Question about Dual Car Audio & Video
Dual XHD7714 bluetooth microphone gain adjustment
Is there a way to turn up the gain on the microphone on this unit? Just received the deck, install was easy, setup was easy, and it actually sounds and works awesome! So far have only received 2 phone calls and they both said it sounded like I was at the end of a tunnel, hope there is a way to adjust the mic gain so that the unit picks my voice a little better
Http://www.dualav.com/phpBB3/viewtopic.php?f=4&t=218
I fixed this problem on mine by doing some fairly intrusive 'surgery' - the link above is what I posted on Dual's forum describing what I did.
Posted on Jul 16, 2010
  • 1 more comment
  • josh810 Jan 11, 2011
    Can you tell me how you fixed the microphone on your Dual XHD7714. I have been watching the forum you said you posted the fix in but it seems to be down indefinitely. Any advice you can give would be greatly appreciated.
  • figgskzoo Jan 11, 2011
    What I did was to open up the face plate case, unsolder the crappy factory mic and in its place, soldered in a 1/16" mono female jack. Then I opened up the mic hole in the faceplate case just enough for the 1/16" jack to protrude. Then I ordered an external, visor-clip, mic with a 6' cord and a 1/16" jack, clipped it to my visor, ran the cord and plugged it in. Presto! I might be able to dig up the part number of the jack, but I got it from digi-key and it was about $2. The mic was $30 and it was a Panasonic brand, iirc. Hope this helps!
  • Al from MA Jul 28, 2013
    figgskzoo, I tried to find a source for 1/16" jack, but that seems smaller than any jack I can find. I found 1/8", 1/4", and 3.5 mm. Any chance you could post the part number of the jack you used?
How install dual xhd7714 on 99 toyota rav4
Did you buy a wireing harrness kit,? The instructions should be in with it if you did buy one. It is hard to explain how to doith because everry vehicle is different with the colour of the wires, My suggestion is to get someone to help you with it that has installed decks before,
Nov 11, 2012 | Buck Toyota Rav4 2003 Stereo/radio...
Need instructions on setting clock on dual xhd7714 car stereo
With the unit on, press and hold DISP until the clock begins
to flash, then release. Press TUNE << to adjust the
hours and TUNE >> to adjust the minutes. Press DISP
momentarily to save the selected time.
Mar 01, 2012 | Car Audio & Video
How do i reset my dual electronics XHD7714? why the red ligth is always blinking? please help!!!
The red light is blinking because it is in theft mode, you need to enter your anti-theft code... I have been trying to get mine from dual for a week now, hope you didnt lose it like i did. You need the remote to enter the code by the way.
May 09, 2010 | Dual Electronics XHD7714
I have a Sennheizer evolution g2 transmitter and reciever to go my Sony EX3 - but the input level is too low - could this have to do with the frequence I'm on?
It got nothing to do with the frequenty.
You can adjust the microphone gain in the handheld-menu. You can also adjust the receiver-output gain in his own menu.
Good luck,
Gerard
Jan 31, 2010 | Sennheiser Evolution G2 100 Series UHF...
Is There An Internal Adjustment for compression limitor...which variable resistor?
Every wireless microphone has a compressor, but thats very important. This way you keep a good signal out of the transmitter, if you adjust the compressor your bandwith will be to high for your receiver.
A better option is to degrease the microphone gain in your handheld and increase the gain on the receiver.
Than the compressor doesn't limit that fast.
Regards,
Gerard
Jan 08, 2010 | Nady Systems UHF 10 / HT Professional...
Wiring in a new car deck
The easiest and most efficient way to hook up your old radio harness to a new head is to use a harness adapter that is made for your vehicle.
If you have not cut off the old plug that went into the old radio then it would be a simple matter of plugging the adapter harness into the old plug and color matching the wires from the adapter to the new head wires, which will be the same colors.
If you go on line to - Installer.com you probably will find the correct adapter for your vehicle. There are other on-line stores that deal with adapters, as well.
If the old plug was cut, it may be possible to splice the plug back to the original wires, then it's a matter of plugging the adapter plug into it.
Hope this helps...
Jul 13, 2009 | JVC KD-S5050 CD Player
Car Audio & Video Logo
1,626 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
