Question about Kenmore Elite 45986 Front Load Washer
My kenmore oasis he is flashing f51 and it wont drain. help!!!!
Any ideas?
    Genius:
  • 1,550 Answers
The F51 fault code on these types of washers indicates that the machine control board detects an RPS (Rotor Position Sensor) failure. This sensor is on the motor at the bottom of the washer.
Here is the troubleshooting for the F51 fault code:
  • Do not overload the washer. Overloading can cause this fault code.
  • Check underneath the washer for any clothes or toys that could be under the washer and obstructing the motor from turning freely. This can occur because there is not a cover on the bottom of the Washer.
  • Using too little water by choosing the wrong cycle for the type of load being washed can cause this fault code.
  • Make sure that your drain hose is properly installed per your installation instructions. Siphoning of fill water out of the washer can cause tub resistance and will result in this fault code.
  • Lift the lid and reach in and make sure that the basket turns freely. If not, you could have garments stuck between the two baskets or a problem with the basket hub. Any abnormal resistance to tub movement can cause this fault.
  • Unplug the washer. Make sure that both the Control Board Connectors P5 (Motor Wires, red, blue and yellow), and the P10 (RPM Sensor Wires, 7 brown wires) are securely plugged into the Control Board.
  • Remove the (P5) Motor Connector from the Control Board and take a resistance reading between the 3 combinations of motor wires (red/blue, red/yellow and blue/yellow). It should read around 32 ohms on the Motor Windings between any of the 3 pins on the harness. NOTE: If you do not get the proper resistance reading on the motor harness at the board, check the reading at the motor end. If you get a good reading replace the upper or Lower Harness whichever is defective. If the reading is still bad when checked directly off of the motor, then you will need to replace the motor. (See notes below for motor access.)
  • Unplug the P10 connector and take a resistance reading between the two outside pins (1 and 7). It should read between 600 and 21.6K ohms. *NOTE: (If it reads open you will need to pull the Rotor and Stator so you can check it right at the RPS Sensor. If it reads good at the sensor replace the Lower, or Upper Harness whichever is open).
  • To access the motor and RPS sensor, lean the washer back against the wall. Secure the washer with blocks if needed. Remove the rotor (1-bolt), and the stator (4-bolts). When you pull the rotor off, check to make sure that the thin plastic beads that run between each magnet on the rotor is intact and in place. This could cause an F51 code as it will no longer separate the poles of the magnet for the sensor to read them properly.
  • Check your wiring connections on the motor and the RPS sensor. Unplug and then plug the wiring harness connections back in on these components 5 or 6 times. This will normally scrape through any possible corrosion or deposits on the connections. Tug slightly on the connections when they are inserted for the final time to make sure that they are secure.
  • Reassemble the washer .
Hope this helps .
Posted on Mar 08, 2009
2 Suggested Answers
  • 572 Answers
SOURCE: In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Posted on Feb 06, 2010
F51 error
Hello, the F51 code is a motor rotor position sensor failure. It's best to call in the warranty service as there is a bunch of tests that need to be run to determine if it's the sensor or control board. If the tech wasn't any help, contact the store for a replacement.
Thanks
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis top load model 580 error F51
There is no reason or condition that will requir having to doing that for correct operation. That indicates the board as being defective. Just asking if your water is draining correctly? When you start cycle, after it finnishes loading the water, can you get it to drain at all. If you can, the board is the problem.
Sep 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis HE is flashing a code
sound like the rps kit is required and is time comsuming will have to remove the back and console includes harness and new rps sensor and inset for sensor if not sure if you can perform it would be better to call service tech....must remove from the bottom of the motor location(main drive d/c motor)
Aug 19, 2009 | Kenmore Washing Machines
Stops in middle of wash cycle and F51 codes keeps flashing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the Bad Board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
Mar 20, 2009 | Kenmore Elite 45986 Front Load Washer
Dryer f51 error
Nov 04, 2007 | Kenmore 67082 Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
370 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
