Question about Onkyo TX-SV727 Receiver
Every time I turn on my Onkyo receiver it goes in to protect mode.
    Novelist:
  • 98 Answers
Please check your speaker cables. Make sure that all of them are seated properly, none is touching each other or to the body of receiver.
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny frayed speaker cable touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough to activate and it could blow a few trasistors in the power output circuit.
Please take out all the speaker cables, unplug your receiver from the mains and try to restart without any cables plugged. If it powers on then you are lucky.
If not and the receiver still goes into protect mode or wont turn on then it possible that there are bad connections on the main board or have some blown transistors. How old is your system? if its still under warranty then you should contact Onkyo immidiately.
Let me know if I can be of any further help. Please do rate this solution and thanks for using FixYa!
Posted on Mar 09, 2009
SOURCE: Onkyo tx-sr800 PROTECT mode
Hold video1 and press speakers A button, it will say "clear" If the message protect appears again, then its service time.
Posted on Sep 05, 2007
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Posted on Jun 11, 2008
Gurudristi
  • 98 Answers
SOURCE: I just hooked up my old Onkyo TX-8511 receiver to
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Rewire if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Otherwise, do your bose speakers play out load on other systems?
  • 4234 Answers
SOURCE: HK AVR-247 protect mode
This is an indication of an internal problem. Typically this is shorted output transistors. Expect a parts cost in the $25-$40 range for this repair.
Dan
Posted on Apr 06, 2010
barbu51
  • 566 Answers
SOURCE: my onkyo receiver (tx8511) keeps going to protect
Hi there
To answer your question;
Your amplifier goes into protect mode when it detects a fault or condition that could damage the speakers and/or the output stage.
Often caused by shorted outputs.
Although this does`nt tell you much on how to fix this problem, the best help i can give you at this point is to tell you to have it looked at by a repair shop.
Hope this help good luck
Posted on Apr 18, 2010
My Onkyo tx-ds595 reciever turns on but after 5 seconds it goes into protect mode. I really would like to fix this porblem myself. Please help.
This can be caused by shorted speakers or speaker wiring, disconnect all the speakers and see if the problem goes away.
Mar 04, 2011 | Onkyo Audio Players & Recorders
My onkyo receiver (tx8511) keeps going to protect mode when turned on. I have changed the fuse, but dont see any way to overide this mode. Is there another fuse or some way to turn off protect mode
Hi there
Apr 18, 2010 | Onkyo Audio Players & Recorders
Hi, after i turn the power on and then press the stand-by button, it clicks off to stand-by mode instantly. This is an Onkyo TX-SR500
This indicates that the system is going into protect mode. First disconnect all speaker wires (with the power cable disconnected). Then turn the unit on and see if it sill shuts aff ofter a few seconds. If it does not, then you have a problem with the speakers or speaker wires. inspect the wires at both ends for frayed strands that may touch. If that all lookd good, plu the speakers in, one at a time, until the problem reappears. Be sure to turn the sytem off before plugging in any speaker just to prevent any accidental short which could be catastrophic. If the system goes into protect mode with all speakers disconnected, you probably have a shorted output transistor.
Apr 05, 2010 | Onkyo TX-SR500 Receiver
My onkyo displays "protected" when i turn it on and goes into standby
there is an internal shorting inside the amp that puts the amp in protect mode also check if the amp comes on after disconnecting the speakers
Oct 13, 2009 | Onkyo TX-SV343 Receiver
Turn on power and the amp goes to protect mode
disconnect the speakers and see if it does the same thing.
if it does not shut down,check that the speaker wires are not touching on the back of the speakers.
many times,people run over the wires with a vacuum or similar and a short results,or bump the speaker.most people have the leads way too long,and even if one strand touches,it will shut down the amp.
if it still shutting off,there is an internal problem.
the best place to go with an onkyo is an authorized depot.
they are tricky to work on.
i did onkyo warranty for 7 years.
Sep 06, 2009 | Onkyo TX-DS939 Receiver
Onkyo av amp goes to protect mode
There's a fre service manual here, you need to join tte site (free)
Onkyo TX SV727 Manual AV Control Receiver HiFi Engine
Sep 06, 2017 | Onkyo TX-SV727 Receiver
I just hooked up my old Onkyo TX-8511 receiver to my bose speakers, which is also hooked up to a subwolfer. When I turn the volume up the system goes into protect mode. Any solutions.
Mar 08, 2009 | Onkyo TX-8511 Receiver
Onkyo TX-DS777 goes straight to protection mode
Hello.You have shorted audio outputs. One of your channels has shorted output transistors. If your unit uses output ICs then one of them is shorted. Both types ( individual transistors or ICs ) are located on the large finned heat sink. The parts are available from http:\\www.tritronicsinc.com. good luck
barneyluc
Oct 19, 2008 | Onkyo TX-DS777
Onkyo ts595 goes into protect mode with volume increase
Hold the VCR/DVR button in and press the ON/OFF Standby button. The display should briefly read CLEAR and then the unit switches off. If that clears protect mode, you'll need to redo the Audyssey and configuration setup as these will have been cleared by the reset.
Sep 27, 2017 | Onkyo TX-DS575 Receiver
Aug 28, 2007 | Onkyo TX-8511 Receiver
415 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
