Question about Hoover U5721-900 WindTunnel Upright Vacuum
Why does the hose have no suction?
The hose has no suction and the vacuum shuts down after a few minutes use.
    President:
  • 389 Answers
Sounds like your machine has a blockage in the vacuum system, and is cutting out from overheating. If you no longer have a manual, which will tell you about clearing blockages, you can download from the Hoover website.
Posted on Mar 08, 2009
Vaccum afuera 550 start few minutes and stop few secondes, after 10 min its stop 30 sec and start 3 sec, after 20 min start ok
Your vacuum may be clogged, overheating and shutting off. Check for obstructions in the hose by laying it as straight as possible and shining a flashlight in one end while looking thru the other end. If you have a curved hose end, try holding the suction hose from another vacuum while checking for airflow in the opposite end.
Nov 06, 2013 | Electrolux Central Vacuum
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Nutone Model CV353; runs for several minutes and then shuts off. After a couple of hours I can turn on again, but again only last a couple of minutes. Possible relay problem?
Check the filter. If it's dirty, thoroughly rinse it in cool water, then let it thoroughly dry before using. If you don't have an extra filter to use during this time, you should get one.
It could also be a clogged hose or pipe. These would cause the motor to overheat, thus shutting off. Check hose at end for suction. If weak or nonexistent, detach hose and try dropping a penny or dime, or marble, down the hose. If it comes out the end, the hose is probably clear. If this is the case, you need to check other outlets.
Dec 12, 2010 | Broan-NuTone CV353 Central Vacuum
My DC17 suction hose doesn't have any suction occasionally.
check the seal on the filter is not broken,And check for any blockage at the bottom of the pickup pipe.
Nov 18, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Runs for a few minutes. Loses suction the shuts
It sounds like it's draging on the motor Also heating up the thermister switch. I would recomend having this look at from a vacuum repair shop ask for free estimates if you call around. save some $$$
Nov 10, 2009 | Royal RY9200 Bagged Upright Vacuum
Tristar mg2 keeps shutting off and a few minutes later comes back on. Almost like it is heating up. I noticed that intermittently I'm losing suction.
. remove the hose and check hose and wand for blockage by dropping a coin through end to end. A coin will come to rest against a clog and when you shake the hose the coin will rattle in the are of the obstruction.
Blockage should always be drawn backwards out with another vacuum. If no blockage, install a fresh bag and check your internal filter. Then test the vac for suction where the hose inserts.
Sep 26, 2009 | Vacuums
I have a red c velvet. My vacuum keeps shutting
Could be you have a filter issue and it is overheating and shutting itself off. Make sure you have not put on the wrong filter type for the machine. Some of the pieces that come in the FJM boxes are not actually filters and people make the mistake of putting them on as filters. The other major problem that could be happening is that there is some problem with the hose itself. On my vacuum it will shut itself off after 2-5 minutes, but the power light remains on. I have to press the up button to get more suction, but that only lasts until it shuts itself off again. If I unplug the hose from the cannister... the power comes on fully and the vac never shuts itself off.
A tech told me that the likelihood is that there is some component or connection in the hose control that is causing faulty shutdown. He told me I would need a new hose costing $175. After a year of trying different things, I am convinced he is right and we need to bite it and just buy a new hose.
Sep 13, 2009 | Miele S558 Red Velvet Bagged Canister...
Hose is not getting any suction
when vacuums shut off randomly it usually means they are overheating. this can be caused by a clog somewhere in the line of suction, or, perhaps due to a very dirty filter - either way, the motor is working hard and getting too hot.
try removing all the various tubes and parts along the suction route and checking for clogs (a flashlight might help too). also, have you rinsed out your two pre-filters lately as recommended in the Dyson manual? it might help.
Apr 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Machine turns on, has little suction, then stops working.
It would be helpful to know what model of vacuum cleaner you're talking about. Basically though, your machine has a blockage somewhere (hence very low suction), and is cutting out after just a few minutes because of overheating.  You need to explore the suction hose (or whatever your machine has), find the blockage and remove it. Blockages almost always happen where the pipe-work takes a sharp bend.  In the worst-case scenario (although in almost all modern machines this is not possible) the blockage may be in the vacuum fan enclosure itself, and then you'll probably need a professional to take care of it.
Feb 03, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC07 shuts down after 5-10 minutes of use and horrible suction!
I have had this problem on two dysons and have solved it by replacing the so called lifetime pre-filter. The problem is not the washable blue sponge but the material gauze filter in the plastic surround.
To see if this is your problem try removing the whole filter (i.e. the filter with the blue sponge inside - you need to remove both bits not just the sponge).
If you do a quick vacuum test for a few minutes then see what effect this has on the suction.
If you need a new part try somewhere like here (you'll need to chose for the right model) : http://www.espares.co.uk/part/dyson/dc07/p/1086/716/6/420625/875479/lifetime-pre-motor-dyson-.html
As I say this has fixed both of mine.
Oct 27, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover U5721-900 WindTunnel Upright Vacuum Logo
135 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
