Question about HP PhotoSmart 7550 InkJet Printer
I have an HP Photosmart 7550 printer. How can I
I have an HP Photosmart 7550 printer. How can I check to see how much ink is left in each of the cartridges?
  • Anonymous Mar 12, 2014
    connect photosmart 7550 to mac mini
    Genius:
  • 1,550 Answers
First plug the printer to the computer .
Click on the "Start" menu button which is located on bottom left hand corner of your screen.
Click on the control panel icon.
Look for the printer/fax icon in the control panel window. Double click on the printer icon.
Find the icon for your printer in the opened window and right click on the icon. Now click on the "Preferences" option.
Look for the menu box pop up with tabs near the top of the box. Click on the "Services" tab.
Click on "Service this device." You will find the button on the Services menu that you just activated.
Click on the estimated ink level tab and a graphic will appear indicating how much ink is left in the cartridge.
Posted on Mar 08, 2009
I want to connect my Dell inspiron 1525 laptop (basic vista)to HP 7550 printer. What type of usb cord do I need, and are drivers available online?
Assuming this is a Photosmart 7550 printer and not the 7550 Plotter, this is what you will need for connectivity. To connect printer to PC, you will need a standard USB A/B cable... one side is a male A connector and the other one a male B connector. As far as the drivers are concerned, you will not need to download any. Vista already has a compatible driver for your HP Photosmart 7550. HP recommends selecting the drivers for the Deskjet 5550 when installing your Photosmart 7550.
Sep 26, 2009 | Dell Inspiron 1525 Laptop
Hp photosmart 7550 says carriage is stuck
print cartrigeis cradle is stuck clear jam then press ok in hp photosmart 7550.
Apr 04, 2009 | HP PhotoSmart 7550 InkJet Printer
Cartridge failed
I just purchased new hp cartidges and I still get error massage cartidge #57 needs to be replaced.
The line on the printing at the end or far right of the sentence (like the last 3 or 4 words are faded)
this is for hp 7550 photosmart
Oct 29, 2008 | HP PhotoSmart 7350 InkJet Printer
Hp 7550 ink jet printer printing uneven
My first guess is that it is a cartridge issue, due to these printers having the print head as part of the cartridge, there is nothing else, it makes the whole cartridge the only printing item. Ensure the carts are not old (exp date) and that they are HP, With that all understood as I now see that you must due to owning it for 6 years, then you could try to clean the contacts on machine's "cartridge holder" and give that a clean too while your at it cause it may be the problem here (see below)
If a inkjet printer lasts 3 years you would be doing well, and you've had 6. Exceptional!
HP Photosmart printers may print images with white lines or single color streaks. This issue can be caused by ink that has dried in the ink nozzles or by debris that is blocking the ink nozzles. The ink cartridges and the and printer cradle should be cleaned. Clean the ink cartridges with the ink cartridge cleaning utility in the HP Printer Toolbox. Also, clean the ink cartridges and the print cradle manually.
Cleaning the ink cartridge cradle
  1. Assume an eye level position with the HP Photosmart printer.
  2. Locate the ink cartridge cradle.
  3. Using clean, moistened swabs, wipe the underside of each wall of the carriage where fibers may collect and come in contact with the paper. Repeat until no ink residue is seen on a clean swab.
  4. Reconnect power cord when finished cleaning.
Manually cleaning the ink cartridges
  1. Turn the printer on and lift the top cover.
  2. After the ink cartridges have moved to the center of the printer, unplug the power cord from the back of the printer.
  3. Remove the ink cartridges and place them wide side down on a piece of paper.
  4. Prepare a clean, foam-rubber swab or a lint-free cloth slightly dampened with water.
  5. Locate the copper-colored circuitry strip on the back of each cartridge.
  6. Clean the copper-colored strip with the dampened swab or cloth. Do not wipe the nozzle end of the cartridge or touch the nozzle plate.
  7. Clean the carriage contacts on the back wall of the ink cartridge carriage with a damp foam-rubber swab or lint-free cloth. Use a dry foam-rubber swab or a lint-free cloth to remove moisture from the contacts.
Cleaning the ink cartridges with the HP Printer Toolbox
  1. Click Start .
  2. Click Settings .
  3. Click Printers .
  4. Right-click the icon of the printer in use.
  5. Click Properties .
  6. Click the Services tab.
  7. Click Open the HP Photosmart Toolbox or Service this device.
  8. Click the Device Services tab. This tab does not display in Windows XP; proceed to the next step.
  9. Click Clean the Print Cartridges .
  10. Follow the onscreen prompts.
If you've got this far then I should tell you that these days, Printers aren't worth fixing, one just replaces them with new
Dec 17, 2007 | HP PhotoSmart 7550 InkJet Printer
Hp photosmart 7350
The 7550 takes three cartridges 56(black) 57(tri-color) and 58 (photo).
If you replace the 57 but the 58 is also empty and still in its slot - you get green tinted photos.
So, check to see if you have the 58 photo cartridge still installed, and if it is out of ink. If so - remove the 58 - the printer will then default to "reserve mode" and you'll get better color.
Dec 16, 2007 | HP PhotoSmart 7350 InkJet Printer
HP PhotoSmart 7550 InkJet Printer Logo
234 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
