Question about Amana ABB2227DE Bottom Freezer Refrigerator
Amana Bottom Freezer door when shut starts a noise
It is the flipper thing for the freezer light. When I open the freezer door it stops.Is there a motor or something turning the light on and off ? It si a constant grinding noise ! PLZ help me
    New Friend:
I was having this same problem and just fixed it. When you close the freezes door the switch turns off the light (everyone know that). That same switch also turns on an evaporator motor and fan that comes on. If ice builds up in the freezer treys, it will cause this motor and,or fan to make noise. My freezer had a piece of ice stuck in the maker. I broke it free, and the noise stopped. If you don't have ice built up on yourself, you may need to replace the motor (AND fan) located behind the panel in the back of the freezer. Good luck!
Posted on May 22, 2016
  • 400 Answers
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Posted on Mar 09, 2009
How do a fix a refrigerator which makes a clicking noise when light in freezer is off? If I open the freezer door it stops. If the door is open and I depress the light switch, it starts the noise aga
That's a weird one. It sounds like the switch operates a relay that cuts off power, and the relay is "chattering." If so, the only way to stop it is to replace the relay. Call a technician if you're not comfortable getting into the inner workings of your freezer yourself.
Nov 06, 2014 | Amana Refrigerators
I have an Amana Refrigerator. It is a double door on top and a pull out freezer on the bottom. The freezer is working fine. The refrigerator light comes on but it is not cold and my fresh food is fading...
either the evaporator fan in the damper vent door isnt running to push cold air from the freezer up into the refrige compartment or the damper vent door between the freezer and refrige section is frozen shut and cannot open to allow cold air flow,you need to access the evaporartor coil in the freezer rear wall and check both the fan and door movement
Mar 22, 2011 | Amana Refrigerators
Fridge and bottom freezer not cooling. Light on when door opened. Is there a reset switch/button? It is an Amana
There is not a reset switch/button. Do you hear any noise at all, fans or clicking noises?
Jan 11, 2011 | Amana ABB1927DE Bottom Freezer...
Bottom freezer seem to be fine top refrig.is warm?
couple things to start off with is make sure the fan from freezer section is still blowing...may have to with door open hold down door switch as they sometimes stop running when you open door...if the fan is still running,then is the back wall of freezer frosted up you could have a defrost problem a defrost thermostat, or a heater issue... last make sure you have a clear passage from the freezer to the refrig such as the airflow gap or damper assembly which will be either a manually damper or a automatic damper//this is the flap that opens and closes usually by temperature to let air from freezer to refrigerator side....also make sure the unit all together is running properly the freezer is the last part to give you a problem as this is where the coolant actually starts then is pushed into refrigerator....few things for you to check repost if you have anymore questions....good luck
Jan 05, 2011 | Amana ARB2217CSR Bottom Freezer...
The freezer area makes constant noises groaning whne door is closed, stops when door is opened
I'm going to say it's a bad bearing in the fan. It shuts off when the door is opened so as to waste as little coldness as possible.
lp
Dec 29, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer door opens when fridge door closes
if you are worried that the freezer is empty....fill it with plastic bottles of water...remember tho,don't fill the bottles completely as frozen water expands.
Jul 20, 2010 | Amana ATB1832AR Top Freezer Refrigerator
My Amana frost-free freezer is accumulating frost all along the back wall. And, things at the front aren't freezing. What is the problem? (Things in the refrigerator are still cold)
I think the good thing about this is your model has a defrost timer inside the fresh food compartment and behind the control panel. Look for a hole or plastic plug covering a hole about the size of a pencil and place a small flathead screwdriver in hole and slowly turn clockwise until the compressor and fans stop. This should begin the defrost cycle and remain off for about 25 minutes. Open freezer door and listen for crackling or noise of water melting and sizzling. If after 25 minutes the refrigerator does not restart slowly turn the timer clockwise again until it starts. Tell me what you find, Sea Breeze
Jan 15, 2010 | Amana ARB1905C Bottom Freezer Refrigerator
Lec elan a class under worktop freezer 4 years old.Red light has been on for 24 hours,food still appears to be frozen.What do i do
check that the thermostst is working,, if its not it wont turn on the compresor,,, and it stops freezing the red light is the warning light that tells you its getting warm inside the freezer ie:hotter that -16* it will soon start to de-frost withing 24 hours keep the door shut if you can till its been looked at,, but get it looked at very soon or you will loss every thing in there
Nov 17, 2009 | Amana ABB1927DE Bottom Freezer...
Unusual fan noise
sounds like you need a new fan motor or blade
Jun 03, 2008 | Amana ARB8057CSL Bottom Freezer...
Amana ABB2227DE Bottom Freezer Refrigerator Logo
582 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
