You need a tech, or a new machine. The fuser is the heater section nearest the exit of machine - where they are always located. Your error message indicates a blown fuse, or lamp, or thermistor. The code can only be reset in service mode after the problem is fixed.
While taking test nr 6 I have noticed a colors displacement which sometimes is larger, sometimes is...
(More)
While taking test nr 6 I have noticed a colors displacement which sometimes is larger, sometimes is narrower, thus its dimensions are not constant.
Among the solutions I have resorted to were:
- ITB (which I cleaned);
- changed the reader unit afterwards;
- checked the mechaism responsible for the drums unit rotation.
None of the above solutions worked.
I would be extremely grateful for any hint or advice.
We have an old Konica 2330 copier system that is giving us a code 36-01. We are the Elks, so this...
(More)
We have an old Konica 2330 copier system that is giving us a code 36-01. We are the Elks, so this was donated to us, and we would like to repair it if possible and monetarily feasible. Please help.
error code 05701 on Oce 9600 The machine says optimizing and after churning away prints out a black...
(More)
error code 05701 on Oce 9600 The machine says optimizing and after churning away prints out a black copy
