Question about Intuit Quicken 2008 Deluxe Full Version for PC
Quicken 2008 won't load
I have had Quicken 2008 Deluxe on my computer for the past year. It just stopped working, wouldn't load. I uninstalled it completely and reinstalled it. After installation it goes to quicken website and upgrades to current verion. The program will then start, however once you shut it down it won't start again. The quicken launch screen flashes but thats it. No error message.
I have a Dell Inspirion 9400 Laptop running Vista Home Premium.
  • Dalynn Turner May 11, 2010
    Does Quicken show up in your process list or application list via task manager?
5 Suggested Answers
  • 55 Answers
SOURCE: I have reinstalled quicken deluxe
In the C drive Navigate to View menu and choose option "Details"
Now you can see the Created Date for specified files so that you can check which files are older / newer
Posted on May 29, 2008
  • 8404 Answers
SOURCE: I did a pc recovery,when
Remove all previous versions of Quicken. Reinstall your 2008.
If you still have trouble ... go to the quicken support page and keep clicking on help until you get an opportunity to Chat with our friends across the sea. @008 is still within the 3 <> yewar window of getting free chat support
Posted on Oct 19, 2009
SOURCE: Yesterday our Quicken Deluxe 2008 wouldn't open,
I have the same problem, have you found a solution?
Posted on Jan 05, 2011
  • 415 Answers
SOURCE: quicken deluxe 2008 - quicken
Sometimes a shortcut gets corrupted. Locate where quicken is located on your harddrive, typically it will be under c:\program files\intuit\ Then look for the launcher. It will end with .exe and make a new shortcut. You can first try double clicking on the file to see if it opens for you before making the shortcut.
If that doesn't work something else may have gotten corrupted and you may have to reinstall the program. I haven't used quicken for a few years so I can't guarentee this but I would check it out: -- Before reinstalling Quicken, if you find you have to, look for where your data files are stored. Unless you've specified otherwise it will probably be somewhere under your User Name in a folder. Rename that folder so it doesn't get overwritten when it reinstalls. Then once it is reinstalled you'll find it made a new folder with the name of the one you just reinstalled. Then it is just a matter of putting the old data in again, hopefully. Not all programs will work that way but many will so you won't loose whatever data you have. Hopefully just making a new shortcut is all you will need to do.
Posted on Jul 28, 2011
Quicken Launcher won't work
Usually RegKey of previous version isn't removed.
Mar 20, 2010 | Intuit Quicken Deluxe 2009 Full Version...
I bought Quicken 99 (basic) when it came out. I installed and re-installed it succesfully up to Windows XP until this year. This past month the icon dissapeared from my desktop and this past week, when I...
You could search the WWW for that file ... I think your best course of action is to get a good back up - both on a hard drive and on a cd or dvd of your quicken file. Save your file under a second name also (see below). Get 2010 version, which they started advertising to Quicken users about 2 weeks ago for $78.00. Load the software then tell Quicken to load your file.
BE ADVISED - the copy of your file on your hard drive will be over written when it converts to the new Quicken. That is the reason you save as another name. The new copy will not run on your Quicken 99 - however, you still have 99, right? and you have the copy under another name to run on that, right?
So you should be in good shape either way.
I think your real 15 year record is that you used it for so long!
Tell me, did I just answer another Quicken question for you here?
Jul 17, 2009 | Intuit Quicken Deluxe 99 for Windows...
Quicken Deluxe 2009 stopped working
your quicken deluxe 2009 is very OK... i think your system vista 64bit is the problem.. is there any other way that your 64bit vista is updating? if you try to use your quicken deluxe and it might works there.. so this time you are going to system restore your vista 64bit and back the recent checkpoint that quicken is run normally...
Jun 19, 2009 | Intuit Quicken Premier 2009 for PC
Quicken 2009 won't load any more. using windows vista.
Ok, this basically means the ini file is corrupted normally. What you'll have to do is either reinstall quicken 2009 or try a repair on it. You can also manually go to c:\Program Files\Quicken\qw.exe and see if the shortcut is bad that you have been using. If you don't have the disk, go to start, settings control panel, add remove programs or programs and features. Locate the program. Right click on it, click change. Then check the feature that gives you the option to repair the software. BACKUP quicken files if they aren't on a disk.
Jun 11, 2009 | Intuit Quicken 2008 Deluxe Full Version...
I did a pc recovery,when I did this my quicken deluxe 2008 program was removed from my computer. Later I reloaded Quicken deluxe 2008, but instead my quicken 2005 came up. How do I get quicken deluxe 2008...
Sep 24, 2008 | Intuit Quicken Deluxe 99 for Windows...
1. Downloaded and registered Quicken Deluxe 2008 but did not receive ID and password info that I have previously done with Quicken. 2. Have done a download from bank on 2 accounts, then downloaded data...
That means that there end has had a problem. You will just need to wait until they get there servers working again.
Hope This Helps,
All The Best,
May 28, 2008 | Computers & Internet
Won't Run
And did you reinstall? Perhaps a trip to Intuits website to see if indeed there is a patch for such a problem. I find that Quicken often has updates and patches. Here is the site for support:
Here is a link specifically to 2008 support:
May 16, 2008 | Intuit Quicken 2008 Deluxe Full Version...
Intuit Quicken 2008 Deluxe Full Version for PC Logo
879 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
