Question about Whirlpool 18.2 cu. ft. Top Freezer Refrigerator ET18PKXG
Whirlpool ET18NK fridge does not get cold but freezer is ok. The freezer portion is around 15 degrees, but the fridge wont get colder that about 53 degrees. The house was empty for about 6 months, and we plugged in the fridge before the heat was on in the house. Dont know the exact temp when we plugged it in, but it wasnt much above freezing, if at all.
  • mgcontrols Mar 09, 2009
    Turns out, the fan was frozen, and never had a chance to thaw.
    I emptied the fridge and freezer and allowed them to defrost for about 5 hours. Then started taking screws out of the freezer pan and back wall of the freezer to take them apart to clean it. After taking the vent tubes out and removing the back wall, I had access to the fan. So I plugged the fridge back in and saw the fan was not working. I gave the fan fan a little "flick" with my finger, and away it went. Started working and hasnt stopped working yet.
    I am going to buy a new fan to keep on hand in case it happens again.
  • 286 Answers
If the fan is frozen this would be cause because something in the defrost system is bad. Or you could have a open motor. Make sure the door gasket is sealing.
Posted on May 13, 2009
Top of the refrigerator is not cooling and the freezer portion is to cold
Main cooling happens in the freezer.
Since top (fridge part) not getting cooling the sensor in that part is continuously asking for cold. So the freezer get colder and colder.
Fridge part not cooling can be due to one of the many reasons.
Evaporator fan, Defrosting problem, Damper motor issues etc etc.
Sep 02, 2014 | Whirlpool Refrigerators
Amana fridge is not cold but freezer is working
If freezer is ok and cooling ( 5 degrees or less) one thing you might want to check is that the flow of cold air to refrigerator is not obstructed by the items in your freezer. The ductwork has to be available. Also check the opening of the damper if fridge is not cold enough. And is the fan operating at full speed - are the bearings dirty and slowing it down?
Also check your freezer temp - there are degrees of freezing. Water freezes at 32 degrees but a good freezer should go down to about zero. And the colder your freezer air is the colder your fridge will be.
Sep 21, 2017 | Refrigerators
Freezer cold fridge isnt
freezer working,fridge not working,condenser fan ok, compressor running very hot.
Dec 14, 2011 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ET18NK fridge does not get cold but freezer is ok. I took off the freezer back panel -- the fan behind it isn't working.
Hello, Thank You for using FixYa. I will be helping you today. Check to see if the fan is getting 120 volts when the compressor is running if it is replace the fan motor part w10189703
Thank You and please rate my answer if it was helpful..
Jun 21, 2011 | Whirlpool ET8GTKXKQ Top Freezer...
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Doesnt get cold enough ,thermastat gets to 42 degrees but i dont think its cold enough ,can it be set to get colder
check the recirc vents on the freezer part of the fridge , sometimes they condensate and freeze plugging these ports for cold air to circulate
Aug 22, 2009 | Whirlpool Refrigerators
FREEZER WORKS GREAT BUT FRIDGE NOT SO GOOD-COILS CLEAN
Sounds like a evaporator fan or defrost problem. Your freezer should be colder then that, 5 degrees or below. Anyway, any cold air the fresh food compartment gets is blown over from the freezer, verify you can feel the air flow or visually see or hear the fan in the freezer compartment. If that checks ok more then likely your defrost system has a defect. This consists of a defrost timer or adaptive defrost board, a defrost terminator which is just a bi-metal thermostat set typically at 30 degrees or so and a heater element, either a calrod or 1 or 2 glass encased elements. When this system fails you end up with a block of ice on the coils through which air cannot circulate.
Oct 21, 2008 | Whirlpool Refrigerators
Refrigerators Logo
1,015 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
