Question about Apple iPod nano 3rd Generation
My ipod nano third generation won't work.
I have had my ipod for one year. Today it shut off while I was listedning to it. The battery was fine before it shut off. It won't turn back on. I tried to charge it, but it won't recognize that it is plugged in. I still let it charge for 2 hours and it still won't turn on. Any advice?
  • rockinva Mar 12, 2009
    I also found this solution on the Apple website and it took care of my problem! Thanks!
  • Anonymous Mar 15, 2009
    my ipod wont turn on no matter what i pugged it in to the wall charger, usb on my computer, tried letting it charge for hours. Tried the reset keys and the disk mode... nothing but a paper weight now please help
Try resetting your ipod by sliding the "hold' thingy back and forth once, then pressing Menu and Select at the same time(it may take a few seconds, but then the Apple logo will show up, and it should be back to normal). I hope this helps!
Posted on Mar 11, 2009
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
I tried to turn on my air coditioning today for the first time this year and my Totaline Themostat P474-1050 won't turn on. Worked fine during the winter and last summer.
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
Jul 10, 2012 | Heating & Cooling
Car suddenly died and battery and oil lights stay on. Battery and oil are fine but car won't stay running without giving it gas. Help?
Did you ever figure out what was wrong with your car? This exact thing happened to my car today.
May 16, 2012 | 2000 Mitsubishi Galant
Ipod 5th gen is not connecting to Pioneer Receiver
I assume its blue tooth enabled! make sure its enabled in your ipod. sometimes it shuts off on its own. or try turning ipod comp off and unplug reciever for 30 sec then turn on and try
Feb 04, 2012 | Pioneer Audio Players & Recorders
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
After charging your portable media player overnight, you turn it on only to find that it is reporting a low battery. Seconds later, it shuts off automatically. What might be wrong
Ifthe MP3 player battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Apple iPod shuffle MP3 Player
I have an iPod Touch 4 with iOS version 4.1 It has been working flawlessly for 2+ months. Today when I shut my B&W off (while the iPod was docked), I got the flashing red light. I unplugged the...
these all relate to the power supply, sometimes when the board is faulty the aux works fine, the red light flashing may only occur when the ipod is connected, but it is all part of the same known problem. contact seller or b and w service, they should fix it.
Nov 01, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
My ipod wont turn back on even on the computer
my ipod wont turn on even when i contect it to the computer
Apr 16, 2009 | Apple iPod nano
Ipod 30gb battery shuts off in 30 minutes
your issue could be one of 2 things.
Either your battery is becoming old and needs to be replaced or your mainboard is malfunctioning and causing the low battery signal.
If you have your music library backed up in iTunes, I would connect the iPod and restore the firmware. You can accomplish this by pressing the restore button in itunes.
If your battery is more than 2 years old, replace it and see if the problem goes away,
Mar 04, 2009 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano 3rd Generation Logo
91 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
