Question about Sony FD Trinitron WEGA KV-32HS510 32" TV
Problem with 1999 Sony Trinitron Wega 32 inch TV
All red colors are now gray.
  • 59 Answers
Sounds like the tube has gone any good tv repair shop will be able to replace it cheapley.
Posted on Mar 10, 2009
Color wiring diagram
with the 5.4 engine
violet/white--- tps reference
gray/white ------ tps 1 signal
orange/lt. blue -- tps signal return
gray/red ----- signal return
red/white ---- reference voltage
with a 6.0 diesel
tan--------ref. volts
yel/white- apps 1 signal
blk/org---- signal ret.
white/red- apps 3 signal
gray/blk--- apps 2 return
white------- apps 2 signal
blk/white-- aps2
hope this helps
Mar 26, 2014 | 2006 Ford F-250 Super Duty
Danco instructions
Umm, yeah I think so....
Nov 10, 2013 | Danco Home
I am installing a CD player in a 2004 Nissan Sentra and I need to find the wiring diagram to show me how. Can you help?
see connection colors below and let me know if you have questions.
2004 Nissan Sentra wire colors aftermarket radio wire colors
Car Radio Constant 12v+ Wire: Pink, yellow
Car Radio Switched 12v+ Wire: Blue, red
Car Radio Ground Wire: Gray, black
Car Radio Illumination Wire: Red/Green, N/A (tape off factory wire)
Car Stereo Dimmer Wire: Red/Yellow, N/A (tape off factory wire)
there is no factory amplifier wire, blue (tape off radio wire)
Left Front Speaker Positive Wire (+): Pink, white
Left Front Speaker Negative Wire (-): Blue, white/black
Right Front Speaker Positive Wire (+): White, gray
Right Front Speaker Negative Wire (-): Black, gray/black
Left Rear Speaker Positive Wire (+): Light Green, green
Left Rear Speaker Negative Wire (-): Violet, green/black
Right Rear Speaker Positive Wire (+): Blue, violet
Right Rear Speaker Negative Wire (-): Pink, violet/black
Aug 21, 2011 | Car Audio & Video
Gray turning red when colored.
You have to look at it as if your grays were blonde, it's going to have a red hue to it as if a blonde were to dye it the same color. I suggest using a gray touch up in a darker brown tint first and then dying all of your hair a day or two later. This should prevent it from turning red and give you a color that is closer to what you're looking for.
Feb 12, 2011 | Revlon Colorsilk Hair Color 4N Medium...
What color are the wires on a 1992 eagle talon to hook up my new stereo.for example.what color is the speaker wires,left front r front left rear right rear.thank you
Here you go.
1990-92 Eagle Talon Stereo Wiring Constant 12V+ Red/Black Switched 12V+ Blue Ground Chassis Illumination Green/White Dimmer Black/Yellow Antenna Trigger White/Black Antenna Left Rear Front Speakers 4" Dash Left Front (+) White/Blue Left Front (-) Black/Blue Right Front (+) White/Red Right Front (-) Black/Red Rear Speakers 6 1/2" Side Panels Left Rear (+) Yellow/Blue Left Rear (-) Gray/Blue Right Rear (+) Yellow/Red Right Rear (-) Gray/Red
Jan 16, 2011 | 1992 Eagle Talon
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
Picture is Gray, does not show any color
Are you using component cables (red/green/blue)? Check your connections to see that they are all seated properly. When using component cables, if only the green is plugged in, it will give you a black and white picture. You will get color once you plug in the red and blue.
What kind of sources are you using? what kind of cables are you using? Need these kinds of specifics to ehlp you out.
Mar 28, 2008 | Televison & Video
Pioneer deh425 plug discription
I have one right in front of me and can tell you what color each wire is, from top left of plastic wiring port.
Black/ green ?
Grey/black ?
Blue Power Antennae
Black Ground
Black/white ?
Green/black ?
Red/green ? Left Lower row
Gray/red ?
Red Accessory/Ppwer
Orange Battery Memory power
Green ?
Dec 25, 2007 | Pioneer DEH-425 CD Changer
Sony FD Trinitron WEGA KV-32HS510 32" TV Logo
207 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
