Question about HP Photosmart C3180 All-In-One InkJet Printer
Printer won't print.
When trying to print, error note says "Not enough storage space".
  • l_k_graham Mar 12, 2009
    Downloaded Printer driver, but will not print, set as default printer
    Problem Solver:
  • 5 Answers
Increase the print buffer under printer settings
Posted on Mar 11, 2009
Error 651?won,t print from note pad
Follow these steps:
Go to control panel following location
Click on Network and Internet\Network Connections
Right click on broadband connections [WAN Miniport(PPPOE)] and un-check set as default
Jan 12, 2016 | Lexmark X2250 All-In-One InkJet Printer
Status code 4174-0000-3080-0504-8007-000D
This is very simple: you seem to not have enough hard drive space for a system update that your console is trying to install.
Error 8007 0070 occurs when you install an update or buy content on...
(I've pasted some bullet points for you)
" Error 8007-0070 occurs when you install an update or buy content on Xbox 360
Problem
You may see the following error code and message when you try to update your Xbox 360 console or purchase content:
xxxx-xxxx-xxxx-xxxx-8007-0070
Note
The "x" characters in the error code vary.
This may mean that there's not enough space on your storage device (mostly likely the Xbox 360 hard disk) to install the update or the content.
Solution
A console update or content download may require significant hard disk space. If you don't have enough free space, you need to move or delete some items."
You can probably get around this by using a 32gb USB thumb drive and moving some of your content that's hogging up your console's space onto that thumb drive temporarily.
Heres the Xbox.com info to get you started about moving and deleting hdd space--which also has info about using a USB thumb drive, too. Copy move or delete Xbox saved games profiles and avatar items
Jul 21, 2014 | Microsoft Xbox 360 Console
Cannot connect to networked computer: Error - "not enough storage space to process this command"
Okay, first a bit of "techie" information. When you print you send a file to the "print spooler" on the system handling the printing. In your case, that is Workstation 2. That file can be quite large and if there are several sent at once it can take up a lot of room. Once the system finishes printing it then clears out that space on the hard drive. Second, because you also use that for a file storage it may be that a lot of files are stored on that system either permanently or temporarily. So....the answer is that you are probably temporarily running out of disk space.
The reason you IRPStackSize increase worked is that you set aside more space for that stack so the system could hand incoming data more easily ...which meant it could sometimes delay a disk write enough to avoid a printing error.
The solution is to either increase the hard drive capacity of the system or to move the printing or customer files to another system on the network.
Of course, I could be wrong about this....;>) but it's the first thing that occurred to me.
Jul 17, 2013 | Microsoft Windows 7 Professional for PC
Brother ql-570 - not enough disk space
I am using Windows XP and your solution above didnt work any other ideas
Mar 21, 2012 | Brother QL-570 Thermal Label Printer
HP 4500 won't print
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Jun 12, 2011 | HP Office Equipment & Supplies
Error: Unable to store job at printer Reason: Insufficient disk space for this job. Solution: Delete some file from the disk before resending this job. How do I fix this?
If you are trying to use job storage, you will likely need to add memory to your printer or install a EIO harddrive. You may have accidently selected job storage when you did not mean to. In that case you will need to cancel any existing print jobs as well as restart the printer.
Mar 21, 2011 | HP Office Equipment & Supplies
Hp 2420 prints a ''job storage status page'' after each print job
If you have your software driver or print job set to save your print jobs to the printer and your printer does not support this, you will get that error and status page. Here is what the User's manual says about print job storage:
"The printer supports two distinct job-storage features that you can use to initiate printing from the printer control panel after the print job is sent from the computer:
● Proof and hold jobs
● Private jobs
Make sure that you identify your jobs in the printer driver before printing. Using default names might override previous jobs that have the same default name or cause the job to be deleted.
The job-storage features require 48 MB of RAM. For printer models that have less than 48 MB of RAM, you can add memory so that they can support the features."
Mar 17, 2009 | HP LaserJet 2420 Printer
Error message: Can not scan. Not enough space on target disk
I have just cured this"not enough space on the target disc" on my set up.I had the problem from day one after buying scanner but learned to get around it.Today I went into Toolbox and opened settings and made a note of the target address. Then checked properties of the target folder and found there was 86mb in a space for 80mb.This was the default setting chosen by the installation programme. I went to my documents and made a new folder and called it Canoscan, clicked ok and it became the new target and the fault is gone. Hope it works for others.
Dec 29, 2008 | Canon CanoScan 4400f MultiFunction Color...
Not enough server storage is available to process this command
Solution described here:
http://forums.techguy.org/networking/502748-solved-cannot-map-network-drive.html
Info on IRPStackSize here:
http://support.microsoft.com/kb/285089
Nov 15, 2007 | LaCie Computers & Internet
Not Enough Memory errors
* Empty your Recycle Bin on a regular basis. * Delete unused programs and files. * Reduce the storage space reserved for Internet Cache. o Open Pocket Internet Explorer (PIE) o Select View, Options and Advanced. o Adjust the size of cache, select Empty Cache When Exiting or disable caching altogether by removing the check mark from Enable Caching. * Consider external storage as an alternative.
Sep 14, 2005 | NEC MobilePro 750
HP Photosmart C3180 All-In-One InkJet Printer Logo
71 people viewed this question
Seeker5211
Seeker5211
