Http://xbox-experts.com/e/errorcode.php?e=E74
This type of fatal cartridge error (i.e. "refer to documentation" / "incompatible cartridges", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. However, our test group has also seen these failures with brand new cartridges. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below on how to access respective printer's service menu and correct:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings:http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart C4200-C4500 and C5200-C5500a Printers - Diagnostic Tap 41 Test: (verifies electrical health of ink cartridges):http://www.youtube.com/watch?v=8fE-IM4AVMc
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
These types of severe
cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print
cartridge(s) problem", "cartridge in wrong slot", etc.) typically indicate the internal micro-electronics
susceptible to ink attack over time, which can lead to premature failures. In
Inkjet411 youtube videos below:
Cartridges - Solving Errors & Warnings: http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart
74-75 Cartridges):
HP Officejet
Ink Refilling &
These types of 'severe' cartridge errors/alert messages (i.e. "refer to documentation" / "incompatible cartridges", "print
cartridge(s) problem", etc.) typically indicates the internal micro-electronics
HP Photosmart
74-75 Cartridges):
HP Officejet
Ink
of the HP #74 / 75 (or 74XL/75XL) cartridge(s) are damaged. The cartridge's electrical wire runs at
HP Photosmart
74-75 Cartridges):
HP Officejet
Ink
i dont get it. i dont play my 360 that much, fact is, i havent played it that much at all since i got it....maybe an hour a day. and i got the e74 message....what causes it and do i have to send it off to fix it or should i return it?
