feb 02, 2014 | Bosch Belt Sander Drive Belt For Pbs 7a,...
I have acquired a makita 9924db belt sander, but not a manual. The dust bag is wide open on the bottom - shouldn't there be some sort of device on it to keep the dust in? Also, I would like to know...
there is usually a plastic clip that slides over the bottom to seal the bag, as for the manual go to "" and you can download a manual from there. Let me know if you need more assistance.
Jul 08, 2011 | Bosch 1274DVS 3" x 21" Belt Sander
PBS 7 AE belt won't turn and dust won't collecr
I had the same problem. On mine it was because the drive belt had worn out. This is under the black cover on the side. You have to remove three torx screws to remove the cover.
Jun 05, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
Belt sander
You're plugged in to a dead outlet, OR the rotor brushes are not in contact with the rotor, OR the power cord is partially severed,
Jan 06, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
I have a 1274dvs sander and it will not work .I use it all the time in my line of work. I think it is the switch but I dont have way to check the switch can you help.
Unfortunatly without a way to check the switch (multimeter) you will have to take it to a repair depot. Got to and look under "find a service center".
Jan 05, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
Bosch 3 x 21 Belt Sander
Remove the dust bag and unplug sander for now. Everywhere you see an access hole (fan area, dust port, back of sander blow thru the tool to remove lodged dust that clogged the system, Also look for broken belt pieces in the back of sander. Then while running (remove belt) blow again thru all the ports to try and reomve as much contamination as possible. When finished you can feel to see if air coming from dust bag port, it not you still have a clog that might need more work. If I have clarified your request would you please rate this response accordingly and thank you.
Sep 10, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
My Bosch 1274DVS 3" x 21" belt sander will run only sporatically
Definately sounds like bad switch or contact to the switch
Feb 26, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
Toothed belt bosch 1274 dvs
If I am correct, when holding the tool in the normal operating position there should be an oblong cover on teh left hand side nea the back of the tool. It should be held on with a screw. remove this cover and you can access the belt . MAKE SURE THE TOOL IS UNPLUGGED. the belt should pull off/push on with a bit of force. Turning the pulleys as you put it on will help it go on evenly. If it is too stiff, put the belt in some boiling water for a minute or two to soften it up a bit.
Nov 03, 2008 | Bosch 1274DVS 3" x 21" Belt Sander
Bosch 1274DVS 3" x 21" Belt Sander Logo
369 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
