Question about Western Digital My Book Essential 500GB External USB 2.0 - WDH1U5000N 500 GB Hard Drive
My I Mac doesn't recognize the WD 500GB external drive anymore
MY I Mac doesn't recognize the WD 500GB external hard drive . I have used the drive for about 4 months with Mac OS leopard and windows pro every day. Don't have more than 50 GB installed on the drive . Can anyone help me please
  • Anonymous Mar 31, 2009
    Same exact thing...  It selects when it wants to work and when it want to take a couple weeks off at a time.  But because I'm a photographer; and keep images stored on it, I have become extremely irritated.
    The only thing that I have done that sometimes works:  Connecting the hardrive to a seprate PC unit, ounce it is recognised unplug and reconect to my Mac... This temporarly elliviates the problem... by time im a awake in the morining... back to square one!
  • Anonymous Apr 10, 2009
    Idk about that...I'm using one on a mac osx 10.4.11 and I have the same problem.  I also tried to plug it into a PC and then back into my mac and nothing
It must be initialised /mounted 1st for osx
Posted on Mar 08, 2009
Wd 500gb hard drive is not shown any power it was working fine suddenly when i try to connect to my laptop nothing appearing. plz advice
Good day, this video tutorial will help you to recognize your WD 500GB. Just follow instruction and your problem will gonna fix.
Jul 30, 2011 | Western Digital My Book Essential 500GB...
Wd passport 500gb only works in mac. i need it to work in other computers
It could be that it's formatted with an HFS+ filesystem, which is not natively recognized in windows. Open up the disk management and check the filesystem on the device. If it is HFS+, you can get it to be recognized by getting all the data off, formatting it with another filesystem (FAT32 or NTFS are recommended), then putting the data back on.
Jul 12, 2011 | Western Digital 500GB My Book Pro-External...
My mac does not recognize my seagate goflex drive anymore
Try the drive on another computer. If it is recognized there, you might be looking at a larger issue on your Mac. If it doesn't, the GoFlex's drive or boards may have failed.
Jul 07, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
My Western Digital 500GB EDD has been making Clicking noise
Here are some options to try: - Purchase an alternate enclosure for your hard disk enclosure in case the circuit board in the WD case has gone bad. - Try accessing the drive via MS DOS window and use CHKDSK command to repair the drive (if you can get it to be recognized). - Try connecting the drive to an alternate PC or even a Mac to see if the drive can be recognized (perform disk repair if recognized).
Feb 10, 2010 | Western Digital My Book Essential Edition...
Hard Drive not mounting
Check the jumper on each hard-drive.
My guess is that the WD drive has the jumper in the "correct" position, for mounting inside an external case, while the other drives have their jumper set to an "incorrect" position.
Set the jumper to MA(ster), not to SL(ave), nor to C(able)S(elect).
Sep 08, 2009 | Macally 1 Bay PHR-250CC (0701107485355)...
My mac won't recognize my wd hd anymore
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Aug 31, 2009 | Western Digital My Book Essential 500GB...
I cannot copy files FROM my Western Digital 500GB
Check the file system of your hard drive. If your PC is recognizing it, check if its a FAT or NTFS. If it is NTFS then you have to reformat it using your Mac and choose FAT. Mac OS recognizes NTFS as a read only drive. If you plan using it with your PC and MAC you should format it using your mac and choose MS-DOS in disc Utility. You cannot format the drive using your PC Computer with a FAT file system because of the capacity. Only Mac can format it with a FAT file system.
Aug 23, 2009 | Western Digital My Book Essential 500GB...
My WD 2T external My Book hard drive is not working
You will need to try formatting the drive. You can do this from the drive management section on the Mac.
Jul 10, 2009 | Western Digital 500GB My Book World...
Mac not Reconize my MyBook
load the driver for mac use, the external hard drive comes with cd, the mac driver should be inside, load it to your mac computer. if you donot have the cd go online to western digital and download it. just load the driver and u will be fine, make sure u connect the cable in right places.
Mar 09, 2009 | Western Digital My Book Essential Edition...
MyBook not recognized by Mac
I am having the same problem!!!! I have my time machine backups on there and I cannot access them! Class action lawsuit???
Mar 09, 2009 | Western Digital 500GB My Book World...
Western Digital My Book Essential 500GB External USB 2.0 - WDH1U5000N 500 GB Hard Drive Logo
1,995 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
