Question about RIM BlackBerry Pearl 8100
Handheld is Locked (screen saver security code)
Found a cell phone and would like to use it but when I insert the battery it says that the Handheld is Locked and requests a password
  • 170 Answers
Just enter any password wrong 10 times and it will automatically clear the handheld data, and reset the phone back to default status, from there you can loadyour inormation on it...
Posted on Mar 10, 2009
Phone shuts down every time it goes into screen timeout
I ahve an app installed on my LG G2 called battery saver get it at the store it has a little green droid dude get it install it and set it up how you want this will save you tons of battery usage.
For the screen saver you have to go into your security settings and configure it different way such as swipe or the draw on the screen type. with the Battery Saver app you will have no problems.
Feb 16, 2014 | LG Venice Boost Mobile
My nokia 2700 classic mobile phone is locked and i have forgotten its security key. IMEI No. is 356912031574227. Please send my its unlock key or nokia security master code so that i can use it.
Hello Sharma,
Switch off the nokia classic 2700 phone. Remove the battery for 30 minutes.Reinsert the battery and switch on the nokia classic 2700 phone. Enter the default code 12345 or 00000. Your nokia classic 2700 phone will be unlocked.
or
Try the Master Code : 4625042566
Jun 09, 2011 | Nokia Classic 2700 Cell Phone
I forgot my security code to unlock phone
First Try it:
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
OR:
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 04, 2011 | Nokia 1650 Cell Phone
3 have hard locked my handset
Tounlock cell phone Password:Instructions
Enter the last four digits of your phone number on yourcell phone PIN screen. Enter 9999, and if that doesn't work try 1111, and ifthat doesn't work try other 4 digit numbers you may have entered. Shut off your cell phone, take off the back of your phoneand pull out the battery. Record the IMEI number which is under the battery.Re-insert the battery and power on the phone. Enter the last 4 digits of theIMEI number on the PIN entry screen. Callyour service provider and request the unlock PIN. You will have to prove youare a customer by stating your cell phone number, addressand social security number. Turn off your phone. Hold thekeys "3," "*" and "Call" and switch the phone on.Hold the three buttons down until the word "Formatting..." appears onthe screen. This should reset the phone lock code. Read more: How to Unlock a Cell Phone Password ' eHow.comhttp://www.ehow.com/how_4810931_unlock-cell-phone-password.html#ixzz19YU6TIa2
Jan 01, 2011 | Nokia N95 Cellular Phone
I have tried calling *22899 to unlock my samsung schu350 and it didnt work it locked automatically when its turned on how do i unlock it
i found some great info but it will automatically delete all your info as well. i found this at t-mobile.com/forums but its universal on all samsungs
A phone lock or security code on most Samsung handsets can be overridden by performing a full reset on the device. This will set the security codes on the handset back to the default eight zero's (00000000).
Important: This reset restores the original factory settings and will erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. It does not erase data stored on the SIM card or memory card (if available). Make sure you have backed up contacts, calendar appointments, and other data before continuing.
1. Power off the handset
2. Remove the battery
3. Remove the SIM card
4. Reinsert battery ONLY
5. Turn handset on
6. At the Insert SIM prompt screen enter the following code: *2767*2878#
NOTE: If using a handset that was released after July 2009 use this code: *2767*3855#
7. The handset should display E2P custom reset
8. Power off handset
9. Reinsert SIM card
10. Power on handset
11. The phone should be unlocked
NOTE: If you didn't get a E2P custom reset or a Full reset message on the handset your Samsung model may need an MCK code. You will have to call technical support for this code. Please have your IMEI number ready to expedite the process for this code. Your IMEI number is located on a label on the back of the phone,under the battery.
Dec 24, 2010 | Samsung Smooth SCH-u350 Cell Phone
How can the standby mode on the Nokia 2730 be fixed.
first decide that in your phone activated your screen saver if yes then customize your display setting. if not then active your screen saver which is watch.if you not get any solution then format your phone. these code are under the following.
*#7780# then want security code. please give your security code. then your phone will be restore factory settings.
Jul 03, 2010 | Nokia 2730 Cell Phone
When i insert another sim card apart from the one the phone came with, this message appears on the screen"phone restricted"
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services.
Nov 24, 2009 | Nokia 7100 Supernova Cell Phone
I forgot my phone security code of nokia 3315 cell
Nov 23, 2009 | Nokia 3315 Cellular Phone
Unlock code for samsung a177. locked with at&t. imei35433103350886301
Once you unlock the phone, then you can insert a new SIM card in this phone.
Nov 22, 2009 | Samsung A177 Cell Phone
RIM BlackBerry  Pearl  8100 Logo
139 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
