Question about Apple iPod touch
Alarm screen is on saying dismiss or snooze, I can't get it to unlcok
    New Friend:
  • 102 Answers
HI!  Click on clock then at the bottom click on alarm, then make sure the on/off button is to off.  Hope this helped if not let us know and we'll get back to you.  Thankyou for asking!
Posted on Mar 11, 2009
I am using my mother's Elgin 3400E travel alarm
On my Elgin alarm clock, you just push the nap button and it will add 15 minute increments for a nap. I haven't figured out how to turn it off if I change my mind or wake up earlier than I set it.
Jul 21, 2011 | Elgin Travel Alarm Clock
I have a Samsung Galaxy Ace. When the alarm went off, I pressed the home menu key as I picked the phone up, and was then unable to get to the screen where I could turn the alarm off. After a couple of...
GALAXY ACE-HOW TO TURN ALARM OFF - Hi, you've probably figured it out by now but just for any other new users who are still struggling, here is the answer: Galaxy Ace : When your alarm is going off and you lose the screen option to either snooze or dismiss, simply look in the top left of the phone and you will see the little alarm icon with an exclamation mark on it, on the top bar where the signal strength indicator and the battery icon is. You can scroll your finger down over this top bar and move it down over the top of your current screen, and when the alarm is ringing, the option to either snooze or dismiss the alarm also appears on this pull down screen. Peace at last!! Hope this helps someone.....
May 05, 2011 | Cell Phones
KADIO KD-3806 Model watch. How can we set date and time.
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
Nov 12, 2010 | Watches
How do I change time on a KADIO clock 3809
press mode to toggle between alarm time and current time;
Nov 08, 2010 | Watches
How do I turn off the alarm?
Pageturn off alarm
When the display shows an alarm:
To turn off the alarm, press Dismiss or Red/End button.
To set an eight-minute delay, press Snooze.
Here is the link for your manual: http://www.motorola.com/staticfiles/Support/Mobile%20Phones/Motorola%20Tundra%20VA76r/US-EN/_Documents/Static%20Files/VA76r_UG_att_9519A36A.pdf
Oct 22, 2009 | Motorola Mobility Tundra VA76r Cell Phone
Need to learn to make adjustment on my watch
Setting CASIO G-Shock Watch
1) Home City
2) Home city and Setting the digital time
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
( ) Button reference
C__ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached. (makes higher pitched beep)
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
May 11, 2009 | Watches
When my alarm goes off my phone does not prompt me to dismiss or snooze. It use to but it no longer does. I either get so frustrated and want to throw the phone or I just don't hear it and am late for...
Disable the old alarm and create a new alarm and see if you get the same result. For example if Alarm1 is the one not working, make an Alarm3 with the same setup. I had a similar problem with my Samsung phone. Alarm1 stopped allowing me the ability to snooze. I created a new alarm in a new slot and it is working fine.
Apr 25, 2009 | HTC Touch Diamond Smartphone
Casio G-Shock 7510
1) Home City
A --- B 2) Home city and Setting the digital time
( ) 3) Adjusting hands
C __ D 4) Alarm set/on/off
5) Snooze
6) Chime
Hold A until second flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A when done adjusting all items to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to go back to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B and D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off.
5) Snooze (SNZ) and Hourly Chime (SIG):
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B and D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off.
To turn any alarm off, press any button. To cancel next snooze, Press C to go to either the timekeeping screen or the snooze alarm screen.
6) Chime on/off
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
Nov 18, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Razr V3 Alarm Will Not Shut Off
My Razr V3m also has this issue. One way to shut the alarm off is (1) make a call to your cell from another phone. (2) Disconnect the call from the other phone without picking up (3) You should see two events on your cell - one for missed call and the other for alarm. (4) Delete the alarm event first and then the missed call.
Drawback for this solution is you need access to another phone...everytime :-(
Sometimes, I am able to shut the alarm successfully without any problem
Aug 22, 2008 | Motorola Mobility RAZR V3
Duplicate alarms
I may be off base but might the problem be as simple as the frequency being set for the alarm. What I mean to say is, might the default reminder time for the alarm be set to such a low setting like sec's or minutes leaving the unit to repeat the alarm rapidly prior to your being able to dismiss/snooze. Good luck.
Sep 14, 2005 | HP Jornada 548 Pocket PC
Apple iPod touch Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
