Question about Cycling
Head space loose on Peugeot bicycle - Cycling
    President:
  • 1,138 Answers
Sometimes the topnut works loose enough for the adjusting nut to come loose and then everything is loose. What usually happens though is that the bearings in the cages wear into the cups and you need a new headset. They come in various sizes and types so you will either have to take the bike in or take all the parts from your headset in to get a replacement. You should try backing the topnut off some more and then tightening the adjusting nut down as much as you need to remove the play and still not have any friction while your steering and then tighten the topnut back down. It will require a thin walled bicycle wrench the correct size to hold the adjusting nut in position so that you don't tighten it further while you are tightening the topnut with a second suitably sized wrench. Hope this helps.
Posted on May 09, 2009
Peugeot bicycle serial #604791 - what year is it?
Google "Peugot serial number" and do your own research. Nobody here is going to be able to help you any better than that. The year, frankly, is not that important. If it's a collectible bike the model is what's important, and that can only be determined by the original equipment on it. For more info see my tip:
How to determine the year value etc of your bicycle
Jan 21, 2017 | Cycling
Peugeot 308 Space wagon 1.6HDI, screeching noise from alternator area? 2010 model.?
possibly the bearings are going south and it needs replaced soon
Nov 02, 2016 | 2010 Peugeot 308 SW
Hi my freind has a peugeot 206 estate it is loosing water no leaks that i can see anywhere can anybody help pls many thanks jim
Losing water, you mean coolant right? If so and you have had the cooling system pressure tested and no leaks are present on the outside of the engine then you most likely have a leaking cylinder head gasket.
Oct 14, 2016 | Peugeot 206 Cars & Trucks
Assembly instructions
The brand would be helpful.
A Note: When you are assembling the bicycle be sure you tighten the steering-head and the handlebar screws and bolts properly.
Loose parts in this location is one of the prime causes of wrecks.
Dec 19, 2015 | Cycling
Knocking noise when accelerating
Very possible that the timing is out. Could be too advanced. If ok, possible bearing noise, low oil or exh. manifold gasket.
Sep 04, 2013 | Peugeot Cars & Trucks
One of my spokes on the non drive side of my rear Aksium wheel has come out of the hub because the space that secures the head of the spoke has warped.
Has the hole warped, or worn?
Either way, you will have trouble with a standard size spoke!
Ask you Bicycle shop dealer if he could sell you a spoke the next size larger in gauge, but the same length-- And can yo determine WHY the hub has warped?
Perhaps there is somethig else going on, that needs checking, too--
Maybe you had best show the problem to your Bicycle repair man...
Mack B
Jan 19, 2011 | Mavic Cycling
When i start my peugeot 2.0 ST the whole car shutters until the temp is half way what is wrong
blown head gasket or cracked head or cracked block take head off to see lot of work
May 23, 2010 | 2005 Peugeot 405
Fault code p0245 puegoet 406 turbo fault
My book shows that P0245 is the super/turbo charger solenoid "A" voltage is low.
Sep 29, 2009 | 2005 Peugeot 405
No excelration
check for loose hoses .you may be sucking air
May 05, 2009 | Peugeot Liberte Cars & Trucks
Cycling Logo
163 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
