Question about HP Photosmart C5280 InkJet Printer
When we try to print off our hp c5280 we get a comment saying failure to print due to allignment failure. What do i do to sort this issue out?
    Genius:
  • 2,120 Answers
Replace all ink carts with Genuine HP
Posted on Mar 08, 2009
  • Leroy Elliott
    Leroy Elliott Mar 08, 2009
    replace all ink carts with Genuine HP
My printer is saying refer to documentation, there's a fault with the righ cartridge, help?
You mean its saying you have a "faulty" right cartridge?
what that means is that the cartridge on your right has a problem and needs to be replaced or repositioned. You can try two things to fix this problem.
You can try removing it and replacing it to see if its just not snapped into the printer correctly. then try cleaning the print nozzle or alligning the cartridges to see if that stops it. To clean the print nozzle or align the cartridges, click on "menu" on the printers keyboard and then use the arrows to scroll until you find "maintenance" and then press "enter" or "ok". Continue scrolling until you find the "clean print nozzle" feature and then press "ok" or "enter". Follow the prompts and try cleaning a couple of times in a row.
If this does not correct the error. Replace the cartridge.
Mar 21, 2011 | HP Photosmart C5280 InkJet Printer
Red exclaimation mark on C5280
Try first unplugging power cable, and see if it clears the error
Jul 29, 2008 | HP Photosmart C5280 Printer
Hp photosmart c5280 Cartridge Alignment problem. everytime I try to print it tells me to run alignment test, and then when the alignment is off, it won't let me print...HELP!
Please follow the below steps. After evry step, if the cartridges are not allign automatically, allign it manually by the below steps.
To align the cartridges from the All-in-One
1. Load letter or A4 unused plain white paper into the input tray.
2. Press Setup.
3. Then scroll using the down arrow key and select Tools then select Align print cartridge or Align printer.
STEP 1.
Please take out all the cartridges and clean the copper contacts with the help of a lint free cloth and the water.
STEP 2.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 3.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
Apr 28, 2010 | HP Photosmart C5280 Printer
Hp photosmart c5280 all-in-one printer........the color ink cartridge will not allign
I had a similar issue, I called HP Support and they had me change out the ink, re-run the alignment, restart, change out the paper, run the alignment again. They had me try everything you could imagine. But, in the end; there was absolutely nothing that would fix it. They said that pulling paper jams from the printer among other things (if not done properly) can permanently damage the print head to where the alignment can no longer correct it. Luckily, while it took forever, the printer was under warranty...I had to do a warranty repair, but the new printer had no issues.
Mar 08, 2010 | HP Photosmart C5280 InkJet Printer
HP SOLOUTIONS CENTER, C5280 SCAN - when trying to save scan in a specific location Drop down menu is blank. THANK YOU
Put new ink cartridges in printer and will not allign properly, what should I do? Alreadsy printed the allignment page and it is off.
Dec 03, 2009 | HP Office Equipment & Supplies
HP C5280 all in one prints but does not scan
2 ways to scan from HP printers
First* try from "my computer" ... near the bottom of the page you should see "scanners" in there, try clicking that and follow prompts
Second* go to start/ programs/ HP/ HP Solution Center
all scanning choices should be on the left
Please don' forget to rate me : )
Oct 01, 2009 | HP Photosmart C5280 InkJet Printer
Printer will not Print Black Ink copies
try to clean and allign the catridges from the front panel menu of the printer..
regards,  raj_p5983
Jan 11, 2009 | HP Photosmart C5280 Printer
Would not print C5280 Flashing Failure Print Cartridge allignment
Solution
  1. Load unused plain white letter or A4 paper into the input tray.
  2. Press the Setup button.
  3. Press the down arrow button to select Tools and then press OK .
  4. Press the down arrow to select Align Printer and then press OK . The unit prints a test page, aligns the printhead, and calibrates the printer.
  5. After the success or failure message displays, click OK to continue. Recycle or discard the alignment page.
Cause An incorrect type of paper is loaded in the input tray. If you have color or photo paper loaded in the input tray when you align the printer, the alignment might fail.
Nov 04, 2008 | HP Office Equipment & Supplies
HP Photosmart C5280 InkJet Printer Logo
59 people viewed this question
Ben Johnson
