Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
My USB cruzer 4GB has suddenly stopped working
I have tried plugging it to many different computers and it is not registering. No red light, it doesn't open
It is a san micro cruzer 4GB. Please help
  • Anonymous Mar 25, 2009
    my flash drive was working one minute...i safely removed it and plugged it into a different computer- and nothing....
    i have tried many computers-both mac and pc operating systems also....can the files be recovered? or have i lost ALL my work?
  • rrrachrr Mar 25, 2009
    my 2 month old flash drive was fully operating one minute and then i SAFELY removed it from my computer and plugged it into another - no lights lit up.....
    i have tried it in 3 other computers - both PC and MAC operating systems-but still nothing...
    have i lost all my data?
    can the information be salvaged?????
  • 416 Answers
Since you say you have tried on several computers, i am afraid to say your USB is dead, if you have warranty you should take it to the shop you bought it from.
Posted on Mar 08, 2009
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
May 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I bought 2 Sandisk Cruiser 4GB and when I plugged both of them into the port that is designated on the computer neither one does anything. The red right flickers but keeps going out. I wiggle it and the...
best to buy a usb muti slot
some usb such as flash devise do have this prob
try diffrent slot ,
try plug usb leave in and restart computer
when back in windows it should at least say found new hardware
Aug 31, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
San Disk Micro Cruzer 4GB
Try plugging it in to a different USB port on your computer. Make sure the connecter on the Cruzer is clean and there's no dust inside.
Also, try plugging it in on a different computer.
If none of these work,
I'm afraid it's a hardware problem and there's nothing that can be done about that.
Hope I helped!
Tom
Jun 20, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My flash drive wont do anything when i plug it to my computer.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
May 28, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have a 4gb cruzer flash drive and its not working
Okay. Try putting it in on the back of your computer and tell me if it lights up at all, even if it flashes once.
Ryan Frame
Creative Energy Associates Technical Center
Head Technician
Mar 16, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
USB device not recognized
corruption.
not fixable.
device can not tell os what it is. that is the most basic of functions.
without id, it can not set configuration needed to access data.
probably already lost data anyway.
replace is about the only option.
sorry for the news
good luck
mark
Dec 22, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
Cruzer micro 4GB, unreadable in USB ports
sounds like your USB connector of the flash drive is damaged. Could be a loose/broken solder joint, or one of the pins on the USB connector could be damaged.
If it was my drive, I would open the case, solder a new connector on the board and backup the files.
Nov 09, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
412 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
