Question about Linksys Wireless-G Broadband Router
Can't get my laptop to find router
My old Linksys Wirless-G 2.4GHz broadband router stopped working. I bought another one just like it. Two of my computers are working but I can not get my laptop to find the router. It appears to be looking for the old one. Any ideas?
  • kve21 Mar 09, 2009
    I have my computer (Gateway GM5424, Windows Vista Ultimate) connected to the internet (broadband modem, comcast) with LinkSys SRX 200 router (model WRT54GX2) connecting to a PC Desktop and Laptop (both Windows XP). The Laptop frequently disconnects unpredictably from the internet that cannot be reconnected through laptops' protocols or turning it off then on. Disconnecting the LinkSys power plug for ~10 seconds then reconnecting usually works. Any explanation for this behavior and permanent connection?
  • 679 Answers
Yes, go to my network places, right click, select properties, then create new connection, the wizard will walk you through, don't forget you have to put in the type of encryption and the Key ,that may be why it's not working. When you set up your new connection, you can select home/office etc, also delete the old connection, as that will cause you problems.
Posted on Mar 08, 2009
Thomson gateway tg585
yes i need my password or linksys wirless-g broadband router i need doe code ? pls give me now
Sep 03, 2013 | Linksys Wireless-G Broadband Router
My wireless router stopped working. If I bypass the router, I have Internet. The error message says "wireless security types do not match. I have a linksys wireless g broadband router.
wireless security type is the encryption setting you are using.
you either need to change it to wpa/wpa2 mix or wpa.
make sure the client(laptop) is set for wpa or wpa2.
Feb 26, 2011 | Linksys Wireless-G Broadband Router
I bought new laptop Dell vostro, it is not able to
Probably your network is secured so you will need to configure connection (provide WEP or WPA passkey to connect).
Double click on wireless network name you wish to connect and put encryption key
Nov 26, 2009 | Linksys Wireless-G Broadband Router
I have a wt54-g broadband router. when trying to go wirless everything went through fine except 1 problem it says cannot connect to the internet. Any way to solve this?
Unplug house connection or router for 30 seconds, then do the linsys for 10 seconds and plug back in. This should reset everything to work correctly. If needed, reset ip address on your pc. Set up home network if necessary.
Sep 12, 2009 | Linksys Wireless-G Broadband Router
Want to get on internet with my lap top via wireless what card do i need for the inspirion 8100
first of all you need to check with your internet provider to see what modem you can use. a wirless 802.11g card (the farthest range) if your provider has a wirless modem i would get it from them. and a wirless modem/router. i use bellsouth wirless dsl and bought the equipment from them. if you have a wirless modem/ router already then you just need the card and configure it.
Jul 26, 2009 | Dell Computers & Internet
I am new at this
There is nothing to Delete. Simply unplug the old and plug in the new. A WEP key is a way to ensure a small amount of encryption in the Wireless network. If the new Router has WPA - you should use that instead of WEP as the WIRELESS Encryption. There should be a "quick start guide" to help you install the new Router.
Mar 29, 2009 | Linksys WRT160N Wireless Router
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Can't go on Internet with Linksys Router
log into router by entering its default web page into your browser 10.0.0.9 usually. then run tests and save.Easy
Apr 11, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
55 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
