Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
Vertical lines I've a Toshiba 46H84 Projection TV. When I first turn on TV, I've vertical lines across screen, but it does get better after it warms up. But now it seems to take longer to clear up, also I've noticed after it clears up, I've what they use to call ghost lines, but I use Directv satellite so that never has created a problem before, and I've two other TV's on the same dish without any problems. Before I noticed the vertical lines I did notice that the picture seemed dark and I adjusted the brightness on it, but it really did not make any kind of difference. Is this something I can repair myself by changing out a module? I've a Toshiba 46H84 Projection TV. When I first turn on TV, I've vertical lines across screen, but it does get better after it warms up. But now it seems to take longer to clear up, also I've noticed after it clears up, I've what they use to call ghost lines, but I use Directv satellite so that never has created a problem before, and I've two other TV's on the same dish without any problems. Before I noticed the vertical lines the picture took a while to clear up when warming up. So I have kept my tv on all the time but not the HD box from DTV.Is this something I can repair myself? and how do I do it?
  • 916 Answers
First unplug the TV and leave it unplugged for about an hour. Whenthe TV is plugged back in it will be reset to the factory settings.Then go into the menu and try adjusting the convergence to correct theproblem. Problems with a projection TV are a very common occurrence.These sets will run hot inside and heat is the number one enemy ofelectronics. Over time the capacitors will change value, leak andbecome defective. Resistors will change value and burn. This will causeother components to become defective. This can have a domino effect andcause other parts to fail. Replacing one defective part may make the TVoperate for a short time but the part will fail again since if theparts that caused the failure to begin with are not replaced. For aproper repair all the electronics must be diagnosed by someone with thetest equipment and the skills to use the test equipment. The repaircost of most rear projection TV sets is in the ballpark of $400. Thisis why you can these TV sets not working at what would seem to be agreat deal. I wish I could tell you there was a button to push thatwould fix the TV but that is not possible.
Should you requirefurther clarification, never hesitate to ask. It would be my pleasureto clarify my answer to your question. If after reviewing the aboveinformation, you have additional questions, I will be glad to answerthem. My goal is your 100% satisfaction with all questions I answer.
This information can be found here: Click Here
Posted on Mar 08, 2009
    Genius:
  • 1,550 Answers
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
It tends to be fault with horizontal IC .
  • 154 Answers
There is a moisture problem on the main board.
It has vertical lines
I had a similar problem and had to replace the computer chip.
Mar 01, 2014 | Toshiba 46H84 46" Rear Projection...
Vertical lines when I turn on my Toshiba 51HX84
Thats a common issue caused by bad capacitors on the hyper module
Feb 10, 2013 | Toshiba 46H84 46" Rear Projection...
Black line running vertical from top to bottom toshibia tv 42
Model listed here is 46 inch---what is correct model of your TV?
Jun 15, 2012 | Toshiba 46H84 46" Rear Projection...
Hello..Toshiba 51HC85, 2005 model. Turn on TV and verticle wavy lines appear until TV is warmed up completely. After warm up the picture is great again. Any ideas?
I've had the same problem for about the last 6 months. My workaround which was to leave the tv on 24 7 and just turn off the TWC service box. But now the symptoms are vertical dark lines going all the way across screen. My guess is that it will cost more to fix than worth it. I paid @$2000 for it new in 2004. Technology has gotten better so I may just go out and get a Samsumg for considerably less and be way better off. None of Toshiba's products had done well for me. 2 laptops, 3 tvs, etc. have taught me this.
Sep 20, 2010 | Toshiba 51H83 51" Rear Projection...
I have a Toshiba projection tv (46H84). When I
Yes!!!
You need to open the case, then remove the board from the unit, then check all the circuit, probably there's damaged circuit connections, use soldering iron to fix this problem....
Oct 18, 2009 | Televison & Video
I have vertical lines on my screen. They appear to
This a common problem in many of the Toshiba sets----set has a "HYPER" circuit board that processes all the signal for the set--surface mounted caps all start to dry out--always starts out where it will have the problem and then when on for a while it gets better and goes away--eventually when enough of the caps are gone--it never gets better.
Board is now only available by removing it and sending it out for rebuild/repair---company doining this is Pts electronics--part number is:
23148103Cost is about 180 dollars plus shipping and this may mean considering the labor to get the board out that the set is not worth repairing.
Sorry to give you bad news but I am certain this is what your trouble is.
I do this here for free so if this information helped you to decide what to do--take a minute and give me a vote here.
If you have questions or need advice reply to this posting here.
SD TECH
Sep 15, 2009 | Toshiba 46H84 46" Rear Projection...
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
Vertical lines
hair line cracks in motherbord on soldering jobs look all over re soilde rthem back togther nicely
Oct 31, 2007 | Toshiba 46H84 46" Rear Projection...
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
163 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
