Question about Garden
I have a Troy-Bilt prower washer that starts up but will stay on for more then 30 to 40 seconds. What could be the issue casing it to shut off?
  • 4090 Answers
SOURCE: pressure washer not working
sketchy info here....
Remove the hose and gun to see if water is flowing....
if it is that means there is no blockage in the hose or gun. When its connected if it runs at the same rate as without the hose and you have set it into pressure clean mode, then the pressure valve and seal have collapsed. Estimated repair cost is $200 and about $100 of that is labor. It is not a DIY unless you know your way around and have the right tools. Having it repaired professionally gives you 3 months warranty as well. Do it yourself and you could end up losing some of the small screws and other nylon components that tend to drop out and get lost when you open it up!
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Posted on Sep 13, 2009
Testimonial: "Very quick reply,very informative,very helpful. Thank you."
  • 174 Answers
SOURCE: Soap will not siphon on my Troy Bilt pressure
Are you using the soap on low pressure. This is the only way it will work
Posted on Sep 20, 2009
SOURCE: oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
Posted on Apr 18, 2010
SOURCE: Troy Bilt power washer 020293- Oil in air filter
that is incorrect. if the oil has been over filled, it will saturate the filter element by way of the crankcase breather tube. it is the small plastic pipe that connects to the bottom of the filter housing. check the oil level. these machines take very little oil. approx 20 oz. if overfilled, it will leak out filter.
Posted on Apr 28, 2010
SOURCE: troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Posted on Jun 08, 2010
I have a troy-bilt model 020296 power washer. what type of replacement spark plug does it take?
Tom, NGK BRP6ES ,Champion RN9YC,Torch F6RTC are replacement sparkplugs for Honda GCV 160 pressure washer engine. This info should be in your pressure washer engine manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.bsppwebtools.com/data/manuals/020296_0esAw.pdf
Troy Bilt 020296 Pressure Washer Relacement Parts
Spark plug cross reference
Jul 02, 2016 | Troy-Bilt Garden
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Troy bilt 2550 psi pressure washer My friend gave
Try this link. I think you'll find what you're looking for.
http://www.troybilt-gen-pw.com/owners_manual/
Nov 04, 2013 | Garden
Troybilt pressure washer
Check the oil level. Yours may have an oil sensor switch.
May 26, 2013 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
Troy built squall 210. Starts and runs for a few seconds. Decided to check the oil and gas poured out of the crank case. Im not talking a little. Im talking atleast a pint or two. Can some body explain...
You have a Troy Bilt motorcycle?
Crank case filled with gasolene indicates a carb problem ... typically, the float has a hole in it causing it to sink ... when this happens, the bloat valve can not turn off the flow of fuel and it runs into the combustion chamber, own past the rings into the crank case.
Many original Troy Bilt machines came with tank shut off valves, it is a good practice to turn this valve off when the equipment is not in use.
Thanks for your interest in FixYa.com
Mar 03, 2013 | Motorcycles
I have an older Troy-Bilt tiller (model & serial # unknown) that when I start it (manual pull) it runs for a second and then shuts off. I checked the spark plug, fuel line and inline filter, fuel, oil...
could be bad coil. does it stay running with choke on? or half on, if so its a gas problem. could be the main jet is plugged in the carb. Or water in the carb bowl. Remove the bowl nut and let some gas run out the put it back in and try it. just guessing as not much info to go on.
Apr 26, 2011 | Troy-Bilt Pony Garden Tiller
How do you prime a troy bilt 675 pressure washer
if you dont see a primer bulb then you must start it in choke mode after running out of fuel
May 31, 2010 | Garden
Troy bilt mower. starts but shuts off within seconds.
sounds like you have a primer bulb if you take the bolt that holds the float bowl off and take a tip cleaner that they use for welding tips and clean the holes out of the side and the top it should let the fuel in again that will save you a trip to a service repair shop
Nov 22, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
May 29, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
208 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
