Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Where can I find a board for my Hitachi 51F500. DP2x JK08012 Deflection conver PWB #2. Had problems with picture with curve on top and bowed in middle, green on majic focus would not move. Went to replace STK 392-110 with STK 392-180. I cant solder to well and I think I ruined the Board No picture or volume now
    President:
  • Hitachi Master
  • 1,779 Answers
I have checked all my suppliers and that board comes up Not Available. It must be repaired to component level.
Posted on Mar 08, 2009
No sound and black screen on my Hitachi 57F500 57 in. Rear Projection HDTV-Ready Television. But if you hook up a video game console you hear sound.
Hi
Have the unit serviced you have no high voltage going to the picture tubes. The most common failure part to suspect is the Deflection Board.
Mar 10, 2011 | Hitachi 51F500 51" Rear Projection...
My Hitachi TV Model #51F500 is showing shadows and double lettering (in other words a terrible picture). Please help.
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Hitachi 51F500 51" Rear Projection...
Colors r seperated n the top and bottom of picture r curved
HI:
This is a convergence power supply problem on your deflection board. There are 2 small bias fuses on the deflection board that has blown, usually this is caused by bad connections on the flyback transformer, it is also possible that the convergence power supply has failed also, but normally on this model open micro fuses on the deflection board is your prolem.
Please leave comment if more info is needed.
Lavell
Sep 28, 2009 | RCA HD52W59 HDTV Projection Television
Sound but no picture
Power supply/Deflection Board and alot of poor connections will cause this.
Aug 06, 2009 | Hitachi 51F500 51" Rear Projection...
Curved picture at top and bottom
if it is bowing from top and bottom your looking at a convergance problem if you keep using your tv soon there will be no picture at all when the board crashes... convergance board needs to be replaced... hope this helps..
Apr 11, 2009 | Samsung HCN4727W 47" Rear Projection...
Parts
Which board are you refering to as the main circuit board? The power supply PWB ? The Deflection / Convergence PWB ? or the Signal PWB ? respond to this same post and I can help you out, but there isnt a PWB called " main" In that chassis hitachi.
Jul 31, 2008 | Hitachi 46F500 46" Rear Projection...
Hitachi Projection HDTV Convergence Problem
If you have the schematic diagram, look for the deflection PWB. The STK392-110 ICs are mounted on 2 heatsinks, in order to remove the parts you will need to unplug the deflection PWB from the chassis.
May 14, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Magic focus
That's a DP23 chassis, why replace the deflection board? Does magic focus come on the screen? Does it just no converge the picture? If so, it's likely that the convergence amps have failed.
That unit takes two STK392-110 Sanyo built Ics at board position Ic04 & Ic05. If you replace them I'd upgrade to the STK392-150's for greater reliability.
Bill
Dec 13, 2007 | Hitachi 51F500 51" Rear Projection...
Hitachi 51f500 magic focus
convergance amp ic bad
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 12, 2007 | Hitachi 51F500 51" Rear Projection...
65xwx20b
Is this a Hitachi set? If so then check the model number and be sure it's right.
Dec 05, 2007 | Televison & Video
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
272 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
