Question about Kenmore 24 in. 16032 Built-in Dishwasher
I went into the advanced programming settings on the Kenmore Elite 16303 (630.16303403) and need to reset some settings. Does anyone have that info or a repair/service manual?
3 Suggested Answers
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
  • 3 Answers
SOURCE: my kenmore elite model 630 (bosch) dishwasher will
Our same dishwasher is 2 years old and also not draining anymore either. No solution yet. Plan to call sears maintenance. A neighbor suggested fixing the solenoid.
Posted on May 11, 2010
I have a sears kenmore elite slide in range model number 790.46613500 that has a f13 err can anyone help with this
Unfortunately, the F13 error indicates that the oven control has failed. First unplug your range and wait 30 seconds or more to reset the code.
If the error recurs, this part will need to be replaced. See http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Range-Parts/Model-79046613500/0583/0124160/R0507023/00001?blt=06&prst=0&shdMod=79046613500 for the parts list.
I'm not exactly sure if your unit needs part 97 or 97A.
I hope this helps.
Dec 08, 2012 | Kenmore Elite Sears & Other Brands...
Kenmore elite dishwasher mdl 665.16919001 all lighs out, won't come ont
try a simple step to reset unit unplug and then plug back in
May 26, 2012 | Kenmore Dishwashers
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Dryer Buttons Don't Work
Try unplugging it for 30 seconds or so. This may reset the board. This happens on many appliances, especially if the power went out. Hope this does the trick.
Aug 30, 2009 | Kenmore Dryers
Kenmore Elite HE3t, door is locked and will not open
You may have to use the manual release to open your door. The following link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Your washer may have experienced a momentary program glitch which can cause interruptions in operation. Sometimes resetting the Central Control Unit (CCU) will coreect these problems. To reset, you have to unplug the washer for AT LEAST 30 minutes. If the problem reoccurs after a CCU reset, then you have a legitimate problem. Take note of any symptoms and/or error codes that may be displayed. If these procedures do not correct your problem, please let me know. I hope this helps you.
Jul 27, 2009 | Kenmore Elite 45986 Front Load Washer
Diagnostics on Kenmore Elite Dryer
You will need to contact Whirlpool. They are the manufacturer for Kenmore. They may have the the info for that particular code. I'm not familiar with it either. But by chance, have you checked the dryer cord and that the breaker hasn't tripped? Unless you have physically reset the breaker, it's hard to tell sometimes if it is tripped. Completely turn it to off and then back to on. Also, if the door switch is bad, the unit will not run and it can go bad during a cycle as well.
Apr 10, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3t- suds-
advance machine to drain/spin cyce to remove the water.if it doenst drain and just "humms". try removing the lower access panel. just behind it youll find the pump assy unscrew the face and empty the contents (probably lint, baby bock, assorted stuff from pockets)be prpared though the hose above is FILLED with water. Make sure your using HE detergent!!!!!!!!!!
Mar 08, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE5T Steam - Won't Start, No error codes
I had the same problem, but due to the great info on the internet, I found the problem and solution.  I have been able to temporarily fix it until I can get someone out to repair the plunger.  The site below has the details.  http://applianceblog.com/forums/view_topic.php?id=730&forum_id=2&jump_to=4559
Karen
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 24 in. 16032 Built-in Dishwasher Logo
91 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
