Question about Sony VAIO PCG-K25 Notebook
Hot do i open a vio laptop to swap out the cd/dvd rom drive
Can you help me
    Problem Solver:
  • 13 Answers
If u post the problem clearly v can help u for sure
Posted on Mar 08, 2009
My satellite won't recognize a cd/dvd drive when I open up my computer there isn't a drive at all how can I fix this
If you don't have a cd/dvd rom drive installed on your laptop then of course your laptop would not reconize a cd/dvd rom. Is you laptop a Netbook, usually netbook does not come with a cd/dvd drive. To solve this case, you will need to buy an external cd/dvd drive and hook it up via USB.
Jan 18, 2011 | Computers & Internet
Tip
Upgrade CD/DVD ROM to CD-RW/DVD ROM
I just replaced my original CD/DVD ROM with a Toshiba SD-R2512 CD-RW/DVD ROM in my 1805-S253 running Windows ME. I used "Roxio Easy CD Creator" for writing to CD's. Everything was "plug'n'play" except the bezel that came with the new drive had to be swapped out. Windows ME recognized the new drive immediately and I didn't have to load any new drivers. This upgrade will probably work on other 1800 or 1805 Satellite series machines.
on Apr 13, 2008 | Toshiba Satellite 1805-S253 Notebook
My laptop is not detecting cd in it wht to do???????????
connect an external cd/dvd drive & see if its working or not. If yes, then you need to replace cd/dvd drive of your laptop.
Jun 16, 2010 | Acer Extensa 4620 Notebook
DVD drive not reading\g any CD or DVD
this problem may be due to power as wella s the rom lens is weak just try with cd cleaner cd and also swap the power cable of the dvd rom also.
i hope this will help you dont forget to rate please.
Mar 24, 2010 | Computers & Internet
DVD ROM MISSING FROM PC USING NERO/CD BURNER XP ETC.
dvd rom drive only writes cd not dvd dvd can be written by dvdRAM
Jul 07, 2009 | Computers & Internet
My dvd/cd rom is not opening, checked hardware, not even listed
just check your dvd writer is open or not open because the some time not open the dvd driver then not detect
fist of all remove the dvd rom and reinstall because the some time remove the dvd drive and after reboot the laptop and check ..............ok
Apr 08, 2009 | Computers & Internet
Need help
hi! All of you
thish the cd-rom drive LENCE problem
if you Need to you change completed drive..
ok
have great day
Nov 09, 2008 | HP Pavilion dv4000 Notebook
Cd rom drive
Hi
Please use the Cd/Dvd Drive with the following specification:
CD-ROM/DVD-ROM/Disk drive
8X max DVD+/-RW Drive with DVD+R double layer write capability
Or
16X DVD-ROM drive, 16X/10X/40X CD-RW drive
Regards
ELLIN
Sep 20, 2008 | Dell Dimension 8200 PC Desktop
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
Emachines w3507 DVD Rom Broken
There may be a hole but it will be under the lip of the door, kind of impossible to get to. You may have to remove the drive from the emachine and unscrew it and open it manually with a small screwdriver. I regularly buy and repair or use parts from used samsung drives which is what emachines uses almost exclusively. The only upside to this is that once open, you can swap the faceplates and doors onto newer drives. If the led light is not in the middle then you can swap out the little plug in circuit too.
Nov 12, 2007 | E-Machines emachines (emachinees) CD-ROM...
Sony VAIO PCG-K25 Notebook Logo
41 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
