Question about Homelite ZR10926 16 Chain Saw
Fuel line has come lose for the chain saw. And dont know how to put it back in
  • John Aman
    John Aman May 11, 2010
    Which end has the line come loose from? the fuel tank or the carb?
    Problem Solver:
You give this same answer for every fuel line replacement but what is the real trick to getting the fuel line back 'into' the tank, especially in a Poulan where there is no soft rubber grommet that will expand..
Posted on Oct 26, 2011
Need a digham for poulan chain saw fuel lines the old ones dry rotted and i dont know how to install the new ones
James I have the same problem. Can you help with a picture or instructions on how to fix please
www.oneway@bellsouth.net
Thanks, .
Oct 03, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
New Rancher 455. Ran for a few minutes then tried to tighten chain but adjuster was maxed out (completely tight clockwise). Removed cover, now can't get tension adjusting pin in hole in bar....pin sits...
Ok.. with the cover off the clutch you notice the screw and the pin that is suppose to go into the hole.. with the chain on the bar back the screw until the pin sits in the hole of the bar.. The chain should be lose you will see the chain dangle at the bottom of the bar.. put the cover back on with it lose.. hand tighten the two nuts that hold the cover on. with the bar in hand and you pulling the bar up make sure the two nuts are on tight enough so the bar does not move but dont over tighten it. tighten the screw you will notice the chain starting to move, and start to tighten up.. once the chain is in the grove of the bar grab the chain and move the chain with your hand to make sure you have not over tighten it. if the chain moves freely and is not lose ( you can also double check how tight it is by grabbing the chain below the bar and letting it go if it snaps back into the bar and doesnt hang there you are where you need to be.) tighten the two nuts up on the cover and start up the saw. Run the saw to make sure everything is all set and nothing is lose before cutting.. If the chain never get to tighten up you need a new chain. buy a new chain and follow the steps again. let me know if you have any questions
Jun 19, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have difficulty starting my Gardenline 49.3cc chainsaw. Please let me know what the correct starting proceedure is.
Genral starting procedure on a chain saw is as follows, put fresh fuel into the fuel tank, top up the chain oil tank,switch the ignition on, if the saw has a half throttle position on the trigger lock this, if the saw has a primer depress this as many times as it takes to 3/4 fill the bulb, pull the choke fully out, if it has a deco valve push this in, now place the saw on the ground with the chain brake on and crank the engine ( always have the saw body between you and the cutter bar,NO left hand starting, NO drop starting ) the engine will only fire once on full choke, do not continue to crank engine after the first fire or you will flood the engine, push the choke back in, crank the engine until it fires up and runs,release the chain brake and blip the throttle to release the half throttle device.
Jan 22, 2011 | Garden
Need fuel diagrahm for poulan chainsaw with priming bulb .took apart and dont know how the fuel lines go. 14'' saw
Hi try this link for a pdf of owners manual: http://www.chainsawsdirect.com/manuals/Poulan_4620AVX_Man.pdf
Hope this helps
Jul 21, 2010 | Poulan Pro Chain Saw 46cc 20"
Homelite chain saw fuel system
The line at the back of the tank gets the filter (check it for plugging) and the one nearest the cap doesn't use a filter (it is the return line from the primer bulb). The filtered line goes directly to the carburetor inlet port and the outlet port allows fuel to be pulled through the carburetor and out to the primer port. Check and replace any fuel lines that are in poor condition. If the engine has been running with the intake filter missing, the interior of the carburetor may be full of debris. Remove, dismantle, and clean the carburetor interior. Go to: http://www.drystacked.com for an excellent 12 page article on Walbro carburetor theory and troubleshooting. Hope this helps!
May 31, 2010 | Homelite ZR10926 16 Chain Saw
Fuel line is bad and needs replaced. need to know
  • One line should be hooked to a small fuel filter or screen.
  • The other one is a dump or over flow that will put a small amount of unused fuel back into the tank.
  • You can buy this type of line at most Lawn Mower shops as a kit. 2 lines and a filer/screen.
  • You can use line for air shocks that fit some cars ie. Cadillac's
May 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a poulan 305 pro chain saw were do the 2 fuel lines go?
Find your model nuber here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The drawing containing your fuel system is as good as it gets. If you need more help contact PoulanPro.com. HTH
Lou
Jun 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Ryobi 18" petrol chainsaw won't start
my guess is that you have a crack or a hole in one of your fuel lines. this is very common in chainsaws and weed eaters because they are used very little and sit for a long time. try checking this and repair if necessary. let me know if this works.
Mar 08, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Fuel Line Deteriorated
the piese on the end of the fuel line is a pickup filter. if you can blow thru it, then it is still good and you dont have to replace it, but if you want to, you can get them and the fuel line from your local small engine shop. if you have a menards or home depot in your area they ussually carry the line & filters aswell. you will need to take a piese of the old line with you, so you can match the size. the line going into the tank usually seal due to the hole being smaller than the plastic hose, which makes feeding it interresting. i just heat a 1/4 inch or so of the end just enough to stretch it out. this causes the diameter to shrink,then melt the tip& roll it into a point. as you feed it thru, use a couple drops of oil so it pulls easy and does'nt stretch(which will effect the seal). pull enough hose thru so that the filter will lay flat in the bottom right hand corner (as looking from rear of saw toward the tip of the chain) of the tank. this ensures that you pickup fuel when you tip the saw on its side.
Feb 27, 2009 | Homelite Garden
Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
best regards savumihai71
Feb 13, 2009 | Husqvarna Chain Saw 20" Bar
Homelite ZR10926 16 Chain Saw Logo
110 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
