Question about Whirlpool GS2SHEXN Side by Side Refrigerator
Whirlpool gs2shexn side by side problem
The digital temperture adjustment display and the light have failled on my fridge does anybody know if there is fuses or any sollutions to this problem. On the freexer dide the light still works fine.
The problem is usually a burnt trace on the main control PCB. If you jump this burn with a wire it will fix the problem.
Posted on May 31, 2009
  • 400 Answers
No fuses, the board needs to be replace.
Posted on Mar 09, 2009
How to stop the flashing (strobing) lights inside both the fridge and freezer?
I had the same problem but instead of throwing a couple hundred dollars away I decided to let my lights stay on all the time inside the fridge. All I did was pop the filter switch out so it wouldn't trigger when the door was closed. No more flickering and the hole doesn't irritate me like the rave party inside my fridge did????
Apr 01, 2015 | Whirlpool WRS325FDAM 25.4 cu. ft. Side by...
Adjustment temperture on ge side by side model gss25gfxaww
You can't adjust it. You can set a new set point and see if it gets there in 24 hours, otherwise you might have a problem with you fridge.
Jul 25, 2012 | GE GSL25JFPBS Side by Side Refrigerator
What is the freezer evaporator
The cold bit behind the panel, silvery metal fins with loops either end. May have fans top and bottom or to the side.
May 21, 2012 | Whirlpool GS2SHEXN Side by Side...
I have a whirlpool side by side fridge. This
On some models you have a mother board located on the back outer section of the refrigerator that can be faulty. There is a tech sheet located behind the kick plate or under the front of the ref bottom to refer to. If someone olays with the digital controls you may have to reprogram the mother board, which is explained in the tech sheet.
Jul 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I HAVE A WHIRLPOOL GC1SHAXMB00 SIDE/SIDE CANNOT CHANGE FRIDGE TEM
try the control bd first this is a bad problem with this model
Oct 11, 2009 | Refrigerators
Fridge light does not work nor the display inside fridge is the bulb fused so when blown display goes out
Yes , the bulb lights up a fiber optic strand , which runs to the display . No light , no lighted display .
Sep 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hi: It sounds tough. Have you tried resetting the electronics? Unplug it for one hour. Don't get into it so the cold will stay in. Then plug it back in again. Sometimes chips need to be reset. Good Luck, Jeff
May 30, 2009 | Whirlpool GS2SHEXN Side by Side...
Freezer and Fridge at wrong temperture
How old is this fridge? Your themostat may be shot. Put an accurate thermometer in the freezer and cooler to ge the real reading. If they are the same as on the door then the themostat is probably the problem. If not, it could be that all you need is a new display.
Dec 17, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Whirlpool GS2SHEXN Side by Side Refrigerator Logo
232 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
