Question about Dell 962 Photo All-In-One InkJet Printer
Dell Photo 944 won't print black and white
Selection box for "print in black and white" has disppeared from "Printing Preferences." Printing in draft mode to save ink.
  • 3 more comments
  • theonomo Mar 23, 2009
    There used to be a check box that would force the printer to print in black and white even if it was a color document. It has disappeared.
  • MyDellStuck2 Mar 29, 2009
    I have had the same problem for months. I finally openned chat with Dell, but they could not help me either. I am looking for my old disks to install the drivers. Using the Drivers from Dell website does not resolve this problem.
  • Anonymous Mar 30, 2009
    I downloaded new driver and also noticed the print in black and white option has disappeared.
  • farelain Apr 14, 2009
    well it's not exactly the same problem. i get the "print in black and white" check box but it still won't print in B&W. it says the cartridge is full but still won't work.
  • mbrooklyn Jun 07, 2009
    Thanks, but I don't have this option on the 944.
I had the same problem and just figured it out! On your control panel, choose printer and then Properties. Go to Printing Preferences and click on the Advanced tab. Under this tab is a button for More Options and then a section Complete-A-Print. I had to uncheck "use color cartridge for all black printing" and then check "use black cartridge to print in black and white." Then I had the option back to print in black and white. I have a Dell Photo 964 but I'm assuming the options should be the same. Hope this helps someone!
Posted on Jun 07, 2009
  • Applegirl168 Nov 03, 2010
    Worked like a charm for my dell 944, thanks!!
Printing black or color pages very good. but printing color prints color washed out
Check that the printer preferences selection is consistent with quality required for Photo print and the paper you are using. Check under printer properties / preferences.
May 06, 2014 | Brother MFC Office Equipment & Supplies
The large black cartridge is not working
Hi Cecile,
Check if you have selected Best Quality printing under Printing Preferences.
Open Control panel - Printers Folder - Right click on printer icon and click Printing Preferences.
Under Features Tab you will find the Quality mode - Fast draft - Normal - Best.
It could also be due to low on ink issue as well.
Regards,
Suhail
May 16, 2012 | Canon PIXMA iP4300 InkJet Photo Printer
I have mp210 and want to change my printer to just black and white as I don't do much color printing but my cartridge run's out and I have to keep replacing my color cartridge as well?
1. In Windows: Go to Start>Devices and Printers>Right click on your default printer. Select printing preferences.
2. In the area that reads: Additional Features in the middle of the window, you'll see a selection that reads: Grayscale Printing Put a check in that box. This will print everything in black and white.
3. Go down to the bottom of that window and put a check on the box that reads: Always print with Current Settings.
4. Click Apply
5. Click OK.
Once you are just printing in black and white, the only cartridge you will have to replace is black ink-unless you change it back to color in the future-then you will have to replace the color cartridge as well when it is low.
Apr 17, 2011 | Canon PIXMA MP210 InkJet Printer
When i print a pen and ink drawing it prints very lightly
Try changing the color quality of your printing under your printing preferences to best to get darker prints.
You might have set your printing quality to fast draft or fast normal.
If you do not know how to go to your printing preferences. Follow these steps.
1. Go to your Printers and Faxes(XP), Printers(Vista), Devices and Printers(Win7) 2. Right Click on Your Printer Icon 3. Click on Printing Preferences 4. On Print Quality, Choose Best. 5. Under Features -- Check the box for Print in Maximum DPI.
I hope this one helps. :)
Feb 04, 2011 | HP Deskjet 5440 InkJet Photo Printer
Change setting
on windows go to configuration panel, select printers and faxes icon
in the printer and faxes window mark the dell printer, right mouse click and select properties.
Look o
I hope this answered your question.
n the different printer tab and select as default output draft.
Aug 30, 2009 | Dell 944 All-In-One InkJet Printer
Can't print color only black and white
Please check if your Colour Ink Cartridge is not emply. If their's ink in the cartridge then try to service your printer through the Print Preferences. Your Colour Cartridge Nozzels could have been blocked thats why your printer is unable to print in Colour.
In case if both the above doesn't work then check in the Print Preferences that you should not have saved the option of PRINT DOCUMENT IN BLACK ONLY. hope this helps , AJ
May 18, 2009 | Dell 966 All-In-One InkJet Printer
Can't set printing preferences to "print in black and white"
try to reset the preferences to factory defaults. Open print preferences > Click on Profiles on the top right > click on factory defaults....
It should solve the issue
Aug 04, 2008 | Dell 924 All-in-One InkJet Printer
R220 inkjet ------------- won't print
No it,s not a glitch, the printer is informing you that these are also out of ink.
Go To START/PRINTERS/Right Click On EpsonR220/Printer Preferences. Tick The Box Draft Or Text.
Should Now Print In Monochrome ( Black and white )
Yoou probably have it set to photo or other colour option.
Mike @ Compurepair.
Feb 27, 2008 | Epson Stylus Photo R220 InkJet Printer
How to print all color pages into black prints.
go the printer name in start ->control panel ->printers and other hardware ->view printers and faxes.
Note :If it is in classic view just click on printer and faxes.
right clik on dell printer name
go to preferences.
window comes about printing preferences - Print Setup.
there is an option which says print in black and white, make sure that box is checked.
apply those settings and then try printing something.
do reply if this worked
Regards
Mohammed
Dec 09, 2007 | Dell 922 All-In-One InkJet Printer
Dell AIO 924 - Can't get the Print In Black Only option to work
I had this problem. It's actually very easy to fix:
- Print -> Properties
- Go to "Advanced" tab
- "More options"
- Deselect "Use color cartridge for all black printing"
- Select "Use black cartridge to print black and white"
- Click "Ok"
You should be able to select the "Print in black and white" option now and stop all the frustration!
Anthony
Dec 05, 2007 | Dell 924 All-in-One InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
1,139 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
