Question about Aprilaire 550 Humidifier
  • 189 Answers
Hi Kathy,
The water panel fills with mineral deposits. For only $10 - $14 you should replace the water panel once a year.
When you remove the old one. Warm water, or bleach or white vinegar will clean out the inside very nice. Take model number with you to the hardware store or Lowe's or home depot. There are three sizes to pick from. Your model number will be on the box for the panel you need. IMPORTANT.....When you install it make sure that the black sprayed on dot on the edge of the panel is the end that goes up.
This is very easy to do, you will be fine. Just change it every year for maximum and economical performance.
Good Luck
HVAC Teacher
Posted on Mar 08, 2009
Aprilaire 550 not turning on
Hello, apply power directly from transformer to solenoid valve, it it does not turn on the solenoid valve must be replaced. If there is no voltage to the solenoid then follow the wires back and see where there is no voltage.
Nov 18, 2011 | Aprilaire 550 Humidifier
Aprilaire 550 making loud noise - sound like not enough water going through pump?
Hello, check to see that the inlet strainer into the solenoid is clean and no sediment has built up in it, also make sure the outlet of the saddle valve is clear and there is no sediment there.
Feb 14, 2011 | Aprilaire 550 Humidifier
How do you clean the build up in the solenoid?
Go to the Aprilaire web site and download the owner's manual. The instructions for cleaning are on page 13.
Jan 04, 2011 | Aprilaire 550 Humidifier
My Aprilaire new water pad has a white substance on it. I mentioned this because twice the pad (tworeleased a sticky, mucous substance that plugged the drain line and caused flooding in my basement. The...
Hello,All the pads have a protectant(white) coating because the pad is aluminum and would rot out fairly quickly from getting wet.The slime is bacteria(fungus) not from the coating that forms from stagnant (sitting) water.Make sure the unit is draining out dry after each cycle.With the pad out pour vinegar OR bleach & water (10:1) to kill the mold in the drain pipe.Do not clean the pad at all ,it gets replaced.They sell an inexpensive wet floor alarm at the store that makes noise when wet.
Oct 12, 2010 | Aprilaire 550 Humidifier
The panel on my aprilaire wont click when you turn it, what could be wrong
check power source at unit,clean thoroughly, remove access panel, look for corrosion damage at all electrical conns.pads wet?
Jan 31, 2010 | Aprilaire 550 Humidifier
440 Aprilaire Humitifier small solinoid doesn't open
Make shure that the the filter in the bottom of the valve is clean. Turn water off use a 1/2 & 7/16 wrench to take apart the bottom connection on valve use a small screwdriver and push the small screen out and clean then put it back together.Use the same wrenches and take apart the top of valve clean inside valve and clean small orfice in plastic water line put back together. Make shure 24volts is gettin to valve you should her a click when furnace is running or fan. It may take a couple times to clean. Hope this helps
Jan 11, 2009 | Aprilaire 600 Humidifier
Aprilaire 550 humidifier
Did you clean the orfice ? It is located on bottom of solenoid. It is plastic with a very small hole.The hole gets plugged and you can clean it or buy a nw one for 50 cents.
Oct 18, 2008 | Aprilaire 550 Humidifier
You can call 1-800-955-7075 give them the make and model #.The part # should be 4217,10x113/8 frame for $14.56 plus shipping
Nov 20, 2007 | Aprilaire 550 Humidifier
Aprilaire 550 Humidifier Logo
773 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
