Question about Daewoo Audio Players & Recorders
I start my daewoo MPF-1620A 2G, a pink light appears, and then the player shut down. Help me:((
Buy rechargable batteries man
Posted on Apr 29, 2009
My daewoo racer has starting problem.it starts and engine gets no power and engine shuts down when accelerator is released.kindly help me.
Hi Bia, The links below are YouTube videos showing how to fix a car that cranks but doesn't start, Also there's videos down the right side of the links that may help as well..................CHEERS..
Fixing Car That Cranks But Doesn Start Up
Car Cranks But Will Not Start
May 08, 2016 | Daewoo Cars & Trucks
Help!!!cant find what fault code means
P4040 code that is a non specific code that could be either EGR control circuit malfunction or security shut down mode meaning that the security system is shutting off the spark and/or fuel.
Sep 20, 2014 | 2001 Daewoo Lanos
Why my Daewoo Esparo doesn't start
Do you electrical power? Are the head lights working? Are they as bright as they should be? If not check the battery. If they are does the engine crank when you try to start it? If not check the starter. If it does try spraying some starter fluid on the air filter. Try and start it again. If it then runs and shuts down after a second or two you have a fuel issue. Is the check engine light on? If it is you may a sensor related issue causing the engine to not start.
Apr 25, 2014 | 2005 Daewoo Espero 2.0
Hi, I have a Dell printer, and it says "MPF Load Error" every time I try to print something. How do I fix this?
Verify the Paper Type Matches the Type Set in the PrinterĀ“s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
Print from the Multipurpose Feeder (MPF)
To print from the Multipurpose Feeder (MPF), perform the following steps:
  1. Click the Start button, point to Programs, point to Accessories, and click Notepad.
  2. Type the word test.
  3. Click File and then click Print.
  4. In the Print window, verify that the Dell 3000cn / Dell 3010cn / Dell 3100cn printer is selected in the Select Printer dialog box.
  5. Click the Preferences button.
  6. In the Printing Preferences window, click the Paper Tray tab.
  7. Click the Paper Source drop-down and select MPF.
  8. Click OK.
  9. Click Print.
Aug 19, 2011 | Dell 3010cn Laser Printer
I own a Daewoo DH-6100P DVD player/recorder and I am unable to get the set up menu to appear on the TV screen. The TV and DVD player are connected to a Sky Box. Can you help please? Keith Saunders
The model is DH-6100P, 80gb HDD crashed then formatted it. Now no start-up menu, stuck please help with solution or firmware file for re-install if possible.
Feb 28, 2011 | Daewoo Televison & Video
How to fix nano
i have a mp3/mp4 player..when i turn it on i only see the light but the menu doesnt appear on the screen..
can u help me pleasee?
Jul 22, 2009 | Apple iPod nano
H.E.L.P!!!!!!!!!!!! PUHLEZE!!!!!
I had the same problem with mine. All you have to do is search these keywords: Virgin, MPF-1000, Driver, Download
When you search those keywords you should have quite a few options to download the drivers needed. Anyway, here are a few links to the software and/or drivers needed for you to be able to get your Virgin Pulse MPF-1000 working.
http://www.soft32.com/download_172979.html
http://www.versiontracker.com/dyn/moreinfo/win/39151
http://wareseeker.com/Utilities/virgin-mpf-1000-2.6.0.28.zip/1fbd18a12
http://pcdrivers.es/vp-mpf-1000-driver/download-2785.html (This download website is in Spanish for those of you that can only read/speak in Spanish)
http://www.drivers-software-download.org/virgin-mpf-1000-26028/
That will be all you need to do. Once you have installed the driver, plug the MP3 into the USB. Once you plug it in the autoplay should come up and just go from there. Please let me know if this solves your problem.
Thank You & God Bless,
MadHatter25
Sep 13, 2008 | Virgin Pulse VP-MPF-1000 (256 MB) MP3...
3010 dell color laser
Ok,
I've went around and around with the same problem (bug) and finally found a solution. Here is the deal. You have to exactly match the settings for the MPF tray in the aplication softwares to the MPF tray settings set from front panel on the printer.
I found this problem when trying to print on gloss paper. The MPF tray had to be set for "Coated 1 Side 2" in both the application and on the front of the printer.
Lets say I'm printing a Word Document. Go to file, print, select the Dell printer, then select properties, select paper tray, set paper source to MPF, set MPF settings to ""Coated 1 Side 2". Click OK.
Now do the printer setup. From the front panel on the printer.
Press Menu, press the down button to Tray Settings
Press center button to select.
Display now asks for paper type. Press center button.
Displays MPF. Press center button.
Push down button until you see Coat1 Side2
Push center button to select.
Press Menu to exit.
I only print on gloss so I have to set the MPF tray to Coated 1 Side 2. I was told this slows the feed and that is needed for coated papers. Now you could probably use another setting as long you set both the MPF tray in both the application and the control panel to match exactly.
Aug 19, 2008 | Dell 3000cn Color Laser Printer
Mp3-mpf-1720
Foloseste CD-ul de instalare. Are nevoie de un driver care se gaseste pe acel CD. L-am folosit pe Windows 7 care il recunoaste singur dar pe Windows XP este nevoie de CD-ul livrat odata cu Mp3 player-ul.
Jun 29, 2008 | Daewoo Pinno VX320 Digital Media Player
My virgin pulse need driver
I can't find my software for my Virgin MPF 1000 where can I get it?
Sep 11, 2007 | Virgin Pulse VP-MPF-1000 (256 MB) MP3...
183 people viewed this question
Top Daewoo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Daewoo Audio Player and Recorder Expert? Answer questions, earn points and help others
