Question about Alarm & Keyless Entry System for Honda Vehicles
Acura 1,6 EL 2000, keyless entry/security alarm system is defect. door's lock don't work, where i can buy a rebuilt unit because a new one is very expensive. Thanks my Email: perro.g@videotron.ca
3 Suggested Answers
  • 65 Answers
SOURCE: 2000 Acura 1.6 EL back doors won't open
Have you lubricated them before? if so then what did you use? it may just be a gummed up locking mechanism but if the manual locks seem fine then it's probably an electrical issue. Is it only one door? do you use it often?
it usually found in the bunch of wires that are all in a rubber tube going to the door, you can see them when you look where the hinges are and the door is open.
I wouldn't go poking around in there yet. First go and see a parts place and get a wiring diagram that shows what wire colors are for when then you will have to find where they go. It is most likely a broken wire or bad connection. once you found out what does what then either test the wires with a multi meter available at any hardware store ,digital ones are best. adn if you find that the wire is bad then replace it. or repalce all the wire which may affect it. I would do the latter if it's only like 2 wires. hope this helps
Posted on Jun 27, 2009
  • 17 Answers
SOURCE: my dodge caravan '09 keyless entry does not work at times
I've had the same problem with my 2009 Grand Caravan also.
I asked the dealer about it, but they weren't aware of anything regarding this. Since it has only happened a couple of times during the past year I haven't done anything else about it. They offered to replace the RKE fob (remote) if the problem persisted.
Posted on Mar 30, 2010
How do I reset keyless door entry that is in lock out mode
Viper Keyless Entry Systems
https://www.viper.com/car/keylessentry/
Viper is the industry leader in keyless entry systems. Add the convenience of keylessentry to virtually any vehicle - even vehicles without power door locks!
Alarms, Remote Car Starters, Keyless Entry & Locks - JC ...
www.jcwhitney.com > Audio, Video & Electronics
20 out of 32 products in Alarms, Remote Car Starters, Keyless Entry & Locks ..... ofKeyless Entry & Car Alarms allow you to lock and unlock power door locks.
How to program your keyless entry keypad - Ford Ownerhttps://owner.ford.com/.../locks.../how-to-program...Ford Motor CompanyDiscover how to lock and unlock your doors and how to program memory settings that will adjust seats & mirrors for each driver.SecuriCodeā„¢ Keyless Entry Keypad - Ford Ownerowner.ford.com/.../locks.../securicode-keyless-entr...Ford Motor CompanyLearn how to set a 5 digit SecuriCode on the Ford keyless entry keypad. ... Sign out. Register/Sign In Ā· Your Vehicle. Service & Maintenance. Service & .... vehicle's SecuriCode keypad to lock and unlock your doors without having to use a key. ... Thekeypad will go into an anti-scan mode if you enter the wrong code seven ...How Programming Your Keyless Entry Can Make ... - Ford Life
Jan 08, 2016 | Cars & Trucks
My 2003 Acura MDX security system will not cut on( I do not hear a beep) when I lock the doors. I have checked all doors, opened & closed each. I have turned the key on & off thinking the ignition...
Check your owners manual for operation of your factory keyless entry remote and factory alarm operation. The features that you mention are programmable.
Apr 14, 2011 | Acura Vehicle Parts & Accessories
Bought from dealer with no keyless entry. alarm activates when doors are locked with power doorlock system. alarm sounds when we open the door. how do we de-activate the alarm before unlocking the door?
Opening the drivers door with the key is supposed to shut down the factory security but the drivers key cylinder usually goes bad. You will have to unlock the rear tail gate lock cylinder with the key and that will shut down the factory security, before opening the drivers door.Your other option is to have an aftermarket keyless entry system installed, which will open the doors remotely while shut down the factory security at the same time.
Jan 25, 2011 | 1996 Jeep Grand Cherokee
My viper 5002 alarm i don't know witch wire's to use off the viper alarm's for the power lock's
The door lock wires for the Viper alarm are green (-)lock and blue (-) unlock. The Viper system only provides a negative lock/unlock pulse for the door locks. So, if you are working on a vehicle that has positive door locks you will have to install relays to change the polarity.
Nov 08, 2010 | 5002 2 Way Car Alarm with Keyless Entry...
Bulldog remote start brain module acting crazy!, turns alarm on!
I have installed 4 deluxe 200s ( 2 on my vehicles and one on each of my parents) and I seem to have problems with the remotes dying but no other problems. I had to buy another unit just to get the remote so now I have an extra deluxe brain brain. If you are interested email me kbirdjr@sbcglobal.net If you decide to get a different unit I might be interested in buying your remote.
Nov 30, 2009 | Remote Starter with Keyless Entry
LHJ001 WIRING
I have the 1995-97 Lincoln Continental Alarm, Remote Starter, Keyless Entry Wiring, review it:
Hope helped.
Oct 30, 2009 | 1996 Lincoln Continental
Have a 2000 VW Beetle. The alarm won't turn off!
My 2000 Beetle does same thing (although not all the time). Just found an internet post that suggests there is a problem in the door lock sensor. I assume you are using a regular key - not
the keyless entry - like I am. He also said that you can disable the alarm (also disables the
keyless entry - which doesn't bother me) by leaving the front door AND the rear trunk open and
starting the car up. Seems to work so far. I will get the door lock sensor replaced and turn the
alarm system back on (not sure how yet), and let you know if that stops the problem.
Jul 24, 2009 | 2000 Volkswagen Beetle
Keyless Entry doesn't unlock my doors anymore
Did you get help? My problem is similar but not as bad. My viper550ESP no longer remotely unlocks the doors (well very, very occasionally it does). That is the only problem.
Jul 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Alarm & Keyless Entry System for Honda Vehicles Logo
146 people viewed this question
Top SMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a SMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
