Question about KitchenAid KCO1005OB 1400 Watts Toaster Oven with Convection Cooking
Toaster oven stopped working, I believe it's the power supply.
The toaster oven just stopped working; no lights are on, no heat.
  • 1 more comment
  • Anonymous Mar 10, 2009
    Less than 1 year old, no lights go on when plugged in. Seems dead
  • lalatraviata Mar 16, 2009
    F*** this oven. I've only had it for a few months and now it's dead. RIP POS.
  • rdzus Apr 29, 2009
    It appears Kitchenaid put a non-resettable overheat breaker in this thing. If the oven thinks it's gotten too hot a tiny drop of low-temp metal melts and allows a little plunger to relax pressure on the contacts it's holding closed. I'm sure they realize now that it's a design messup. I called their hotline and they immediately sent a new toaster and a return label for the old one. The number to call is in the booklet that came with the toaster and can probably be found on their website.
  • 5 Answers
SOURCE: toaster oven just stopped working...
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Posted on Apr 07, 2008
SOURCE: Light and oven does not turn on.
:-) Same here, in the middle of cooking the toaster just died. O' well, i am a tech! i opened the unit and diagnosed the problem. the unit has a non-resettable high limit thermostat that blows open when reaching high temperature. the problem is that when it happened, the oven wasn't even hot and was only on for a bout five (5) minutes. From my experience, it is due to a design defect. from all i have seen so far, it doesn't seem that the company cares about its reputation or customers... what can you expect from the French?!
Posted on Jun 12, 2008
SOURCE: Toaster Oven Repair
Toaster switch does not stay down. I have to hold the switch down to get toast. The heating element works fine as does the oven. Can we fix the switch? Or, do you know someone to whom we can send it for repair? Thanks!
Sheila Newton
Winston-Salem, NC
Posted on Sep 12, 2008
SOURCE: KitchenAid toaster oven Mod# KC010058
The overload switch is located above the theromostat.To check it put a jumper across the switch and plug the unit in. If the switch is bad you will now see the red light on and the oven will work. Take the switch off and gently pry the 4 posts back. Remove the pin, gently put it in a vise and put a drop of solder on top of the metal cap. Put the switch back togther, install it and you should be back in operation.
Posted on Mar 13, 2009
  • 563 Answers
SOURCE: black n' decker oven toaster oven broken
I work for Black & Decker customer service. Our number is 800-231-9786.
Unfortunately, our products can't be repaired. Please call the above number so that we may determine your warranty eligibility. The oven carries a one year warranty from the date of purchase.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 04, 2009
The bottom heating elements on my breville toaster oven model BOV 800 XL stopped working. What to do?
You could have them replaced but will it be cost effective to do so? Maybe a new toaster would be better and cheaper.
Sep 17, 2017 | Breville Toaster Ovens
How can I troubleshoot my kitchenAid toaster oven? The timer works but the light will not go on, and it will not heat up on any setting.
The heating element went bad. The manufacturer makes it impossible to open the unit and doesn't sell parts - the lawyers told them it is too risky to let consumers repair toaster ovens.
Feb 25, 2015 | KitchenAid KCO222OB Countertop Oven
My black & decker tro964 is not heating
That may sound like a stupid question, but is it plugged in?
Have you tried to plug in the toaster on a different power outlet?
If there is a ground fault switch where the toaster is plugged in (that's those outlets which have 2 buttons on the front, one labeld "Test" the other usually labeled "Reset") unplug the toaster and push the "Reset" button and try the toaster again. To test, if the power outlet, were the toaster is usually plugged in, is working, try a hair dryer or any other device on that outlet.
Its most likely cheaper to replace the whole toaster than to replace the heating elements, for about 40 $ since that's the price of your toaster on some websites.
Jan 06, 2014 | Black & Decker TRO964 Toaster Oven
Delonghi xr640 toasting-finished chime not working
follow this steps and fix it. God bless you
f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
My toaster oven stopped heating all together.
your heating element has gone bad or there is some bad wiring in the oven itself
to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
Heating units bottom stopped working. Then the top heating bars stopped working. It's a radiant oven.
it is several prosibilites for your problem:
1) the wire of the oven is damaged;
2) the thermostat is decalibrated or damaged;
3) one or more heating element is intrerupted or burned.
1) check the wire an replace or repair where is posible whit similar heat resistant wire;
2) replace the thermostat whit similar one;
3) replace the heating element
Feb 21, 2010 | Oster 6239 Toaster Oven with Convection...
Toastmaster Toaster Oven 357 is not heating when door is closed?
Mine just broke too - it won't heat - everything else works - lights, timer ect. but no heat can't cook
without it - love my oven - any solutions ( I guess it's the heating element ) Hope I can get a new one.
Aug 29, 2009 | Toastmaster 357S Cool Wall 1400 Watts...
Non stop ignitor clicking
The thermostat tells the ignitor what to do. So, I believe the problem should be takrn up with the heat foreman
Jul 29, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Oven just stopped working
1-usually it easy proplem
2- check your electricity voltage by testsrowdriver or another good device like radiocasset or voltmeter if you can
May 31, 2009 | DeLonghi XR450 Retro Toaster Oven with...
169068 GE Toaster Oven - no heat
remove the plastic side where the controls are . if you see a broken wire you might be able to repair it otherwise theres no parts made for it ,so no matter how simple the broken part is .....there is nothing that can be done about it ........ WELCOME TO THE WORLD OF "MADE IN CHINA"
Jan 28, 2009 | GE 168947 Toaster Oven with Convection...
KitchenAid KCO1005OB 1400 Watts Toaster Oven with Convection Cooking Logo
222 people viewed this question
Top KitchenAid Toaster Ovens Experts
Think Crucial
Think Crucial
Tom Chichester
Are you a KitchenAid Toaster Oven Expert? Answer questions, earn points and help others
