Need to find a cover for duo-therm roof top ac model # 57915.622
Cover was broken in hail storm about 1 year ago.
    Guru:
  • 462 Answers
I wish I could help you but my agreement with fix ya says I can recommend any names or addresses or phones or emails.
Is this an RV?
Posted on Mar 08, 2009
Where can I find the model number on this old Duo-Therm roof AC. Is it possible to recharge it?
Take the cover off to see the data plate. There may be one inside by taking the inside cover that holds the louvers and filter in place. If it needs to be recharged, then there is a leak in the metal tubing. That has to be located and repaired first. Install a drier on the low side to absorb any moisture let in by the leak before evacuating the system for freon.
Aug 07, 2015 | Heating & Cooling
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
Duo therm ac in my rv quit when the converter burned up does the ac need 12v to work?
there is a fuse located under the shroud on the roof AC on a circuit board that controls the thermostat to turn on the power to the Air Conditioner replace it it is marked F-1 or, on some F-2 etc.
the air conditioner works on both DC voltage for the thermostat and AC voltage for the compressor
Sep 08, 2013 | Dometic 3312024.015 Duo Therm Comfort...
RV AC is working fine, but the water is leaking from the ceiling Where is the drain tube on the unit, The AC unit is a roof type, Duo Therm serial # 43404934, Part # 3105459
Normally, the condensate will drain out of the unit onto the roof and off the edge to the ground. Remove your cover inside (probably 2 screws) and tighten the 4 bolts you will find inside. If they are tight, go to your RV supply place and get new roof gasket. Remove the AC and insert the new gasket and resecure the AC to your roof.
Thanks for your question @ FixYa.com
Jul 26, 2011 | Dometic Rooftop RV Air Conditioner
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
Duo Therm Penguin model 610115.311 AC unit no-power
Actually you should have fried you converter. What is the voltage reading you get for the air conitioner? supply? One should run off the generator and the other on shore powerIs it set up that way?.
Sep 28, 2009 | Heating & Cooling
Ac unit blowing water with air on after a few minutes
2 things to check, one is remove filters on inside & look at front coils to make sure they aren't frosting/freezing up. The other, remove cover on upper unit & check that drain holes in base are not plugged. Be careful of wasp nests when removing cover. If neither one of those is problem, you may have a cracked drain pan, which you can also observe/inspect when cover off on roof unit.
Jul 21, 2009 | Heating & Cooling
Duo Therm AC/Heating not working at all after tripped breaker.
I had to get on the roof of mine, remove the cover and manually spin the fan. Add a little oil to the shaft where it goes thru the bearing. All of this is done on the roof side. Mine required this procedure every spring. Duotherm realizes they had a problem and have since corrected it but they don't deal with all of their customers that had the original problem.
Jul 20, 2009 | Heating & Cooling
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
