Question about Electrolux Refrigerators
Problem with Electrolux ERE 3500 X
Eectrolux EUA 3500 X problem is that the cupboard is iset inside the cupboard
3 Suggested Answers
SOURCE: Fridge prolems Electrolux ERE 3500
No it is a power problem.
Posted on Jun 24, 2008
Disconnect the power cord (or switched power off) and wait an hour or two until compressor has cooled. When you now switch the power on, the clicking is heard only once and compressor starts (weak noice and vibration noticed). When compressor gets warmed, the compressor will stop and clicking starts again (clicking comes from electric circuits when compressor is switched off and on repeatedly, but it will not start because it has stucked - this is typical fault in old compressors said maintenance expert to me). Buy a new fridge.
Posted on Jun 16, 2009
How to change belt electrolux epic 3500 sr
See my other posts for the directions for change. Hope this helps!
Jun 19, 2014 | Electrolux Epic 3500 Vacuum
Electrolux ere 3500 problem
Ok you have a faulty relay on the compressor very easily fixed, tell your repair man whats wrong then they cant rip you off.
Nov 16, 2013 | Refrigerators
I have an Electrolux Epci 3500 Sr upright vacuum cleaner ... 100 percent positive switch is shot and one of the wires inside is fried but before buying a new handle assembly online how do I check the...
The switch is replaceable, so you don't need to replace the complete handle assembly. I've got a 3500 that I replaced the switch on and it works great now. You can get a new switch at the local Aerus Electrolux store. To find the nearest store, just follow the directions on the below site.
I do recommend letting the service tech do the replacement.
http://www.aerushome.com/storelocator/
Nov 26, 2010 | Electrolux Epic 3500 Vacuum
Does anyone know how to get the bottom off the electrolux Epic 3500 SR I need to check the beater brush? Thanks Jim
Actually the top comes off from the bottom base. Remove the underside screws, flip the machine over and gently remove the gray cover from the motor and brush assembly. Once inside, remove two more screws holding down the brush cover which is also part of the tunnel. It will reveal the brush, belt, and much dirt so be prepared.
Dec 06, 2009 | Electrolux Epic 3500 Vacuum
How do you replace short suction hose inside casing
This portion rarely needs replacing. It is designed to pull easily away from the brush side in case of blockage and then may need to "unscrew" use only the identical component form an AERUS Electrolux dealer. This should be accomplished without dismantling the head.
If there is evidence of glue or contact cement type adhesive on the bag side, you may need to tear apart and unravel with pliers
Nov 04, 2009 | Electrolux Epic 3500 Vacuum
How to check the belt?
I have listed a link to the manual for your model and a link to the replacement belt you need. Hope it helps!
Manual
Electrolux Epic 3500 Replacement Belt
Oct 29, 2009 | Electrolux Epic 3500 Vacuum
My Electrolux series 3500 SR won't power on.
Most likely the cord has a broken wire you can't see (near the plug) or; the switch is bad.
Either is a fairly simple repair.
Charlie
Aug 21, 2009 | Electrolux Epic 3500 Vacuum
Place for washing mashine
You do not need airflow for the washing machine only the dryer.
And yes you can put it inside of a cupboard or cabinetry,as long as you have water supply, and waste water discharge access
Jan 19, 2009 | Washing Machines
Mar 29, 2008 | Refrigerators
Refrigerators Logo
563 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
