Question about Brother Office Equipment & Supplies
Printer doesnt come out of sleep mode (Brother MFC7420)
Hi there
i recently purchased a brother MFC7420 printer. The printer i connected directly to my PC and is set up perfectly as i can print, scan, fax etc etc. However, the minute i leave the printer idle for while it goes into sleep mode...then when i try and send another print job to it...it doesnt wake up....i have to turn it off and on to get it to come out of sleep mode. Have asked brother ..they said to upgrade the firmware....which i tried to do but it says i have the latest firmware...
please advise...
thanks
nick
No when I sent documents while my computer is awake to the MFC-8600 the THE MFC-8600 is a sleep, it will not print. I have to unplug the MFC-8600 and then plug it in to get it to print, my computer is awake all the time, the brother feature won’t allow you to keep it awake. It only allow to stay awake 99 minutes
5 Suggested Answers
  • 186 Answers
SOURCE: Brother 1270E won't receive faxes
make sure the phone line is plugged into the port marked "line" not "phone"
Posted on Jun 21, 2007
  • 22 Answers
SOURCE: "Receiving Sleep" on Brother Fax 4100
The sleep mode is only a power save mode. You may not have the machine in the correct fax receive mode. If the machine is on a line by itself it needs to be set to fax only, if line is shared with a telephone it needs to be in fax/telephone, if you share the machine with an answering machine it needs to be in TAD mode, and so forth. Each time you press the MODE key it will change the receive mode. Most people hit this key by mistake and change the MODE and the unit will not pick up calls. Press the MODE key until you are in the correct mode. To make sure the machine will print, press reports and then the 1, this will print a help list. If the help list prints you know that the machine works. Then check to make sure the machine is in the correct fax receive mode.
Posted on Oct 04, 2007
checkitright
  • 1362 Answers
SOURCE: Print fax journal from previous date on Brother MFC-3820CN
although it may have a time retreival function it will not store 2mo of faxes !! most likely only a few days depending on the amount of fax you receive
Posted on Dec 10, 2007
Logjam
  • 159 Answers
SOURCE: sleeping will not awake
1st check to see if there is a "dial tone"by picking up the handset. Then try to send a fax by using the handset.
Posted on Jan 01, 2008
SOURCE: Error Message: Scan Unable A6
I did not. The solution is a new scanner head which is almost as much as a new machine which I bought at Costco. I'm using my old machine for printing until it wears out, the new one for copying and faxing.
Norm
Posted on Aug 16, 2008
How to get out of sleep mode permantly
I had to re-install the drivers for my HP printer. It should not have helped but it did. Somehow it was able to clear the buffer, etc. to get it working again.
Apr 16, 2015 | Brother IntelliFax 4100e Business-Class...
Receving large unwanted faxes
Please rate my solution. Hope this resolves the problem.
According to the manual one of the things that can cause this is if the data cable (USB) was disconnected from the printer while the job is printing. Press the Cancel button on the printer, that should clear the memory. Also make sure you don't have print jobs in the queue if the printer is connected to a pc.
Manual can be downloaded at:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_7420_7820N_EN_1156.PDF
Aug 28, 2009 | Brother IntelliFax-2820 Laser Fax
Our Brother Fax Machine 2820 stays in sleep mode. How do we get it out of sleep mode?
Machine goes into sleep mode when not being used When it recieves or you copy something it will come out of sleep mode If its not recieving then you need to check your recieving settings
Jun 10, 2009 | Brother IntelliFax-2820 Laser Fax
Our fax doesnt want to recieve it sais sleep mode
have you tried to turn it of then on to reboot the fax machine! if that will not work you may have a bad main board
Jan 10, 2009 | Brother IntelliFAX 2800 Laser Fax
Fax machine sleep mode
have you tried to unplug the machine from the wall and then plug it back in this reboots the machine
Dec 23, 2008 | Brother IntelliFAX 2800 Laser Fax
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Disable sleep mode
To change the sleep mode: Press Menu Numbers 1, 8. From your key pad select the amount of time before the fax goes to sleep. 0 - 99 Press Set Press Stop/Exit You can find the user manual here for the future if you would like: http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000082/FAX4100_US_UG_0.pdf Hope that helps... Lbcoaster
Jun 27, 2008 | Brother IntelliFAX 4100 Laser Fax
Sleep Mode showing on the screen
SLEEP MODE MEANS NOTHING UNLESS YOUR USING IT WITH A PRINTER IT IS SAYING SLEEP BECUSE IT IS WAITING FOR A PRINT JOB IF YIOU ARE NOT REC. CHECK THE MODE KEY AND AMKE SURE IT IS SET TO FAX ONLY
Oct 11, 2007 | Brother IntelliFAX 4100 Laser Fax
1,515 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
