Digital Research CD-RW Burner
Problem for Digital Research (D522452EU) CD-RW Burner
Nero Software Problem
By Melissa - usenet poster
Just bought and installed my first CD-RW (Digital Research model
DRCDRW481648). Also, installed the Nero Software which came with it
(Nero Burning and InCD among others). When I start Nero Burning, the
message "Scanning SCSI/IDE-Bus, Please Wait" appears, and that's as
far as I get. The computer shows no signs of the hard drive being
accessed or anything else happening. The computer locks up and I must
reboot. I've tried # but have trouble getting to their FAQ's
or technical support. I'm in way over my head and not even sure if I
should have installed the InCD software. It seems the only thing it's
used for is to format CD-RW's and that took me about 40 minutes each
using a 333 machine. My main use of this CD-RW is for making back-ups of
my hard drive. Any help would be appreciated.
George
Same Problem
Nov 13, 2008
-   I tried to install nero update 9.0.9.d, and about all i got was errors. I used the nero 9 cleaner, but there were several functions that were not installed. I have tried several ways to install nero 9. I think the trial download worked, but when I tried the "updates", there were problems. I have just about given up. -   jhenry1933
Best Solution
posted on Sep 13, 2008
Very Helpful)
bbsevergreen
Rank: Apprentice
Rating: 100%, 1 votes
Partial solution: do not simply uninstal by way of control panel. Go to Nero.com>support>downloads, find, download, and run the appropriate cleaning utility.
Was this helpful?
Yes
No
Solution #2
posted on Aug 02, 2007
Not Rated)
Phoebe
Rank: Apprentice
Rating: 0%, 0 votes
Graham,
My operating system is Windows 98. Also, I have no SCSI devices.
which unzipped to two files: the dll file you mentioned which was to be
installed in the Nero folder, and also NEROPIX.VXD which was to be
installed in
the Windows\System\IOSUBSYS folder. I did so and rebooted with no
change.
Then I opened in Safe Mode and the "Scanning SCSI/IDE.." message
appeared
for a couple of seconds and took me right to the wizard. I could
drag/drop
files, and the log would show burn started time and completion time.
Unfortunately, the CD-RW never spun up, so it never really burned.
The Nero website also lists a download to "...check if the WinASPI
driver
layer is installed correctly". I think I'll try that next.
George
Was this helpful?
Yes
No
Solution #3
Not Rated)
Luisa_K
Rank: Apprentice
Rating: 0%, 0 votes
Do you have any anti-virus program running in the background? If so,
disable that and try Nero.
At any rate, uninstall Nero and delete Ahead directory.
Install aspi 4.60 using ForceASPI from a link here:
Reboot.
Disable any background tasks such as anti-virus program.
Reinstall Nero.
Was this helpful?
Yes
No
Solution #4
Not Rated)
Cato
Rank: Apprentice
Rating: 0%, 0 votes
Which operating system is this?
Clearly your writer is installed correctly, and you would expect the version
of Nero *supplied with it* would work with the drive, no matter where
Digital Research sourced the drive. However, there are some anomalies
concerning the way Nero uses ASPI with relation to the different Windows
operating systems.
On Windows 2000/XP systems, Nero will install a file called wnaspi32.dll in
the Nero folder, which is its ASPI file and that file must be present for
Nero to work correctly on those systems.
On Windows 9x systems, I believe that it looks to see if an external ASPI
layer is installed (as there is no resident ASPI in those systems) - ASPI
being the system whereby the software communicates with the writer.
Depending on what is found I understand that this wnaspi32.dll file may not
be installed. If an installed ASPI layer is corrupt then the circumstances
could arise where an installation sees no ASPI whatsoever.
The first thing to do is to check for the presence of that dll file and put
it in place if missing. You can copy the file from the installation disc.
Windows 9x also permits the use of VXD files to extend the operating system.
These can cause the system to fail if too many such files use the operating
system call backs. You could find that you have a working aspi and the
system will fail because of the VXD file. You can establish if this is the
problem by renaming the nerocd95.vxd file to nerocd95.old, then reboot. If
you can now start Nero, albeit with an error message, then that is the cause
of your problems. If that is the case I have a couple of different versions
that you can try. This *only* applies to the Windows 9x OS.
< Graham Mayor
Was this helpful?
Yes
No
Solution #5
Not Rated)
M0nica L
Rank: Apprentice
Rating: 0%, 0 votes
John,
I followed your directions and the CD-RW apparently is being recognized
by my computer. I can access files from it with no problem.
Regarding seeing the CD-RW in "My Computer" it is listed as Optorite.
In my User's Guide Digital Research is not mentioned at all and under
the Warranty Information, I/OMagic is listed for repairs, etc.
This CD-RW has many aliases.
After reinstalling the Nero software it still hadn't corrected the
problem.
Later, I started Windows in "Safe Mode". Then when I tried to open
Nero, I got the following message, "The WIN-ASPI file '?.?' can't be
found, therefore you can currently select only image recorders. This
missing file is a part of the Windows 95/98/ME files. Please fix this
problem and then restart Nero. [Error12:Init failed!]"
I do appreciate your trying to help me.
George Nuetzel
Was this helpful?
Yes
No
Solution #6
Not Rated)
pawa
Rank: Apprentice
Rating: 0%, 0 votes
John,
problem.
George Nuetzel
Was this helpful?
Yes
No
Solution #7
Not Rated)
lawyer
Rank: Apprentice
Rating: 0%, 0 votes
Can you see the cdrw in my computer?
If yes.
Can you read a cd with it.
If yes.
reinstall Nero.
If no.
check and see if you installed the cdrw right.
check the cable.
Was this helpful?
Yes
No
Popular Solutions for Digital Research CD-RW Burner
Questions and Unsolved Problems for Digital Research CD-RW Burner
Do you recommend Digital Research (D522452EU) CD-RW Burner?
Answer
Answer
data burner said no cd in man dog multimedia dominator 52x but thier is.i'm running nero 6 oem... (More)
Answer
fireware has failed and now the computer will not opperate
Answer
it's a cd of 800mb but it says that the capacity is 702mb only
Answer
hello sir/madom my name is palamkuttalmathai i did not use any cdearth software but november28... (More)
Answer
just re-formatted OS Windows XP Pro have always used Sony CD extreme but now PC says - no compatable... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CD and DVD Burner Experts
Top Computer & Laptop Repairmen
in , MD
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
