Question about LG 24 in. LDF 7811 Built-in Dishwasher
Attaching counter clips to dishwasher - LG 24 in. LDF 7811 Built-in Dishwasher
  • Jeff Meyer May 11, 2010
    Did you get your problem taken care of?  Please post a comment back here is you still need help.
    Thanks!
    Can you be more specific with your question?
    Do you own a LG LDF7811 dishwasher?
    Thanks!
Dishwasher was not installed but only slid under counter so now it topples over. I have no installation clips
Your dishwasher may have a "side mount" and you may be able to screw it into the sides of the cabinet, if not, you will need to find out how to attach the brackets to your dishwasher (they usually slip into a groove in the top of the dishwasher, bending the tab over once slipped in will prevent it from coming out again.) If the brackets are for another dishwasher, you will need to order the correct brackets for yours.
Oct 07, 2012 | Magic Chef Built-In Dishwasher -...
We have a Bosch SHE45M06UC/50 in an island with a granite countertop. It is not attached and so moves. How do we attach it to the granite countertop? Or how do we attach it????
You glue on a wood strip, to the underside of the counter, then screw into that. Use construction adhesive. The wood strip needs to stick down no further than the counter edge treatment, so you normally cannot see this wood strip.
May 11, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Water not draining
Remove the check valve ( the white plastic part the hose is attached to with the ball and clip) by gripping it firmly and rotating it counter clockwise.( Be prepared for water coming out) The blockage is usually in here or in the hose /drain itself. Blow through the hose to the drain just to make sure it's clear.
Does the motor run? When you removed the hose did water come out of the dishwasher?
Apr 21, 2011 | Whirlpool 24 in. DU1100XTP Built-in...
Need to stabilize machine and have granite countertops
Ask a local granite fabrication shop to get you some dishwasher mounting clips. They look like a perforated disc of metal with a small nut brazed to one side. They come with a short screw that attaches through your dishwasher mounting tabs. Place your dishwasher where you want it relative to the cabinets and pick a hole in the mounting tabs that won't leave the clip protruding and attach the clip to the chosen hole. Use masking tape on the top of your dishwasher door, wipe the bottom of the granite and the top of the clip with acetone, then use a gel-type two part epoxy from your local hardware store to attach the clip to the granite. Use enough to make the epoxy push through the perforations in the clip as this is how the epoxy grips the clip. Push the clip to the bottom of the granite and close the dishwasher door, using a wood shim or two between the top of the door and the mounting tab/clip to push the clip tight to the granite. Pull the shims out once the epoxy has cured (check the instructions on the epoxy).
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Nov 20, 2010 | Siemens 24 in. SL84A305UC Built-in...
Mounting my dishwasher to granite counter tops. Granite Grabbers last about a week before they loosen up
Oct 21, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Just did a kitchen remodel, kept the Bosch dishwasher model SHU9955UC, contractor having problems will attaching dishwasher to granite. Any suggestions? Thanks!
Sep 24, 2010 | Bosch SHU9955UC Built-in Dishwasher
When shutting the door, it rubs against the side. The other side has plenty of clearance. How do I adjust the door?
If it rubs against the cabinet that its under there should be two clips that are attached to the top of the washer and is screwed to the underneath of the counter top. Take the screws out of clips and counter top and you should be able to move it enogh to fix the probels.
Mar 10, 2010 | Samsung DMR78AHS Builtin Dishwasher
I'm having my kitchen counter tops replaced with granite. I have a GE Model GSD700 dishwasher that is now attached to the existing counter top. The granite counter tops will not accept having a dishwasher...
• Purchase and install the GPF65 side-mount
bracket kit if the underside of counter is granite
or a similar material that will not accept wood
screws. The GPF65 kit is available from authorized
GE appliance dealers.
Also note that any stainless steel tub models would be able to accomadate granite tops without a kit, and I beleive all Profile GE models come with the kit included.
Sep 27, 2009 | Dishwashers
Kenmore Dishwasher installation
taking astab at this but your kit floor has been replaced and to close to counter now????, your either shimming up counter or removine the floor from under d/w
Mar 11, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
Dishwasher de-installing
You may be able to push it back in and place a piece of quarter round molding down at the floor with nails to prevent it from coming out again.
There should be some kind of clips if you look under the front edge of your counter. The clip or clips should have holes for screws that will screw into the underside front edge of the couner top.
Feb 09, 2008 | Bosch 23 in. SHU 8805 Built-in Dishwasher
LG 24 in. LDF 7811 Built-in Dishwasher Logo
221 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
