Question about Honeywell Programmable Thermostat Heater
Upstairs honeywell thermostat went out on 3/7 [no display]
There are 2 furnaces [ downsstairs electric] upstairs is propane. Called local heating and air 24 hr. service. The service guy looked at upstairs furnace [Amana] and said that the transformer was burned out. He said the system was desiged to be dual heat but had been incorrectly installed.
He said the thermostat should have had a fuse in the system to keep it from burning out but did not, hence the problem.
He said he did not have the proper replacement reformer with him and that the job was beyond his skill level to repair. He called his boss who tried to talk him thru the repair process and concurred the problem was the burned out transformer. His boss came to do the job and brought a transformer with a fuse. He installed the transformer. We went outside to look at the 2 heatpumps. He said the 'pin' was set to year round defrost and should not be set this way and had not been installed properly for a dual heat system. He asked to look at the wiring in the crawl space. He said it was wired incorresctly and installed by someone who didn't know what they were doing. He told me I needed a honeywell vision pro 8000 thermostat so that the system would work properly and that this would cost $589.00 including the vision pro 8000 and labor, that they would have to schedule during regular work hours and that this cost would be in addition to the 299.00 bill for the transformer change out they had just performed. He further informed me that I now only had air conditioning with no heat until he installed the vision pro 8000. I confronted this;saying " so you've set this up so i have to buy the vp 8000 thermostat" and said i had to have both heat and air conditioning from the repair that day. He went back upstairs to the furnace and changed the wiring. He told me the system/ upstairs thermostat would now work for air conditioning only and if we needed heat we would have to run the upstairs system on emergency heat. He also added I needed to to perchase and schedule the vision pro installation within 30 days or lose the 589.00 price... .
    Novelist:
  • 189 Answers
FIRE THIS GUY!!!!
You have two systems.
These two systems should be wired totally independent of one another. I have the Pro series t/stat in my house. I love it.... I am a retired contractor I get stuff at cost. I paid about $130 for that t/stat. I understand he is in business to make money. But he should be fair enough that in the future you would want to call him back, Or even give him a nice referral. Alol this guy wants is your money. If the first guy admitted thatbhe did not have the expertice. He shouldn't be paid the experts price.
Call your city or county building inspectors office. Tell them that you would like a list of 4 or 5 reputable heating contractors in your area.
$275 should be fair for the nice t/stat and a fused transformer. Although a cheap t/stat would be fine.
Plus 75 bucks to pull upthe driveway. 60 -90 bucks labor to staighten things out. You should not have to pay for the romantic weekend away for the contractor and his wife.
GOOD LUCK!
Posted on Mar 08, 2009
How do I reset the temp my heat pump switches from electric to gas. It runs much more economically on electri than on propane. The thermostat is a Honeywell th8000. Code 350 setting I believe. Thanks
Heatpumps are more complex than an AC unit. Yes, there is a difference between a heatpump and an air conditioner. Where the real difference lies is out side in the condenser unit. There's a defrost board out in the unit, and depending on the brand and model, one of the wires will need to be changed so that the gas furnace will not come on. The problem with this, heatpumps use the heat that is available from the outdoors and transfers it to indoor. When the temps outside drop below 50 degrees, there's not enough latent heat to transfer, thus calling the propane furnace to operate. Without the addition of the furnace, you will not be able to heat the area properly. The only way to remedy this, is to remove the propane furnace and replace it with an electric airhandler with a heat strip for "emergency heat". The emergency heat term is used when the temps drop below the temps I mentioned above and calls for the heat strips to come on.
Feb 03, 2017 | Honeywell Heating & Cooling
How can I connect an Intertherm furnace with a heat pump to a new Honeywell thermostat?
Ensure that that thermostat is for a heat pump and has connections for the emergency heat strips.
Feb 02, 2016 | Heating & Cooling
Trane xv95 converted to propane is on system lockout
worth checking over heat temp sensors (klixon ) sensors can cause heater to go into a cool down purge Through an open circuit heat exchanger (Klixon ) temp sensor Ive seen before good luck
Nov 25, 2017 | Honeywell Electronic Programmable...
I have 2 Thermostat's in my home. My heat works well upstairs but not downstairs. My thermostat downstairs won't come on but I unhooked the thermostat from downstairs and tried it upstairs and it worked...
Hi, sounds like you determined the problem is not with the thermostat. That leaves the furnace that serves downstairs. What type heating system do you have?
Jan 13, 2010 | Honeywell Programmable Thermostat Heater
Honeywell T8011r does not have anything on display - does not appear circuit breaker is thrown - could it be wire disconnected at the plate or is there a fuse inside the unit?
Check to see if you have power at the furnace. You thermostat is powered by 24vac coming from the furnace. You should have power on the "R" terminal.
Oct 05, 2009 | Honeywell Electronic Programmable...
Heating blowing coo air downstairs and warm upstairs?
Some of this depends on where the air handler/furnace is located. Most often in two story houses, it's in the attic upstairs, or in a closet upstairs. A duct routes air from the furnace to the downstairs supply duct, so it is a distance from the air handler.
When the unit first initiates a heating cycle, that duct is going to be full of cool air, and the duct itself will be cool. So the furnace has to run long enough to push the cool air out, as well as warm the duct up, before your going to feel warm air at the registers downstairs.
Keep in mind, heat rises. And, your thermostat only monitors the immediate area where it's located. In your case, upstairs.
Two story houses are problematic because of this. And one way around it is to have a damper system installed that distributes the air upstairs or downstairs based on a thermostat located in those spaces. There would be 2 dampers, and 2 thermostats (one upstairs, one downstairs). Each stat would control a damper, and the call for heat or cooling.
Let me know if you would like to consider a system like this, and I can point you to components to use. I've put several system like this in.
Jan 26, 2009 | Kitchen Appliances - Others
High Electrical bill - Appears to be heatpump problem.
Sound like there are running on emergency heat which is elrctric.Have the system checked out buy a local heating and cooling company. Have they checked the filter and changed them.
Jan 14, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
886 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
