Question about Kenmore 24032\24036 Top Load Washer
Kenmore 70 series top loader - wouldn't drain & spin
Everything works well (water fill & washing) until drain cycle begins.
I can hear the switch click, but everything stops right before the drain & spinning cycle.
Is this simple enough for me to take care of ?
Thanks in advance...!
Jason from L.A.
  • Anonymous Mar 11, 2009
    I have the same problem with the 80 series top loader Does this
    have to do with the lid switch?
  • 107 Answers
The lid switch is the only thing affecting this part of the cycle. The new switch comes with the new plug (under console ) and the harness that goes to the switch. The console will flip up and the cabinet will pull forward after removing 2 brass looking clips. After that it's right there under the right side of the upper cabinet.
Posted on Mar 14, 2009
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Hello, Have a Kenmore series 70 (capcity plus).
Note after reading a bunch of information. I went home and removed the hose from the Level Switch and "clean it", if you will and re-attached. Started a load, and bingo bango bongo, it work. Thanks for the insight.
Nov 30, 2009 | Kenmore 22422 Top Load Washer
Washing machine will fill with water, but won't articulate
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
I assume that you mean after filling, it won't begin the agitate cycle.
If you can hear the motor but the agitator won't move, it could be the "motor coupling". (See the motor section of the Sears site. This coupling is a fail safe between the motor and transmission. If the plastic prongs break, or the rubber center piece wears out, the transmission cannot agitate the washer.
If you can't hear the motor, it could be a timer problem.
Try to manually move the timer to a spin position and see if the motor / transmission move. If they do, it is most likely a timer.
Sep 26, 2009 | Kenmore Washing Machines
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/
Sep 01, 2009 | Kenmore Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
146 people viewed this question
Sal De
 Brian Main
Brian Main
