Question about E-Machines eMachines Desktop PC
I own an e-machine talbe top computer model #MIV83 70H 03901. The other night I tried to jiggle around the wires in back connected to the speakers and I got them back. Now they fell out and I am really not sure If I am putting them back in the right place. I am trying to read the book but that says one thing and what I am being told to do is another. Help!!! Sandra Bures bures9008@roadrunner.com
    Scholar:
  • 54 Answers
On most computers, the audio jacks are color-coded. The GREEN jack is for the speakers, and the PINK jack is for the microphone. If your audio jacks are not color-coded or have different colors, there are also small graphics next to the jacks to help. For the speaker jack, you are looking for a jack that looks like a circle with an arrow pointing OUT from the center.
Hope this helps.
Posted on Mar 09, 2009
My left speaker has no sound unless i jiggle the cord right at the part where all 3 p;ugs turn into 1 cord. how do i fix it?
The wire inside the speaker cable is broken. You may be able to identify the exact point the wire is broken by bending the wire and unbending the wire. If you can locate the approximate location of the break, you could cut the broken section out then strip the wire, and reconnect. Best to solder if possible. Otherwise, you will probably need to replace the cable or buy a new speaker set.
May 19, 2014 | Logitech X530 5 Speakers
No sound
Tried unplug,replug the tv back about an hour later.Than do resetting to all audio setting back to factory setting.Now ur tv should have audio back again.If this is a computer audio problems,check ur speaker plug in wire from the sound card jiggle the wire a little.Ur computer audio should return,most of the times just cold connections between the sound card and the audio speaker wire connections.
Feb 09, 2013 | Computers & Internet
Dometic duo-therm rooftop ac unit motor wont spin unless i jiggle the wires that go into the motor then it works! Trailer sat in a monsooon storm last night. next morning compressor kicks on just fine and...
If you have to jiggle the wires going into the compressor motor to get it going, I would submit that you may very well have a broken wire or otherwise loose connection that is making contact when you jiggle the wires. If all appropriate connections were good, jiggling the wires would/should have no effect. I assume you are jiggling wires AT THE MOTOR input and not elsewhere in the circuitry. After you jiggle the wires and get it started, does it continue to run? or if not, describe more thoroughly what is happening..
Jul 14, 2012 | Dometic Rooftop RV Air Conditioner
How to connect speaker into my computer.
Speakers generally have a cord with a usb plug on the end for power and another cord with a male audio jack (it should be green) for receiving the sound from the computer. On your computer tower there should be terminals for both. These are located on the back, front, or both depending on computer model. Connect each wire to its respective terminal. If possible you should connect them from behind because it creates less of a mess around your desktop.
Aug 25, 2011 | Kinyo Audio Players & Recorders
My husband purchased Bose compnion 5 in Singapore last December. He tried it last night but the right side speaker had a very soft sound compared to the loud sound from left side speaker. How do we fix...
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 31, 2011 | Bose Companion 5 Multimedia Speaker System...
I let a friend borrow my speakers (z-2300) and When they came back one of them fails to produce any sound. I switched the wire connections with the same problem on the same speaker (absolutely no sound....
hope this helps
May 03, 2011 | Logitech Z-2300 Computer Speakers
I have a harman/kardon computer speaker set. model REVA00 what are all the wires required to hook up to computer. Set includes sub woofer and two desk top speakers.
If you turn your pc around, so that you can see the back. There should be a series of small coloured holes - each of which has an image. From there you can plug in the corresponding wires for L and R speakers and the bass (subwoofer)
Mar 03, 2011 | Harman Kardon Audio Players & Recorders
Short in subwoofer wire - Altec Lansing computer speakers & sub
yes, you can splice the cables and put on a new connector, goto radio shack with the old connector and im sure they will have one you can splice right onto it. ive done this many times with varios equipment "headphones speakers etc" it may take a couple of tries to get the wiring right but if its just one speaker there will most likely be just 2 wires, if you wire it up and it doesnt quite sound right, wire it the other way. speakers will work wired backwards but wont sound quit right so if it doesnt, rewire it and it should. good luck and i hope this helps!
Jan 15, 2010 | Altec Lansing ADA 885 Computer Speakers
My speakers started buzzing and making a horrible noise during the night. I had to unplug them to get it to stop. What's going on?
Feedback. Check the wires, might have a bad connection. Wiggle them around and see if the buzz sound stops or changes. If that happens, its usually that wire. Good Luck.
Sep 10, 2009 | Harman Kardon HK695 Computer Speakers
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
