Question about Apple DVI-I to ADC Adapter (M8661Z/A)
Macbook Pro External 23" Apple Cinema Sceen blue hue
Cant get rid of bluish hue on the screen. No bent pins on any of the connectors. Any suggestions?
  • 600 Answers
Have you altered the white point and temp settings in system prefs / displays
Posted on Aug 13, 2009
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
Screen has odd green hue occasionally when turning on then flashes.
It may be a bad connection in the display adapter. Try another adapter. Beware, some after-market adapters are not wired correctly.
Aug 17, 2017 | Apple Cinema Display 23" HD Monitor
Macbook and 24" display flicker when plugged in
MiniDisplay will probabely not support the Cinema's screen resolution...
Sep 05, 2012 | Apple LED Cinema Display 24 inch LCD...
The screen is half blue
You many need to reseat the Apple DVI to ADC Adapter that is connecting your Apple Cinema HD 23" to your Mac.
If that adapter is not properly seated, it can cause a color distortion with the display. Also, if the adapter is damaged, that can also impact proper resolution and color balance.
To try and resolve this issue for you, I have a procedure I would like you to try:
-SAFE BOOT MODE-
I am going to have you take your Mac into Safe Mode to see if we can't isolate what may be affecting your display's resolution.
Try these steps:
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain startup items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
Here is an additional support reference for troubleshooting Apple Cinema Displays color or distortion issues.
Apple Support Link:
Calibrating your Apple Cinema HD Display for color accuracy
This should help. If it does not let me know.
Regards,
-Mactechtrainer
Apr 24, 2009 | Apple Cinema HD 23" LCD Monitor
Monitor non functional
Am I correct in understanding that your MacBook is operating properly, but when you attach your external monitor it doesn't show anything?
I often connect my black MacBook 2GHz to my flat screen's VGA port. Sometime the screen doesn't respond for one reason or another. The fastest solution is typically to mirror the screens then return to normal. When that doesn't work, it's usually enough to restart the MacBook while it's still plugged in to the external monitor. If neither of those work, try connecting to a different monitor or finally try replacing the connector.
Unfortunately those connectors don't have the best life spans. (See Apple's customer reviews on DVI connectors.)
iKnow Apple Dan (919) 280-3101
Aug 02, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple 23" Cinema HD Display went off
Hey - I just got done with 30 minutes of trying my cinema HD on my macbook pro and plugging and unplugging. When I plugged it into an extension cord in another socket the monitor started right up. I've had this configuration in my office for years with no problem...until today. Did mac send us a system upgrade that caused a problem with the monitor's power source???? Good luck!!!!
Jul 28, 2008 | Apple Cinema Display 23" HD Monitor
Image/screen shifting with mouse position
I realized my issue was that the screen was "slightly" zoomed in using the universal access panel in the system preferences. Turning it off, or zooming out completely solved the problem.
Feb 21, 2008 | Apple Cinema Display 23" HD Monitor
Apple Cinema Display 23" HD - Dust on inside of screen.
Well, I pretty much knew that the display would have to be disassembled to clean the dust out. I should have been more specific by asking if the display "could" be taken apart to clean it out, especially since the dust is in between the image and light source layers.
Jan 15, 2008 | Apple Cinema Display 23" HD Monitor
Screen resolution.
Hello there!
It's fortunately quite easy to adjust the resolution your MacBook Pro sends over to your external display.  Try this:
  1. Click the blue Apple icon, at the top-left of your display (while connected to your 23" external monitor).
  2. Click on "System Preferences".
  3. Click on "Displays" in the "Hardware" row.
  4. A display preferences window should now open on each display... one on your laptop, and one on the 23".
  5. In the "Display" tab of this preference window, specifically the one located on your 23" display, should be a list of resolutions available.  Scroll down and select the highest resolution, which for a 23" should be 1920x1200.
This should adjust your resolution to the maximum.  To make these settings easier to get to in the future, check the box in the display preferences labeled "Show displays in menu bar".  You'll see a small icon, meant to look like a display, appear in your menu bar.  Going forward, you can click on this to set/change resolution settings without going through all the above steps.
Hope this helps!
Oct 10, 2006 | Apple Cinema Display 23" HD Monitor
Televison & Video Logo
65 people viewed this question
Top Apple Televison & Video Experts
Carlos L. Burgos
Carlos L. Burgos
Jim Goldsmith
Jim Goldsmith
Are you an Apple Televison and Video Expert? Answer questions, earn points and help others
