Question about Dell Vostro 1500 Notebook
Vostro 1310 won't turn on
My day old vostro 1310 shut off and would not turn on. I pressed the power button and it lit up. I could hear the hard drive go a little and the hard drive lite went on. Then the number lock key started flashing. Nothing else happened after that. The screen never turned on. The fan did turn on and off intermittently but nothing else happened. I called dell technical support and they had me run it through a bunch of tests and they said they would exchange it if his supervisor approved when I call back on monday. Sunday for kicks I pressed the power button and it turned on without any trouble. It just gave the start in safe mode option. If dell still lets me exchange it I definately will. I just want to know what is wrong.
I had the same problem, some times it worked properly without any problem but sometimes like what robjamsqu said, nothing on screen but other parts worked, but since yesterday it have been still out of order, i mean the same as robjamsqu said. i tryed to use an external monitor but it did't workk too.
Posted on Nov 19, 2009
    Master:
  • 404 Answers
I dont think theres anything wrong with the laptop but who's ever is using it could have done smth wrong
Posted on Mar 08, 2009
Download systemboard-page 8
Manuals here:
http://www.dell.com/support/home/us/en/19/product-support/product/vostro-1310/manuals
Nov 12, 2014 | Intel Dell Vostro 1310 Motherboard R511c...
My dell vostro 2510 won't power on, when i press power button to turn on the pc , the power light turn on for about 5 sec then it turn off itself,
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Jun 18, 2011 | Dell Vostro 2510 Laptop
I have a dell vostro 1310 laptop that will not boot. It first tried to recover but couldn't and would just shut down. Now I cannot even enter anything with a command prompt. I think my hard drive is fried...
Dell site should have info regarding the removal of old drive. Then install new drive in its place and install the recovery disks that you got or made. Hopefully the new drive will come with the software to prepare the drive for loading although some of the newer OS disks will do it for you.
Jul 22, 2017 | Dell Vostro 1310 Laptop Computer PC...
Dell Vostro 1310 - when turned on screen still blank, numlock blinking, capslock and scroll lock light on and stable. tried changed new RAM,issue still persist. whats wrong with it?
it may be bios problem or loose connection with Hard disc... So, follow the below steps: 1.remove the battery and power adapter 2.press the power on button 2 minutes 3.replace the battery 4.now on the laptop normally... now see the result.... ---------------------------------------------------------- if not solved then follow the below steps
1.remove the battery and power adapter 2.remove the hard disc,cd/dvd drive 3.replace the battery 4.now on the laptop normally... 5.if any display appears then problem with ur hard disc or cd/dvd drive.
------------------------------------------------------ follow the below steps to check the problem with your hard disc or cd/dvd drive
1.remove the battery and power adapter 2.remove the hard disc,cd/dvd drive 6.connect the cd/dvd drive 3.replace the battery 4.now on the laptop normally... 5.if any display appears then the cd/dvd drove has no problem,then problem with ur hard disc drive. ---------------------------------------------------
Apr 17, 2010 | Dell Vostro 1310 Laptop Computer PC...
I can't put dvd disk into Dell Vostro 1310
1. Switch off the laptop
2. Press the power button to switch it on.
3. Instantly after pressing the power button, start pressing " F2 " key on the keyboard to enter the BIOS setting.
4. Now press/touch the " eject button " of the DVD drive and now you are done, you will get the disc out.
I stole this from http://www.tech-tweak.net/2009/11/how-to-eject-stuk-dvd-from-slot-load.html
Mar 17, 2010 | Dell Vostro 1310 Laptop Computer PC...
When running test on my Dell Vostro 1500, error code 0146 shows
Error 0146 is a failed hard drive or bad drive sector, you have a bad hard drive,
Mar 04, 2010 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
My Dell Vostro 1310 won't turn on. I get a black screen (well actually, a bit of colors are coming, but nothing else ...). Tried again and again to turn on, seems to be a problem with the video card....
check for led lights if they come on.
note down the lights.
If you are able to remove the connection of the lcd to the laptop do so for instruction refer to www.dellsupport.com click on manal
Oct 05, 2009 | Dell Vostro 1310 Laptop Computer PC...
No output at all
okay close laptop remove battery, open ram / memory compartment, remove memory. try holding down power button for 3 minutes. THEN INSTALL BATTERY , NOT RAM/ MEMORY AND PRESS POWER BUTTON AND IF YOU HEAR A SOUND THAT GOOD NEWS THE SCREEN MIGHT COME ON, OR IT MAY NOT, BUT YOU SHOULD HEAR A BEEP, IF POWER BUTTON REMAINS LIT HOLD DOWN TILL COMPUTER TURNS OFF, THEN INSERT MEMORY/ RAM AND FIRE IT UP. WORK THESE STEPS
Jun 02, 2009 | Dell Vostro 1500 Notebook
Can't start windows: Hard Drive - No drive detected
The laptop cannot see/detect the hard drive. This means the hard drive is faulty or it needs reaeating.
Remove the hard drive and inserting again, then reboot the laptop, if it still cannot detect the hard drive then it is faulty.
You need to purchase a new one and install Windows on the new hard drive.
Mar 14, 2009 | Dell Inspiron B120 Notebook
Dell Vostro 1500 Notebook Logo
632 people viewed this question
Alun Cox
