I was getting perfect reception, grandchildren touched the remotes, TV and Converter box, now I get no reception from the converter. I misplaced the operating guide. Can you help getting it restarted?
  • steve_wyman Mar 08, 2009
    Zenith Converter box ptt 901. I did as instructed, disconnecting and reconnecting after a half hour, and nothing. The box is on but it is not sending signals to the set - just a blank screen.
  • 19,396 Answers
To start ensure that the problem is not a lose cable at the back of the TV or of the Box, check all cables and connection.
If that is not the problem, the solution depends on what cable you use to connect the box to the tv.
If you use a coax antenna cable, you may need to do a channel auto tune search to find the frequency from the obx. Do this only if you use coax connection.
On any other cable, switch the box channel, to ensure you are not on a blank channel, and use the tv remote source, or input button untill you do not find the picture for the box channels.
If that does not work, then it is probably a cable and connection problem.
Posted on Mar 09, 2009
  • 42 Answers
Ok unplug the converter box and replug again in the tv and in the power slot..... it will work .... if not check whether the battery has worn out in ur remote .....
Posted on Mar 08, 2009
    President:
  • 1,011 Answers
Place tv on channel 3 manually .if this is a converter box for dtv without cable.
  • 916 Answers
Change the tv setting back to antenna they may be on air, or on cable. Once changed back the set will be working again.
  • 10,594 Answers
It seems children changed antenna selection in TV menu.
Please go to TV Menu and select RF-1 or Antenna-1 to view TV channels.
    Brigadier General:
  • 8,619 Answers
Hi!
Please tell me the make and model number of your cable box
    Genius:
  • 1,550 Answers
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
Remove all connections and connect once again .
  • SAM ANDERSON Mar 08, 2009
    Provide details about the model of your tv ?
  • 154 Answers
Reset your tv as default. and try again.
  • crysiszone Mar 08, 2009
    Tell me the model number of your TV.
    Top Expert:
  • Televison & ... Master
  • 77,499 Answers
What is the brand and model of the converter box? without this info it is impossiable to know what is wrong, U can find an on line manual with the the above info.
  • yadayada
    yadayada Mar 08, 2009
    why the thanks for trying, haven't provided any assistance yet
Converter box will not stay on - starts green light then switches to red
I have one of those right here attached to my computer so I can watch TV on the PC. The red-green light is the power indicator. Your converter is turning off for some reason. Possibly it is getting a signal from another remote, and turning off. You can block the converter's remote sensor with something (black tape works) and then change the channels with front panel buttons if it has them.
Mine has power buttons for both the TV and the converter, so watch out for that.
Apr 06, 2017 | Televison & Video
Connecting a sansui 13 inch to a converter box
1) Connect the converter box to a good digital TV antenna and position the antenna as high and as close to a window as possible.
2) Set the converter box 'output switch' to an unused channel for your area. (Usually 2, 3 or 4.)
3) Connect the output of the converter box to the 'antenna input' on the TV.
4) Turn on both units and set the TV channel to the same output channel selected above.
5) Now select TV channels using the converter box remote only. The TV should receive all converted channels on the preselected channel.
6) Adjust the TV antenna for the best reception for all channels.
May 04, 2014 | Sansui Televison & Video
I need the code for rca digital conv.box
Which code? For the Universal Remote? If so, it has a scanning function on it.
Dec 18, 2011 | RCA Analog (RCA) to Digital (VGA)...
Yes hello, i'm trying to hook up my Coby 12'1 digital tv to a converter box is that possible or do i need a cable box for it to connect?
You should be able to connect the tv to a converter box. This is good for OTA signals to a TV with an NTSC tuner (coax) or composite video input. http://www.cobyusa.com/?p=prod&prod_num_id=205&pcat_id=2007#features-tab has the manual for the DTV102. Put the antenna coax cable to the converter box ANT In and then either the antenna out to the TV or the A/V (composite) out to the TV's composite in. If you use the RF connection, you will need to set the TV to channel 3 or 4 and set the switch on the converter box appropriately. For a composite video connection, you will need to change the input to AV1 (if there are several inputs). Depending on the TV, there may be a source or input button on the TV. For other models this is only on the remote. If you have the original remote, no problem. If you have a universal remote, make sure that you have a key that corresponds to the feature and that you found the code that lets the key work for your TV. (Not all universal remotes have the feature.)
However, you should get the best antenna that you can and have it pointed correctly to receive the stations. Digital signal doesn't have borderline reception. Try antennaweb.org or tvfool.com to check the stations and directions in your area. Antennaweb assumes an outdoor antenna but is very conservative in the channel list that it will indicate you can receive. Tvfool lists the channel reception depending on the antenna type. Tall trees and buildings can block the signal.
I hope this helps.
(please note that surges from the antenna can damage converter boxes and kill the tuner.)
Feb 08, 2011 | Coby DTV102 ATSC STANDARDDEFINITION TV...
Get Dtv with my 37MF321D
This TV does not have built ATSC/RF Tuner.
I have this same model TV, the analog reception is snowy even with outside aerial. I have to get the Govt, Set box converter and the picture is now perfect! Apply for the Govt Digital TV converter Box and you will enjoy it
Feb 01, 2009 | Philips 37MF321D 37 in. LCD Television
Converter box worked fine and now wont get any signal
Did you go through the complete setup by putting your TV on Channel 3 and letting it scan all of your channels or are you just hooking up the box and not doing this? Make sure the box is set to "blue" which is On and do the complete setup.
Nov 18, 2008 | Zenith C27A24T 27" TV
Receive one channel with Coverter Box
Make sure those 6 channels are also being broadcast in Digital format also, otherwise your converter box won't have a digital signal to convert for your TV. The switchover date is early next year I believe.
Oct 10, 2008 | Zenith C27A24T 27" TV
Haier / Celera TV & RCA Converter Box remote code
hi guys,
pgm-->tv code-->ok-->you are done
try this link for codes.
http://www.1800customersupport.com/productdocuments/DTA800_code.pdf
hope you got it.
Satya.
Jul 18, 2008 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
