Question about 2wire 2700HG-B Router (2700HGB)
Have a 2wire modem and I want to bridge to Netgear router - can't get to Netgear admin page...
    Problem Solver:
  • 6 Answers
Default IP is 192.168.0.102 or 192.168.1.102
Posted on Mar 27, 2009
,hjkljljljlj.m
Posted on Mar 08, 2009
I bridged an either-net cable from 2wire modem to Net Gear Wireless router. I need to turn off wireless (DHCP?) on the 2Wire modem, since it is unecessary. I am prompted at login for admin password at...
If you want to turn off dhcp for 2wire then connect the two wire to a computer and use :192.168.1.254 .But if you are doing in for netgear then yes you can use :192.168.0.1 with the user name as admin
password as password
*** it will work only if you have never customized the router admin password . else do a hard reset of router (pin hole in the back - press and hold 20 secs )and the router will be in factory default mode ..
Aug 17, 2011 | 2wire (2701HG-B) Wireless Router
Attempting to connect WGT624 V4 as a wireless bridge to connect to my 2 wire qwest dsl modem to connect tv components to internet along with Xbox 360
To establish the bridge connection, make sure to write down the Wireless MAC Address of the 2wire first. Now login to your Netgear router's setup page and go to the wireless bridge settings. Manually type there the Wireless MAC Address of the two wire. Make sure to enter the same SSID, same Channel and same Wireless Security Key to successfully establish the wireless bridging. Save your settings after that and reboot the router.
Oct 22, 2009 | Computers & Internet
2wire VPN over cisco router 800 series
yes.
when u bride modem you have to go inside ur cisco if u have ur 2wire bridge u should pick up a diffrent ip than 192.168.1.254 on the default gatewat | go to ur command prompt or DOS screen |
vista type CMD on ur search on the start menu at the bottom
xp go to RUN then type CMD | should brin up black screen
type in (ipconfig) look for default gateway |
go to ur browser and type that IP address on the address bar
should take u to ur cisco interfase | then should ask ur for a username and password try variation of admin admin or (blank) admin or admin (blank) that should get u in
if u see DHCP make it PPPoE then it should ask u for username and password from ur ISP or ur primary email address from ur ISP and password | that should do the trick
*****if u cant find username and PWD go to WAN setting manual settings then PPPoE and then USRname and PWD
rate me pls
Mar 24, 2009 | 2wire (1000-400108-001) Router
Difficulty in installation
1. hard reset ur modem ( it will set to bridge by default)
2. connect ur modem to WAN port at netgear router
3. connect ur pc to LAN port at netgear router
4. by default ur pc ip should be 192.168.1.x
5. type at IE/firefox address bar
username = admin
password = password
6. enter all basic info (ISP = other, streamyx username password, wifi setting)
7. set value for idle timeout (in minutes) = 0
Dec 18, 2008 | NetGear WGR614 Wireless Router
Netgear wgt624 just stopped connecting to internet
I encountered the same problem, with the same modem and also Comcast, and here's what wound up working for me, after time spent with a nice guy on the Netgear customer support line:
1. Log into router: http://192.168.0.1 (or 192.168.1.1) - user: admin / password: password
2. Under Maintenance, click Router Status. If IP Address is listed as 0.0.0.0, there's your problem-- router isn't getting address from modem.
3. At bottom of Basic Settings, under Router MAC Address, change selection from Use Default Address to Use Computer MAC Address.
4. Click Apply.
5. Click Router Status again-- non-blank IP address should now be listed.
6. Basic Settings will now show MAC address under Use This MAC Address. See if you can get online now. I could, and I hope you can, too!
Dec 04, 2008 | NetGear WGT624 Wireless Router
Setting Up the Netgear WGT624 as a bridge
Just disable the DHCP function of the Netgear router. Connect them from LAN port of 2wire to LAN port of Netgear.
Nov 25, 2008 | NetGear WGT624 Wireless Router
Tring to bridge my 2wire
Why do you need to bridge?
Can't you use both devices off the one router?
usually to bridge you would need, effectively , 2 extra access points to set as the bridges, they then connect to the other routers, allowing communication between the 2.
I do know 2wire is slightly different but you would still need something to act as a bridge on the netgear end.
I still don't understand why you need both routers running. Connect both your computers to the same router which has the internet connection.
Hope this helps
Tony
Feb 28, 2008 | 2wire 2700HG-B Router (2700HGB)
Problem in reconfiguring WGR614 v5 after reset
You should configure the 2wire to a bridged modem for the autentication to work on Netgear.check with your ISP for configuring your 2wire to bridged modem
Cheers !!
Feb 24, 2008 | NetGear WGR614 Wireless Router
Trying to hookup a wireless router to HP 1100
DSL uses PPOE, which may be different than what you had previously. Cable, for example, uses TCP/IP.
Re-set the router to defaults, and follow the instructions for PPOE, which should be in your manual or setup disk. Your ISP may have this info on their site, or you can get it at the Netgear site:
www.netgear.com
Oct 17, 2007 | 2wire HomePortal 1100 Router...
2wire 2700HG-B Router (2700HGB) Logo
315 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
noti13
Level 1 Expert
William Dehn
William Dehn
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
